MATRICE 600PRO
SIMPLY PROFESSIONAL PERFORMANCE
The Matrice 600 Pro (M600 Pro) inherits everything from the M600 with improved flight performance and better loading capacity.Pre-installed arms and antennas reduce time required for setup, and the system’s modular design makes it easy to mount additional modules.The airframe is equipped with the latest DJI technologies, including the A3 Pro flight controller, Lightbridge 2 HD transmission system, Intelligent Batteries and Battery Management system. All Zenmuse cameras and gimbals are natively compatible and full integration with third party software and hardware make the M600 Pro ideal for professional aerial photography and industrial applications.
Aircraft
Diagonal Wheelbase1133 mm
Dimensions1668 mm × 1518 mm × 727 mm with propellers, frame arms and GPS mount unfolded (including landing gear)
437 mm × 402 mm × 553 mm with propellers, frame arms and GPS mount folded (excluding landing gear)
Package Dimensions525 mm × 480 mm × 640 mm
Weight (with six TB47S batteries)9.5 kg
Weight (with six TB48S batteries)10 kg
Max Takeoff Weight Recommended15.5 kg
Hovering Accuracy (P-GPS)Vertical: ±0.5 m, Horizontal: ±1.5 m
Max Angular VelocityPitch: 300°/s, Yaw: 150°/s
Max Pitch Angle25°
Max Wind Resistance8 m/s
Max Ascent Speed5 m/s
Max Descent Speed3 m/s
Max Service Ceiling Above Sea Level
  • 2170R propellers: 2500 m;
  • 2195 propellers: 4500 m
Max Speed40 mph / 65 kph (no wind)
Hovering Time* (with six TB47S batteries)No payload: 32 min, 6 kg payload: 16 min
Hovering Time* (with six TB48S batteries)No payload: 38 min, 5.5 kg payload: 18 min
Supported DJI GimbalsRonin-MX; Zenmuse Z30, Zenmuse X5/X5R, Zenmuse X3, Zenmuse XT; Zenmuse Z15 Series HD Gimbal: Z15-A7, Z15-BMPCC, Z15-5D III, Z15-GH4
Flight Control SystemA3 Pro
Propulsion System
  • Motor model: DJI 6010
  • Propeller model: DJI 2170R
Retractable Landing GearStandard
Operating Temperature14° Fto 104° F (-10° C to 40° C)
Charger (Model: MC6S600)
Voltage Output26.1 V
Rated Power600 W
Single Battery Port Output Power100 W
Optional Battery (Model: TB48S)
Capacity5700 mAh
Voltage22.8 V
Battery TypeLiPo 6S
Energy129.96 Wh
Net Weight680 g
Operating Temperature14°F to 104° F (-10°C to 40° C)
Max Charging Power180 W
Remote Controller
Operating Frequency920.6 MHz to 928 MHz (Japan); 5.725 GHz to 5.825 GHz; 2.400 GHz to 2.483 GHz
Max Transmission DistanceFCC Compliant: 3.1 mi (5 km), CE Compliant: 2.2 mi (3.5 km) (Unobstructed, free of interference)
Transmitter Power (EIRP)10 dBm @ 900M, 13 dBm @ 5.8G, 20 dBm @ 2.4G
Video Output PortHDMI, SDI, USB
Operating Temperature14°F to 104° F (-10° to 40° C)
Battery6000 mAh LiPo 2S
Standard Battery (Model: TB47S)
Capacity4500 mAh
Voltage22.2 V
Battery TypeLiPo 6S
Energy99.9 Wh
Net Weight595 g
Operating Temperature14° F to 104° F (-10°C to 40° C)
DJI - M600 - First Flight
2017-04-18
Documents & Manuals
  • M600 Pro Release Notes
    2017-08-16
  • M600 Pro User Manual v1.0
    2017-07-17
  • M600 Pro Quick Start Guide v1.0
    2017-06-20
  • M600 Pro Disclaimer and Safety Guidelines v1.4
    2017-07-07
  • M600 Pro In the Box
    2017-06-20
  • M600 Series Intelligent Flight Battery Safety Guidelines v1.0
    2016-11-09
  • M600 Battery Travel Case v1.0
    2016-10-14
  • DJI Hex Charger v1.2
    2016-12-08
  • Matrice 600 Maintenance Manual v1.0
    2016-06-22
  • M600 Series Remote Controller Channel Expansion Kit User Guide v1.0
    2017-02-16
Camera Firmware
  • Zenmuse Z3 Firmware for Matrice 600 Series
    2016-11-10
  • Zenmuse X5R Firmware for Matrice 600 Series
    2017-01-03
  • Zenmuse X5 Firmware for Matrice 600 Series
    2017-01-03
  • Zenmuse X3 Firmware for Matrice 600 Series
    2017-01-03
  • Zenmuse XT Firmware for Matrice 600 Series
    2016-06-02
  • Zenmuse Z30 Firmware
    2017-06-22
SOFTWARE
    2017-09-18
  • DJI Assistant 2 v.1.1.6
    2017-06-19
    2017-09-07
  • Be sure to unplug the gimbal attitude cable before camera firmware update using the Matrice 600 Pro, or else firmware update will fail.
    * Disclaimer of Warranties:
Model M600 M600 PRO
AIRCRAFT Weight (no-load operation with six TB47S batteries) 9.1Kg 9.5Kg
Weight (no-load operation with six TB48S batteries) 9613g 9960g
Max Take-off Weight 15.1kg 15.5kg
Flight Controller A3 A3 PRO
Dampening system none Dampening balls at the bottom of IMU units and A3 main controller
Max Flight Time (no-load operation with six TB47S batteries) 35mins 32mins
Max Flight Time (no-load operation with six TB48S batteries) 40mins 38mins
Flight Time (with load of 6Kg and six TB47S batteries) 16mins 16mins
Flight Time (with load of 5.5Kg and six TB48S batteries) 18mins 18mins
Propeller Model DJI 2170 DJI 2170R
Transportation Transportation Mode Unpackaged Packaged
Transportation Dimensions (folded) 640*582*623mm(Without box) 520*480*640 mm(In box)
Charger Model Charging Hub(A14-100P1A) M600 Pro charger with Charging Hub(MC6S600)
Voltage 26.1V 26.1V
Rated Power 100W 600W
No. When connecting to DJI Assistant 2, the aircraft will recognize the correct firmware and update it accordingly.
They can be used on the M600 but not the S1000+. If redundant IMUs on the M600 use vibration damping balls, then vibration damping balls should also be added to the A3 Flight Controller, ensuring performance is not compromised.
The M600 Pro is equipped with a new 2170R propeller that increases overall efficiency and stability during flight. It is also equipped with the A3 Pro flight controller, enhancing precision control while improving overall safety. Vibration damping balls have been added to the A3 flight controller’s redundant IMUs, absorbing more shake and reducing more noise.
No. When folded,The M600 Pro is smaller in size than the M600.
Yes.
Yes.
DJI GO will state ‘IMU data error’ when barometers are normal but are at risk of being disturbed by airflow (likely when the aircraft is maneuvering or braking at speed). The ‘IMU data error’ warning will stop when the risk of airflow disturbance lowers.
Yes, they both use the same controllers and batteries.
Please connect the M600 Pro to DJI GO and choose ‘unlock landing gear’ to resolve the issue.
No.
No. However, the M600 Pro’s battery is compatible with the Inspire 1’s battery heater and insulation sticker, which is designed to keep the battery within the temperature range.
Buy MATRICE 600 Pro
Simply Professional Performance
