Inspire 2
POWER BEYOND IMAGINATION
The Inspire 1 was a revelation. The first filmmaking drone in the world to integrate an HD video transmission system, 360° rotating gimbal and a 4K camera, as well as the simplicity of app control. The launches of the Zenmuse X5 and X5R cameras further cemented the Inspire as a critical tool for filmmakers around the globe.
The Inspire 2 takes everything that was good about the Inspire 1 and improves it. An all-new image processing system records at up to 5.2K in CinemaDNG RAW, Apple ProRes and more. It goes from 0 to 50mph (80kph) in just 5 seconds and hits a maximum speed of 58mph (94kph) and has a max descent speed of 9m/s for unheard of speed and agility in an aircraft this size. A dual battery system prolongs the flight time to a maximum of 27 minutes (with an X4S),while self-heating technology allows it to fly even in low temperatures. FlightAutonomy has been revised and developed specifically for the Inspire 2,providing two directions of obstacle avoidance and sensor redundancy. Increased intelligence adds multiple intelligent flight modes, including Spotlight Pro, giving even single pilots the ability to create complex, dramatic shots. An upgraded video transmission system is now capable of dual signal frequency and dual channel, streaming video from an onboard FPV camera and the main camera simultaneously, for better pilot and camera operator collaboration.
Aircraft
ModelT650
Weight7.58 lbs (3440 g, including propellers and two batteries, without gimbal and camera)
Max Takeoff Weight8.82 lbs (4000 g)
GPS Hovering AccuracyVertical: ±1.64 feet (0.5 m) or ±0.33 feet (0.1 m, Downward Vision System enabled)
Horizontal: ±4.92 feet (1.5 m) or ±0.98 feet (0.3 m, Downward Vision System enabled)
Max Angular VelocityPitch: 300°/s
Yaw: 150°/s
Max Tilt AngleP-mode: 35° (Forward Vision System enabled: 25°)
A-mode: 35°
S-mode: 40°
Max Ascent SpeedP-mode/A-mode: 16.4 ft/s (5 m/s)
S-mode: 19.7 ft/s (6 m/s)
Max Descent SpeedVertical: 13.1 ft/s (4 m/s)
Tilt: 13.1-29.5 ft/s (4-9 m/s)
Max Takeoff Sea Level1.55 mi (2500 m)
3.1 mi (5000 m with specially-designed propeller)
Max Flight TimeApprox. 27 min (with Zenmuse X4S)
Motor ModelDJI 3512
Propeller ModelDJI 1550T
Indoor HoveringEnabled by default
Operating Temperature-4° to 104° F (-20° to 40° C)
Diagonal Distance(propeller excluded)23.8 inch (605 mm, Landing Mode)
Max Speed58 mph or 94 kph(Sport mode)
Remote Controller
ModelGL6D10A
Operating Frequency2.400-2.483 GHz
5.725-5.850 GHz
Max Transmitting Distance(unobstructed, free of interference)2.4 GHz:
FCC: 4.3 miles (7 km);
CE: 2.2 miles (3.5 km);
SRRC: 2.5 miles (4 km);
MIC: 2.5 miles (4 km);
5.8 GHz:
CE: 1.2 miles (2 km);
SRRC: 3.1 miles (5 km);
MIC: - ;
EIRP2.4 GHz:
FCC: 26 dBm;
CE: 17 dBm;
SRRC: 20 dBm;
MIC: 17dBm;
5.8 GHz:
FCC: 28 dBm;
CE:14 dBm;
SRRC: 20 dBm;
MIC: - ;
Video Output PortsUSB, HDMI
Power SupplyBuilt-in battery
ChargingDJI charger
Dual User CapabilityHost-and-Slave connection
Mobile Device HolderTablet or Smart Phone
Max Mobile Device Width170 mm
Output Power9 W (Without supplying power to smart device)
Storage TemperatureLess than 3 months: -4° to 113° F (-20° to 45° C)
More than 3 months: 72° to 82° F (22° to 28° C)
Charging Temperature32° to 104° F (0° to 40° C)
Battery6000mAh 2S LiPo
USB Supply PoweriOS: 1 A @ 5.2 V (Max); Android: 1.5 A @ 5.2 V (Max)
Battery (Standard)
NameIntelligent Flight Battery
ModelTB50
Capacity4280 mAh
Voltage22.8 V
Battery TypeLiPo 6S
Energy97.58 Wh
Net Weight515 g
Charging Temperature41° to 104° F (5° to 40° C)
Max Charging Power180 W
Velocity Range<32.8 ft/s (10 m/s) at height of 6.56 feet (2 m)
Altitude Range<32.8 feet (10 m)
