inspire 1
CREATIVITY UNLEASHED
Aircraft
ModelT600
Weight6.27 lbs (2845 g, including propellers and battery, without gimbal and camera)
6.74 lbs (3060 g, including propellers, battery and Zenmuse X3)
GPS Hovering AccuracyVertical: ±1.64 feet (0.5 m)
Horizontal: ±8.20 feet (2.5 m)
Max Angular VelocityPitch: 300°/s
Yaw: 150°/s
Max Tilt Angle35°
Max Ascent Speed16.4 ft/s (5 m/s)
Max Descent Speed13.1 ft/s (4 m/s)
Max Speed49 mph or 79 kph (ATTI mode, no wind)
Max Takeoff Sea Level1.55 mi (2500 m)
2.8 mi (4500 m with specially-designed propeller)
Max Flight TimeApprox. 18 min
Motor ModelDJI 3510H
Propeller ModelDJI 1345T
Indoor HoveringEnabled by default
Operating Temperature14° to 104° F (-10° to 40° C)
Diagonal Distance(propeller excluded)22.8 inch (581 mm, Landing Mode)
Max Takeoff Weight7.71 lbs(3500 g)
Remote Controller
ModelGL658A
Operating Frequency922.7-927.7 MHz (Japan Only)
5.725-5.825 GHz
2.400-2.483 GHz
Max Transmitting Distance(unobstructed, free of interference)Up to 5 km or 3.1 miles when FCC compliant
Up to 3.5 km or 2.1 miles when CE compliant
Up to 2 km or 1.2 miles when MIC compliant
EIRP10dBm@900m, 13dBm@5.8G, 20dBm@2.4G
Video Output PortsUSB, mini-HDMI
Power SupplyBuilt-in battery
ChargingDJI charger
Dual User CapabilityHost-and-Slave connection
Mobile Device HolderTablet or Smart Phone
Max Mobile Device Width170mm
Output Power9 W
Storage TemperatureLess than 3 months: -4° to 113° F (-20° to 45° C)
More than 3 months: 72° to 82° F (22° to 28° C)
Charging Temperature32° to 104° F (0° to 40° C)
Battery6000mAh 2S LiPo
Charger
ModelA14-100P1A
Voltage26.3 V
Rated Power100 W
Battery (Optional)
NameIntelligent Flight Battery
ModelTB48
Capacity5700 mAh
Voltage22.8 V
Battery TypeLiPo 6S
Energy129.96 Wh
Net Weight670 g
Operating Temperature Range14° to 104° F (-10° to 40° C)
Storage Temperature RangeLess than 3 months: -4° to 113° F (-20° to 45° C)
Charging Temperature Range32° to 104° F (0° to 40° C)
Max Charging Power180 W
APP
NameDJI GO
Mobile Device System RequirementsiOS 8.0 or later, Android 4.1.2 or later
Supported Mobile DevicesiOS: iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPod touch 6, iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular.
This app is optimized for iPhone 7 and iPhone 7 Plus.
Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD.
Gimbal
ModelZENMUSE X3
ZENMUSE X5(optional)
ZENMUSE X5R(optional)
ZENMUSE XT(optional)
ZENMUSE Z3(optional)
Angular Vibration Range±0.03°
Interface TypeDetachable
Pan: ±320°
Mechanical RangePitch: -125° to +45°
Pan: ±330°
Max Controllable SpeedPitch: 120°/s
Pan: 180°/s
Camera
NameX3
ModelFC350
Total Pixels12.76M
Effective Pixels12.4M
Image Max Size4000x3000
ISO Range100-3200 (video)
100-1600 (photo)
Electronic Shutter Speed8s - 1/8000s
FOV (Field of View)94°
CMOS1/2.3” CMOS
Lens20mm (35mm format equivalent)f/2.8 focus at ∞
9 Elements in 9 groups
Anti-distortion
Still Photography ModesSingle shoot
Burst shooting: 3/5/7 frames
Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7EV Bias
Time-lapse
Video Recording ModesUHD (4K): 4096x2160p24/25, 3840x2160p24/25/30
FHD: 1920x1080p24/25/30/48/50/60
HD: 1280x720p24/25/30/48/50/60
Max Bitrate of Video Storage60 Mbps
Supported File FormatsFAT32/exFAT
Photo: JPEG, DNG
Video: MP4/MOV (MPEG-4 AVC/H.264)
Supported SD Card TypesMicro SD
Max capacity: 64 GB. Class 10 or UHS-1 rating required.
