DJI Lightbridge 2
DJI Lightbridge 2 breaks technical limits to allow you to travel further and see more clearly. The integrated controller and intelligent algorithms set a new standard for wireless HD image transmission by lowering latency and increasing maximum range and reliability.
DJI Lightbridge 2
General
Maximum Transmission DistanceUp to 5 km or 3.1 miles (unobstructed, free of interference) when FCC compliant
Up to 3.5 km or 2.1 miles (unobstructed, free of interference) when CE compliant
EIRP100 mW @ 2.4 GHz
Operating Frequency
  • 920.6 MHz ~ 928 MHz (Japan)
  • 5.725 GHz ~ 5.825 GHz
  • 2.400 GHz ~ 2.483 GHz
Ground System
Dimensions182mm x 167mm x 104mm (L-W-H)
Weight810 g
Antenna Gain3.5 dBi @ 2450 MHz
Built-in Battery7.4 V, 6000 mAh
Operating Current900 mA
Operating Temperature14° to 104° F (-10° to 40° C)
Charging Temperature32° to 104° F (0° to 40° C)
Video Output PortHDMI, SDI, USB
Compatible DJI Product
DJI Gimbal SystemZ15-GH4, Z15-5D III, Z15-A7, Z15-BMPCC
Flight ControllerA3, A2, N3, WooKong-M
Aerial SystemsS1000+, S1000, S900, S800 EVO, F550, F450
Supported Video Outputs
HDMI720p50, 720p60, 1080i50, 1080i60, 1080p24, 1080p30, 1080p50, 1080p60
SDI720p50, 720p60, 1080i50, 1080i60, 1080p24, 1080p30, 1080p50, 1080p60
Air System
Dimensions (without antennas)68mm x 48mm x 21mm (L-W-H)
Weight (without antennas) 70 g
Antenna Gain 2 dBi @ 2450 MHz
Operating Voltage9-12 V
Operating Current650 mA @12 V
Antenna ConnectorMMCX Male
Battery Charger
Output Voltage17.4 V
Rated Power57 W
Supported Video Inputs
AVPAL25, NTSC30
HDMI720p50, 720p60, 1080i50, 1080i60, 1080p25, 1080p30, 1080p50, 1080p60
DJI - Installing DJI Lightbridge 2 and Zenmuse Z15-GH4 (HD)
2015-09-29
DJI - Introducing Lightbridge 2
2015-09-11
Release Notes
  • DJI Lightbridge 2 Release Notes
    2017-04-20
  • DJI Lightbridge 2 User Manual v1.6
    2017-02-17
APP / LIVE VIEW
    iOS Version v3.1.14.
    Android Version v3.1.10.
    Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
SOFTWARE
  • DJI Assistant 2 Release Note
    2017-09-18
  • DJI Assistant 2 v1.1.6
    2017-09-08
    2017-09-08
Lightbridge 2 FAQ
The following enhancements have been made to the DJI Lightbridge 2:
A new SDI output port has been added. The Remote Controller is now integrated into the Ground System, so that you don’t need to buy an additional Remote Controller.
Transmission latency has been reduced to as low as 50ms. Transmission range has been extended to up to 5km. Intelligent, adaptive wireless technology has been added for increased transmission reliability. Picture-in-Picture output support has been added.
The Serial Digital Interface (SDI) is capable of transmitting High Definition digital video via a coaxial cable. Compared to HDMI output, the SDI boasts longer transmission distance and more stable signal. It is the most widely used interface in the Broadcasting and Television industries. The SDI port included with the DJI Lightbridge 2 solves the problem of unstable signal transmission, improves compatibility between devices, and removes the need for extra adapters.
No.The Remote Controller is now integrated into the Ground System. There is no need to buy extra Remote Controllers.
No, the DJI Lightbridge 2 is not compatible with the Inspire 1.
No, the DJI Lightbridge 2 has a brand new algorithm for optimized wireless transmission. It cannot be used with the original DJI Lightbridge.
No, the DJI Lightbridge 2 air system has a working voltage of 3S while that of the DJI Lightbridge is 3S~6S. Please make sure the voltage is set to 3S when the DJI Lightbridge 2 with the cable from the DJI Lightbridge.
The AV input port of DJI Lightbridge 2 air system is also used for power supply, which is different from the previous generation. Make sure to avoid short circuiting this port during installation and use.
50 meters.
The built-in 2S 6000mAh battery gives the Ground System a working time of 4 hours.
The mount can hold an iPad Air or other similar-sized tablet. Tablets should be no more than 170mm wide.
The latest version of the DJI GO app for iOS and Android should be used with the DJI Lightbridge 2.
First, mount the Antenna Extension Cables to the Air System. They will make a clicking sound when successfully installed.
Then, connect the Antenna Extension Cables to the antenna of the Air System and install the Antenna Mounts to the landing gear of the aircraft. For optimal signal performance, adjust the Antenna Mounts to make sure that they are perpendicular to the ground when the landing gear is retracted.
Use cable ties to fix the Antenna Extension Cables.
After finishing setting up the Air System, connect the A2 to your computer and use the A2 Assistant Software to map the channels of the Remote Controller. Map the Return to Home function to channel 6, which corresponds to the Return to Home button.
You can either use USB and HDMI output or USB and SDI output simultaneously. The HDMI and SDI output ports cannot be used at the same time. You can choose the output port configuration in the DJI GO app. The default output port is HDMI.
Please move to a location with less electromagnetic interference and/or choose channels with suitable video transmission quality in the DJI GO app. If the live view is still not clear, you can use “Signal Diagnosis” in DJI GO app to check whether the antenna is functioning normally or not.
The red color displayed by the Air System’s video light signals normal functioning. The video light only shows the working condition of the LB ports (HDMI/AV port) while the condition of the EXT port (Gimbal port) is determined by the gimbal light.
First, make sure you that you have configured the output port to correspond with the monitor.
Then, make sure you choose the correct input port: LB for direct input, EXT for gimbal signal and PIP_LB/PIP_EXT for PIP dual video input.
If the configuration of the app is correct, please check that the settings of the camera and ensure that the gimbal cable is not loose or broken.
Reboot both devices and link them again. Please ensure that the linking process is being performed in an environment with low interference.
Select “Low Latency” in the DJI GO app and ensure that there is no strong interference nearby. Alternatively, manually adjust to a channel without interference and choose the suitable video transmission quality.
First, make sure that the aircraft is flying in an environment with relatively low interference or adjust to a channel without interference and choose the suitable video transmission quality (in the DJI GO app).
If the loss of signal continues, you can use “Signal Diagnosis” in DJI GO app to check whether the antenna is functioning normally or not.
mobile
Revolutionize Industries with your Game-Changing App
Using the Mobile SDK, create a customized mobile app to unlock the full potential of your DJI aerial platform.
Learn More
BUY LIGHTBRIDGE 2
Wireless HD image transmission from above.