Operating Range<32.8 feet (10 m)
Operating EnvironmentSurfaces with clear patterns and adequate lighting (> 15 lux)
Ultrasonic Sensor Operating Range0.33-16.4 feet (10-500 cm)
Ultrasonic Sensor Operating EnvironmentNon-absorbing material, rigid surface (thick indoor carpeting will reduce performance)
Upward Infrared Sensor
Obstacle Sensing Range0-16.4 feet (0-5 m)
FOV±5°
Operating EnvironmentLarge-size non-reflective obstacles
Gimbal
ModelZENMUSE X4S(optional)
ZENMUSE X5S(optional)
Angular Vibration Range±0.01°
Controllable RangePitch: -130° to+40°
Roll: ±20°
Pan: ±320°
Max Controllable SpeedPitch: 180°/s
Roll: 180°/s
Pan: 270°/s
Interface TypeDetachable
Mechanical RangePitch: -140° to+50°
Roll: -50° to+90°
Pan: ±330°
Charger
ModelIN2C180
Voltage26.1 V
Rated Power180 W
Charging Hub
ModelIN2CH
Input Voltage26.1 V
Input Current6.9 A
Obstacle Sensing Range2.3-98.4 feet (0.7-30 m)
FOVHorizontal: 60°; Vertical: 54°
APP
NameDJI GO 4
Mobile Device System RequirementsiOS 9.0 or later,Android 4.4.0 or later
Intro
The Circle (2016) A Short Film Shot On the Inspire 2
2016-11-15
The Circle (2016): Inspire 2 – A Revolution in Filmmaking
2016-11-15
The Circle (2016) Workflow and Post-Production
2016-11-15
Tutorials
DJI Technologies - CineCore 2.0
2017-05-19
DJI Technologies - Spotlight Pro
2017-05-19
SAMPLE FILES
  • Inspire 2 DNG Sequence
    2016-11-29
  • Inspire 2 PRORES 4444 Sample Video
    2016-11-29
SOFTWARE
    2017-09-18
  • DJI Assistant 2 v1.1.6
    2017-09-07
    2017-09-07
APP / LIVE VIEW
    iOS Version v4.1.5.
    Requires iOS 9.0 or later. Compatible with iPhone 5s, iPhone SE, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4 and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 7, iPhone 7 Plus.
    Android Version v4.1.5.
    Android version 4.4.0 or later. Compatible with Samsung S8 ,Samsung S7 edge, Samsung S7, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Samsung tabs 705c, Ascend Mate 9, Ascend Mate 7, Huawei Honor 8, Huawei P8 Max, Vivo X7, Xiaomi 5, Google Nexus 6p, Nexus 9, Google Nexus 7 II, LG V20.
Documents & Manuals
  • Inspire 2 Release Notes
    2017-06-26
  • Inspire 2 User Manual v1.4
    2017-07-11
  • Inspire 2 Quick Start Guide
    2017-01-04
  • Inspire 2 Safety Guidelines and Disclaimer
    2017-01-19
  • Intelligent Flight Battery Safety Guidelines
    2017-01-20
  • Inspire 2 In the Box
    2016-11-18
  • Inspire 2 DJI Focus Handwheel Remote Controller Stand User Guide
    2017-01-13
  • Inspire 2 GPS Module for the Remote Controller User Guide
    2017-04-06
  • CINESSD Quick Start Guide
    2016-12-02
  • DJI CINESSD Station Quick Start Guide
    2016-12-02
  • Inspire2 Intelligent Flight Battery Charging Hub User Guide
    2016-12-02
  • Inspire 2 License key Purchase and Activation Guide
    2017-02-10
  • DJI Cinema Workflow
    2017-04-20
Aircraft
Max Ascent Speed 6m/s (Sport Mode);
Max Descent Speed: Vertical, 13.1 ft/s (4 m/s); Tilt, 13.1-29.5 ft/s (4-9 m/s)
Default tilt is 13.1 ft/s (4 m/s), can be set in-app.
Max Speed 26m/s, 58 mph (94 kph, flight forward in S-mode).
Up to 25 minutes with Zenmuse X5S. Up to 27 minutes with Zenmuse X4S.
The Inspire 2 currently supports the Zenmuse X4S and Zenmuse X5S.
No. Please purchase your gimbal and camera separately.
Yes. Its Forward Vision System is capable of detecting obstacles up to 30 meters ahead, while the upward facing infrared sensors can sense obstacles within a 5 meter range.
No. You will need to use an Inspire 2 remote with your Inspire 2 aircraft.
Yes. The maximum effective distance between the Master and Slave controllers is 100 meters, and both controllers will receive the same HD live view.