Operating Temperature Range0° to 40° C
Battery (Standard)
ModelTB47
Capacity4500 mAh
Voltage22.2 V
Battery TypeLiPo 6S
Energy99.9 Wh
Net Weight570 g
Downward Vision System
Velocity Range<26.2 ft/s (8 m/s) at height of 6.56 feet (2 m)
Altitude Range5-500 cm
Operating EnvironmentSurfaces with clear patterns and adequate lighting (> 15 lux)
Operating Range<9.8 feet (3 m)
Ultrasonic Sensor Operating Range0.17-16.4 feet (5-500 cm)
Ultrasonic Sensor Operating EnvironmentNon-absorbing material, rigid surface (thick indoor carpeting will reduce performance)
imovieThe Inspire 1has been certified by Apple in their Works with iMovie and Works with Final Cut Pro X programs, so you can edit 4K without worry whether you are a professional or shooting for fun.
hdmi
Tutorials
How to link the Remote Controller
2016-09-30
How to set master and slave RC
2015-12-24
Inspire 1 Tutorials - Upgrading Firmware on the Inspire 1
2015-12-18
Showcase
DJI Inspire 1 – “Soar”
2014-11-12
Introducing the Inspire 1
2014-11-12
DJI Inspire 1 – “Vintage”
2014-11-12
Firmware
  • Inspire 1 Firmware v01.11.01.50 (X3)
    2017-07-10
  • How to Update Firmware v1.4
    2015-10-22
Software & Drivers
  • Dlog to sRGB 3DLUT
    2016-05-12
  • Dlog to sRGB 3DLUT User Instruction
    2016-05-12
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v1.0.0
    2015-12-07
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v0.9.2
    2015-10-20
  • DJI DNG Cleaner v1.1
    2015-04-10
  • Charging Hub Upgrader v1.1
    2015-09-09
  • Inspire 1/Phantom 3/ X5 Transcoding Tool v0.9.2
    2015-10-20
    2015-04-10
APP / LIVE VIEW
    iOS Version v3.1.22.
    Android Version v3.1.22.
    Requires Android 4.1.2 or later.Compatible with LG V20, VIVO X9, OPPO R11, Google Pixel, Nexus 6P, Huawei P9, Huawei MATE 9, Samsung Galaxy Tab S2, Samsung Galaxy S5, Samsung Galaxy S6 Edge, Samsung Galaxy S6, Samsung Galaxy S7, Samsung Galaxy S7 Edge, Samsung Galaxy S8, Samsung Galaxy S8+, Samsung Galaxy Note 8, Samsung Galaxy Note 5, MI 6, MI5.
Documents & Manuals
  • Inspire 1 Release Notes
    2017-07-10
  • Inspire 1 Safety Guidelines and Disclaimer
    2015-11-18
  • Inspire 1 Quick Start Guide (EN) v2.2
    2016-06-01
  • Inspire 1 Quick Start Guide (DE) v2.0
    2015-12-18
  • Inspire 1 Quick Start Guide (FR) v2.0
    2015-12-18
  • Inspire 1 User Manual (EN) v2.2
    2017-07-12
  • Inspire 1 User Manual (DE) v1.0
    2015-03-20
  • Inspire 1 User Manual (FR) v1.0
    2015-03-19
  • Inspire 1 Safety Guidelines v1.0
    2014-12-31
  • Intelligent Flight Battery Safety Guidelines v1.4
    2016-01-04
  • Charging Hub for Inspire 1 Intelligent Flight Batteries v1.0
    2015-09-01
  • Inspire 1 1345s Quick-Release Propellers Quick Start Guide
    2015-03-26
  • 1345 Propeller Locks Quick Start Guide
    2015-01-23
  • 1345LS Propeller Mounting Plate Kit User Guide
    2017-03-02
  • Inspire 1 Maintenance Manual v1.0
    2015-02-28
  • Inspire 1 In the Box
    2014-12-31
  • Inspire 1 Car Charger User Manual
    2016-06-17
  • *Disclaimer of Warranties:
RC & Video Transmission
Use the DJI GO app to calibrate the remote controller.
Fully charging the Inspire 1 remote controller takes approximately 6 hours. It can be used for approximately 4 hours after being fully charged.
The mount can support an iPad Air or other similar-sized tablet. Tablets should be no more than 170mm wide.
5 km video transmission can be achieved when the display resolution is 720DPI or lower and there is no interference.
The transmitted video usually has a 220ms delay.
As long as the function is activated, the device can transmit video through both ports simultaneously.
The master remote controller and the slave remote controller can maintain a connection at distances up to 50 meters.
No more than 6 slave remote controllers (3 for Japan version) can be connected at the same time. The primary slave remote controller will be able to change the camera settings, as well as the tilt and yaw of the gimbal. The other slave remote controllers can only be used to change the parameters of the camera.
