Aircraft
ModelT600
Weight 2870 g (Battery and propellers included, Zenmuse X5 excluded)
3400 g (Battery, propellers and Zenmuse X5 included)
Max Takeoff Weight3500 g
Hovering Accuracy (P Mode)Vertical: 0.5 m
Horizontal: 2.5 m
Max Angular VelocityPitch: 300°/s
Yaw: 150°/s
Max Tilt Angle35°
Max Ascent Speed5 m/s
Max Descent Speed4 m/s
Max Speed18 m/s (ATTI mode, no wind)
Max Service Ceiling Above Sea Level4,500 m (Default altitude limit: 120 m above takeoff point)
Max Flight TimeApproxi. 15 minutes
Motor ModelDJI 3510H
Propeller ModelDJI 1345T
Indoor HoveringEnabled by default
Operating Temperature14° to 104° F (-10° to 40° C)
Diagonal Distance559 mm
Charger
ModelA14-100P1A
Voltage26.3 V
Rated Power100 W
Battery (Optional)
NameIntelligent Flight Battery
ModelTB48
Capacity5700 mAh
Voltage22.2 V
Battery Type6S LiPo High voltage battery
Energy129.96 Wh
Net Weight670 g
Storage TemperatureLess than 3 months: -4° to 113° F (-20° to 45° C)
More than 3 months: 72° to 82° F (22° to 28° C)
Charging Temperature5° to 40° C
Max Charging Power180 W
Max Flight TimeApprox. 18 minutes
DJI GO App
RequirementsiOS 8.0 (or later) and Android 4.1.2 (or later)
Supported Mobile Devices
  • Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD
Remote Controller
NameC1
Operating Frequency922.7~927.7 MHz (Japan Only)
5.725~5.825 GHz
2.400~2.483 GHz
Max Transmitting DistanceFCC Compliant: 3.1 miles (5 km); CE Compliant: 2.1 miles (3.5 km)
(unobstructed, free of interference)
EIRP10 dBm@900m MHz, 13 dBm@5.8 GHz, 20 dBm@2.4 GHz
Video Output PortsUSB, Mini HDMI
Power SupplyBuilt-in battery
ChargingDJI charger
Dual User CapabilityHost-and-Slave connection
Mobile Device HolderTablet or Smart Phone
Max Mobile Device Width170mm
Output Power9 W
Charging Temperature 32° to 104° F (0° to 40° C)
Battery6000 mAh 2S LiPo
Battery (Standard)
ModelTB47
Capacity4500 mAh
Voltage22.2 V
Battery TypeLiPo 6S High voltage battery
Energy99.9 Wh
Net Weight570 g
Charging Temperature32° to 104° F (0° to 40° C)
Vision Positioning
Velocity Range < 8 m/s @altitude 6.56 feet (2 m)
Altitude Range0.16 - 16.4 feet (5-500 cm)
Operating EnvironmentSurfaces with clear patterns and adequate lighting (> 15 lux)
Operating Range< 9.84 feet (300 cm)
Zenmuse X5R - Tuned Footage
2016-04-26
DJI - Mounting the Zenmuse X5 to the Inspire 1
2015-09-28
DJI Zenmuse X5 - From Flight to Post
2015-09-11
DJI Zenmuse X5R – Color Grading Session
2015-09-11
Inspire 1 RAW Straight-from-the-camera Sample Files
  • Inspire 1 RAW Iceland Sample Footage (55s)
    2016-04-26
  • Inspire 1 RAW Straight-from-the-camera DNG Sequence
    2016-03-23
  • Inspire 1 RAW Sample Video
    2016-03-23
Firmware
  • Inspire 1 RAW Firmware v01.10.01.40
    2016-12-15
  • Inspire 1 RAW Firmware v01.09.01.30
    2016-07-07
  • Inspire 1 Pro Firmware v1.10.1.40
    2016-12-15
  • Inspire 1 Pro Firmware v1.9.1.30
    2016-07-07
SOFTWARE
  • Dlog to sRGB 3DLUT
    2016-05-12
  • Dlog to sRGB 3DLUT User Instruction
    2016-05-12
  • DJI Camera Exporter
    2016-03-18
  • DJI Camera Exporter User Manual
    2016-03-18
  • DJI CineLight
    2016-05-30
  • DJI CineLight Release Notes
    2016-05-30
  • DJI CineLight User Manual
    2016-03-24
APP / LIVE VIEW
    iOS Version v3.1.5.
    Android Version v3.1.4.
    Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
Inspire 1 Pro Straight-from-the-camera Sample Files
  • Inspire 1 Pro Straight-from-the-camera Photos
    2015-09-30
  • Inspire 1 Pro Straight-from-the-camera Videos
    2015-09-30
Documents & Manuals
  • Inspire 1 RAW Release Notes
    2016-12-15
  • Inspire 1 Pro Release Notes
    2016-12-15
  • Inspire 1 RAW User Manual
    2017-02-09
  • Inspire 1 Pro User Manual v1.2
    2017-02-09
  • Inspire Series Remote Controller Release Notes
    2016-07-28
  • Inspire 1 Pro Disclaimer and Safety Guidelines
    2015-11-24
  • Inspire 1 Pro Intelligent Flight Battery Safety Guidelines
    2015-11-24
  • Inspire 1 Pro In the Box
    2015-12-01
  • Inspire 1 Pro In the Box (JP)
    2015-11-18
  • Inspire 1 Pro Quick Start Guide v1.2
    2016-01-13
  • Inspire 1 Pro Quick Start Guide (JP) v1.0
    2015-09-30
  • Zenmuse X5R SSD Quick Start Guide
    2016-06-03
  • Zenmuse X5R Reader Quick Start Guide
    2016-06-03
  • Inspire 1 Car Charger User Manual
    2016-06-17
mobile
Revolutionize Industries with your Game-Changing App
Using the Mobile SDK, create a customized mobile app to unlock the full potential of your DJI aerial platform.
Learn More
Buy Inspire 1 Pro or Raw
Get Professional. Get Vertical. Get the Inspire 1 Pro and RAW.
