MavicPRO
Platinum
The Mavic Pro Platinum features a sleek design and compact body that is both powerful and alluring. A new and improved 30-minute flight time coupled with 60% noise power reduction makes the Mavic Pro Platinum DJI’s best portable drone yet.
Aircraft
FoldedH83mm x W83mm x L198mm
Diagonal Size (Propellers Excluded)335 mm
Weight (Battery & Propellers Included)1.62 lbs (734 g) (exclude gimbal cover)
1.64 lbs (743 g) (include gimbal cover)
Max Ascent Speed16.4 ft/s (5 m/s) in Sport mode
Max Descent Speed9.8 ft/s (3 m/s)
Max Speed40 mph (65 kph) in Sport mode without wind
Max Service Ceiling Above Sea Level16404 feet (5000 m)
Max Flight Time30 minutes (no wind at a consistent 15.5 mph (25 kph))
Max Hovering Time27 minutes (no wind)
ESC(Electronic Speed Controller)FOC
Max Total Travel Distance (One Full Battery, No Wind)9.3 mi (15 km, no wind)
Operating Temperature Range32° to 104° F (0° to 40° C)
Satellite Positioning SystemsGPS / GLONASS
Hover Accuracy RangeVertical:
+/- 0.1 m (when Vision Positioning is active) or +/-0.5 m
Horizontal:
+/- 0.3 m (when Vision Positioning is active) or +/-1.5 m
Operating FrequencyFCC:
2.4-2.4835GHz; 5.150-5.250 GHz; 5.725-5.850 GHz
CE:
2.4-2.4835GHz; 5.725-5.850 GHz
SRRC:
2.4-2.4835 GHz;5.725-5.850 GHz
Transmitter Power (EIRP)2.4GHz
FCC:<=26 dBm; CE: <=20 dBm; SRRC:<=20 dBm; MIC:<=18 dBm
5.2 GHz
FCC:<=23 dBm
5.8 GHz
FCC:<=23 dBm; CE <=13 dBm; SRRC: <=23 dBm; MIC: -
Remote Controller
Operating Frequency2.4 GHz to 2.483 GHz
Max Transmission DistanceFCC Compliant: 4.3 mi (7 km);
CE Compliant: 2.5 mi (4 km)
SRRC Compliant: 2.5mi (4 km)
MIC Compliant: 2.5 mi (4 km) (Unobstructed, free of interference)
Operating Temperature Range32° to 104° F ( 0° to 40° C )
Battery2970mAh
Transmitter Power (EIRP)FCC:<=26 dBm
CE:<=20 dBm
SRRC: <=20 dBm
MIC: <=18 dBm
Operating Current/Voltage950mA @ 3.7V
Supported Mobile Device SizeThickness Supported:6.5-8.5mm
Max length: 160mm
Supported USB port types: Lightning, Micro USB(Type-B),USB(Type-C)™
Gimbal
Roll: 0° or 90° (Horizontally and vertically)
Vision System
Vision SystemForward Vision System
Downward Vision System
Obstacle Sensory RangePrecision measurement range: 2 ft (0.7 m) to 49 ft (15 m) Detectable range: 49 ft (15 m) to 98 ft (30 m)
Operating EnvironmentSurface with clear pattern and adequate lighting (lux > 15)
Velocity Range≤22.4 mph (36 kph) at 6.6 ft (2 m) above ground
Altitude Range1 - 43 feet (0.3 - 13 m)
Operating Range1 - 43 feet (0.3 - 13 m)
App / Live View
Mobile AppDJI GO 4
Live View Quality720p@30fps, 1080p@30fps(Remote Controller)
720p@30fps(Wi-Fi)
720p@60fps, 1080p@30fps(DJI Goggles)
Latency160-170ms (depending on conditions and mobile device)
Required Operating Systems
  • iOS 9.0 or later
  • Android 4.1.2 or later
Camera
Sensor1/2.3” (CMOS), Effective pixels:12.35 M (Total pixels:12.71M)
LensFOV 78.8° 28 mm (35 mm format equivalent) f/2.2
Distortion < 1.5% Focus from 0.5 m to ∞
ISO Rangevideo: 100-3200
photo: 100-1600
Electronic Shutter Speed8s -1/8000 s
Image Size4000×3000
Burst shooting: 3/5/7 frames
Interval
Video Recording ModesC4K: 4096×2160 24p
4K: 3840×2160 24/25/30p
2.7K: 2720x1530 24/25/30p
FHD: 1920×1080 24/25/30/48/50/60/96p
HD: 1280×720 24/25/30/48/50/60/120p
Max Video Bitrate60 Mbps
Supported File SystemsFAT32 ( ≤ 32 GB ); exFAT ( > 32 GB )
PhotoJPEG, DNG
Supported SD CardsMicro SD™
Max capacity: 64 GB. Class 10 or UHS-1 rating required
Wi-Fi
Operating Frequency2.4G/5G
Max Transmission Distance80 m(Distance), 50m(Height) (Unobstructed, free of interference)
Max Speed14 km/h (9 mph)
Max Ascent Speed6.6 ft/s(2 m/s)
Max Descent Speed3.3 ft/s(1 m/s)
Charger
Voltage13.05 V
Rated Power50 W
Intelligent Flight Battery
Capacity3830 mAh
Voltage11.4 V
Battery TypeLiPo 3S
Energy43.6 Wh
Net WeightApprox.0.5 lbs(240 g)
Charging Temperature Range41° to 104° F ( 5° to 40° C )
Documents & Manuals
  • Mavic Pro Release Notes
    2017-09-19
  • Mavic Pro User Manual V1.8
    2017-09-01
  • Mavic Pro User Manual V1.2 (CS)
    2017-01-03
  • Mavic Pro User Manual V1.6 (PT)
    2017-06-30
  • Mavic Pro User Manual V1.6 (IT)
    2017-06-30
  • Mavic Pro User Manual V1.6 (NL)
    2017-06-30
  • Mavic Pro Quick Start Guide v1.6
    2017-09-01
  • Mavic Pro Disclaimer and Safety Guidelines v1.0
    2017-08-09
  • Mavic Pro In the Box
    2017-09-01
  • Mavic Pro Intelligent Flight Battery Safety Guidelines v1.0
    2017-01-17
  • Mavic Battery Charging Hub User Guide
    2016-11-08
  • Mavic Propeller Cage User Guide v1.2
    2017-08-22
SOFTWARE
    2017-06-19
  • DJI Assistant 2 v1.1.6
    2017-09-07
    2017-09-07
There are three main differences. The Mavic Pro Platinum has an extended flight time of 30 minutes and an increased hover time of 27 minutes. It also has 4dB (60% noise power) aircraft noise reduction. Finally, the aircraft comes in a sleek platinum finish.
Yes, you can.
Yes, it will.
