Agras
MG-1
Aircraft Frame
Diagonal Wheelbase1520 mm
Frame Arm Length625 mm
Dimensions
  • 1471mm x 1471mm x 482mm (arm unfolded, without propellers)
  • 780mm x 780mm x 482mm (arm folded)
Propulsion System
Motor
Stator Size60mm x 10 mm
KV130 rpm/V
Max Thrust5.1 kg/rotor
Max Power770 W
Weight (with cooling fan)280 g
Foldable Propeller
MaterialHigh-performance engineered plastics
Diameter / Pitch21x7.0 inch (533x178 mm)
Weight58 g
ESC
Max Allowable Current (Continuous)25 A
Operating Voltage12S LiPo
Signal Frequency30 to 450 Hz
Drive PWM Frequency12 kHz
Spray System
Liquid Tank
Volume10 L
Standard Operating Payload10 kg
Max Battery Size151mm x 195mm x 70mm
Nozzle
ModelXR11001
Quantity4
Max Spray Speed0.43 L/min (per nozzle, for water)
Spray Width4 - 6 m (4 nozzles, 1.5 – 3 m above the crops)
Droplet Size*XR11001: 130~250 μm
*Droplet size may vary according to operation environment and spraying speed.
Flight Parameters
Features
Total Weight (without batteries)8.8 kg
Standard Takeoff Weight22.5 kg
Max Takeoff Weight24.5 kg (@ sea level)
Max Thrust-Weight Ratio1.81 (with 22.5 kg takeoff weight)
Power BatteryDJI Designated Battery (MG-12000)
Max Power Consumption6400 W
Hovering Power Consumption3250 W (with 22.5 kg takeoff weight)
Hovering Time
  • 24 min (@ with 12.5 kg takeoff weight)
  • 10 min (@ with 22.5 kg takeoff weight)
Max Operating Speed8 m/s
Max Flying Speed22 m/s
Recommended Operating Temperature0 to 40℃
Remote Controller
Features
ModelGL690B(Japan Only), GL658C
Max Transmission Range (unobstructed, free of interference)1km
EIRP100 mW @ 2.4 GHz
Built-in Battery6000 mAh, 2S LiPo
ChargingDJI charger
Output Power9 W
Operating Temperature Range-10 to 40℃
Storage Temperature Range
  • Less than 3 months: -20 to 45℃
  • More than 3 months: 22 to 28℃
Charge Temperature Range0 to 40℃
Remote Controller Charger
Features
ModelA14-057N1A
Voltage17.4 V
Rated Power57 W
DJI MG-1S - Agricultural Wonder Drone
2017-03-21
Documents & Manuals
  • AGRAS MG-1 Product Release Notes
    2016-09-21
  • AGRAS MG-1 User Manual
    2016-07-05
  • AGRAS MG-1 Quick Start Guide v1.2
    2016-06-14
  • AGRAS MG-1 In the Box
    2016-06-14
  • AGRAS MG-1 Disclaimer and Safety Guidelines v1.2
    2016-06-14
Software & Driver
  • AGRAS MG-1 Assistant Software v1.8 (For Flight Controller)
    2016-07-05
  • DJI Assistant 2 Software v.1.1.0 (LightBridge 2 and IOSD)
    2017-03-02
  • DJI Windows Driver
    2016-04-01
    2017-03-02
  • DJI AGRAS MG-1 Release Notes
    2016-11-07