Currently, only the new Zenmuse X4S and Zenmuse X5S are supported.
Yes. Included in the box is a 16GB Micro SD card. It supports SD cards up to 128GB.
Currently supported Micro SD cards are:
Sandisk Extreme 32GB UHS-3 V30 MicroSDHC;
Sandisk Extreme 64GB UHS-3 V30 MicroSDXC;
Panasonic 32GB UHS-3 MicroSDHC;
Panasonic 64GB UHS-3 MicroSDXC;
Samsung PRO 32GB UHS-1 MicroSDHC;
Samsung PRO 64GB UHS-3 MicroSDXC;
Samsung PRO 128GB UHS-3 MicroSDXC;
L:42.7cm x H:31.7cm x W:42.5cm without propellers (landing mode).
The Inspire 2 has 3512 motors and 1550T propellers.
No, please purchase the Highland propellers separately.
Yes. The Inspire 2 uses 3512 motors and 1550T propellers. The max thrust for each rotor reaches up to 2kg.
Thousands of hours have been spent on testing to ensure top safety and reliability.
The Inspire 2 Intelligent Flight Battery has a capacity 97.5Wh. Most airlines allow carrying
batteries below 100 Wh in carry-on luggage. However, as regulations may vary across airlines and regions, please contact your airline or the regulatory body of your destination.
Remote Controller
The new dual-band Lightbridge HD video transmission system has a maximum transmission distance of 7 km*.
The video feed from the FPV camera and main camera (1080p or 720p) can be viewed simultaneously through the
Picture in View feature. The dual-band system consists of 2.4GHz ISM and 5.8GHz ISM**, giving the Inspire 2 stronger
resistance against interference.
*Unobscured, free of interference, FCC compliant.
**In accordance with local law and regulations, 5.8GHz is not available in some countries.
The remote controller is equipped with a 6,000mAh LiPo 2S battery. Fully charging the Inspire 2 remote controller takes approximately 3 hours.
It can be used for approximately 4 hours after being fully charged.
The mount can support an iPad Air or other similar-sized tablet. Tablets should be no more than 170mm tall.
Open the DJI GO 4 app, click the remote controller icon and enter to Settings.
You can choose MODE1, MODE2, MODE3, Custom and more under Stick Mode.
No. The remote controller has a mobile device holder for smartphones and tablets. You can also buy the DJI CrystalSky monitor.
The distance here refers to environments free of obstructions and interference, under FCC compliant specifications.
The Master and Slave remote controllers can maintain a connection at distances up to 100 meters.
There is no training port on the Inspire 2 remote controller.
Below 220ms.
Battery
You will get a 180W Battery Charger and a Battery Charging Hub in the box with your Inspire 2.
When connecting the standard Battery Charger to the Battery Charging Hub, it takes about 90 minutes
to charge 2 batteries and 180 minutes to charge 4 batteries.
The Inspire 2 can take off if the power discrepancy of the two batteries is within 13%. If it is unable to take off,
the DJI GO 4 app will inform you that “the power discrepancy in the two batteries is too large”.
The Inspire 2 continuously checks battery status and will notify you through the DJI GO 4 app if a battery malfunctions.
In this case, please land the aircraft immediately.
By charging and discharging a pair of batteries together you will maximize flight time and battery life.
Please match batteries on the battery interface of DJI GO 4 app.
You will hear the Exit button click to confirm successful mounting of each battery.
Other signs is that the button will have less give when you tap it, and that the batteries will not detach when pulled.
The DJI GO 4 app also will not inform you of errors and show a full status for each battery when properly mounted.
It is recommended that you keep the Intelligent Flight Batteries charged to 50% when storing them.
If storing for a long period of time, we also recommend that you fully discharge them every 3 months.
Cameras
No, you will need to purchase a DJI License Key to enable these formats.
No.
640 x 480px.
Yes. Press and hold the C2 button, and at the same time use the left dial to control the pitch. The roll axis is not controllable.
Other
No. You need to purchase the DJI CINESSD and DJI CINESSD Station card reader separately.
120GB , 240GB and 480GB.
Yes. Many key parts of the Inspire 2 are designed with redundancy, including IMU sensors and barometers.
The Inspire 2 flight controller monitors and analyses the redundancy data in real time, to ensure that flight data is correct.
Yes. During RTH, the Inspire 2 is able to collect information about the environment and automatically plan the best path back home.
Being able to detect obstacles 200m away, it also restores communication faster with the remote controller during RTH after losing signal,
so as to make RTH safe and successful.
To use ActiveTrack, you should keep your Inspire 2 at least 2m above the ground and set the aircraft to P-Mode.
Buy inspire 2