Camera & Gimbal
The Inspire 1’s camera has only a very minimal “fisheye” effect, especially when compared to other flying platforms. Dedicated lens profiles for Adobe products such as Photoshop or After Effects will be released soon. Note: The focal length of the Inspire 1 lens is equivalent to 20mm.
Yes. Just press and hold your finger on the Camera page of the GO app for a few seconds. A circle will appear, which can then be dragged to adjust the orientation of the camera.
4K video generates 450MB per minute. At this rate, a 16GB SD card can hold up to 36 minutes of footage.
In your DJI Pilot app, check whether you are recording in PAL or NTSC format and confirm that it matches the format that is used by your display device. NTSC (60 Hz) is standard in the United States and Japan. PAL (50 Hz) is commonly used in EU countries and in China. Your video may appear blurry if it is not formatted correctly for the display device you are using.
This is completely normal. The cooling fan is built in to protect critical sensors, ensuring that normal temperatures are maintained and the camera can function properly. When the sensor temperature exceeds 30 ℃, the fan is automatically activated. The fan is turned off when the temperature drops below 20 ℃.
Battery
Restrictions for bringing batteries in carry-on luggage may vary across airlines and regions. For accurate information and guidelines, please contact your airline or the regulatory body of your destination.
Press and hold the circular power button for 5 seconds to check the battery life. The Battery Level Indicators will light up and/or blink for 10 seconds. Remaining battery life is also displayed in the DJI Pilot app.
To prevent swelling, the battery automatically discharges to below 65% of its total power capacity if it is not used for more than 10 days. It takes approximately 2 days to discharge a fully charged battery’s power level to 65%. It is normal to feel moderate heat emanating from the battery during this process. Discharge thresholds can be modified using the DJI GO app. To manually discharge the battery, do the following:
Slow: Place the Intelligent Flight Battery into the Inspire 1 battery compartment and turn it on. Leave it on until less than 8% power remains, or until the battery can no longer be turned on. Launch the DJI GO app to check battery levels.
Rapid: Fly the Inspire 1 outdoors until less than 40% of the battery’s capacity remains.
After prolonged use, the internal charge indicator thresholds can become less accurate. Performing a full charge/discharge cycle can re-calibrate the charging parameters and extend the life of the battery.
Using the app
Photos are available when a mobile device is paired with the master remote controller and can be downloaded to the device.
This button is used to save videos to the mobile device. By tapping this button, you can quickly and easily save the most recent 5 seconds of recorded video directly to the mobile device.
The GO app can function without registration when it is being used offline, but registration is required for online use.
Miscellaneous
4K video is recorded at a rate of 30 frames per second, so the lower rate may make it seem like frames are being lost, especially when shooting fast-moving objects. Alternatively, the issue may be related to your display device.
The Inspire 1 boasts an advanced industrial design that allows for a moderate degree of movement at the arm connection point. This serves to reduce vibrations during flight.
Both the Inspire 1 and DJI GO app have the ability to identify compatible, authentic accessories.
If you are able to successfully turn on the Inspire 1, the battery is likely an authentic DJI battery
The DJI GO app will display an alert in the “Overall Status” section if it detects a counterfeit or defective battery
If there is a problem with the battery, the GO app will display an alert when activating the Inspire 1 using the Combination Stick Command
If there is a problem with the battery, the LED indicator on the back of your Inspire 1 will glow solid RED and you will hear a rapid beeping sound
The two remote controllers are physically identical. You can set the remote controllers to either "Master" or "Slave" through the DJI GO app if you wish to use dual controller mode.
Yes.
Its length x height x width dimensions without the propellers attached are 44 x 30 x 45cm (17.3 x 11.8 x 17.7in).
The Inspire 1 uses its own new flight controller.
The Inspire 1 uses 3510H motors and 1345T propellers.
The Inspire 1 comes with a 16GB micro-SD card. It supports SD cards up to 64GB.
The Inspire 1 does not currently support GO Pro attachments. The gimbal is designed to hold DJI cameras only.
The exposure can be set to Auto, for automatic changes, or Manual, if you wish to use a specific setting.
We do not recommend flying with any payload other than the included DJI gimbal and camera.
Yes, you can preview image or video sizes through the DJI GO app.
No, DJI does not sell LCD or HD monitors for the Inspire 1. However, you can output the live streaming video to a compatible monitor or mobile device of your own.
Yes, all Inspire 1 units come with standard TB47 charger.
With the standard TB47 100W charger, it takes 85min to fully charge a 4500mAh battery.
No, it cannot. The mobile device holder can only be used with the Inspire 1 remote.
There is no trainer port on the remote controller for the Inspire 1.
The Inspire 1 does not currently support ground station.
Buy Zenmuse X3
Creativity Unleashed
