Agras MG-1S
The Agras MG-1S integrates a number of cutting-edge DJI technologies, including the new A3 Flight Controller, and a Radar Sensing System that provides additional reliability during flight. The spraying system and flow sensor ensure accurate operations. When used with the MG Intelligent Operation Planning System and the DJI Agriculture Management Platform, a user can plan operations, manage flights in real-time, and closely monitor aircraft operating status. The MG-1S is a high performance aircraft capable of offering comprehensive solutions for agricultural care.
AIRCRAFT FRAME
Diagonal Wheelbase1515 mm
Frame Arm Length625 mm
1471 mm×1471 mm×482 mm(arm unfolded, without propellers)
Dimensions1471 mm×1471 mm×482 mm(arm unfolded, without propellers)
780 mm×780 mm×482 mm(arm folded)
SPRAY SYSTEM
LIQUID TANK
Volume10 L
Standard Operating Payload10 kg
Max Battery Size151 mm×195 mm×70 mm
NOZZLE
ModelXR11001VS(0.379L/min)
Recommend ModelXR110015VS(0.591L/min)
TK-VK6 (0.393L/min)
TK-VK8(0.525L/min)
Quantity4
Droplet SizeXR11001VS:130 - 250 μm(subject to working environment and spraying speed)
FLIGHT PARAMETERS
Total Weight10 kg (without battery)
Standard Takeoff Weight23.8 kg
Max Takeoff Weight24.8 kg (at sea level)
Max Thrust-Weight Ratio1.71 (with 23.8 kg takeoff weight)
Power BatteryDJI Designated Battery (MG-12000S)
Max Power Consumption6400 W
Hovering Power Consumption3800 W(@with 23.8 kg takeoff weight)
Hovering Time*22 min(@12000 mAh & 13.8 kg takeoff weight)
10 min(@12000 mAh & 23.8 kg takeoff weight)
*Hovering time acquired at sea level, with wind speeds lower than 3m/s.
Max Operating Speed7 m/s
Max Flying Speed12 m/s(P & F Mode,with GPS);15 m/s (A Mode)
Max Service Ceiling Above Sea Level2000 m
Recommended Operating Temperature0 ℃ to 40 ℃
REMOTE CONTROLLER
ModelDLG60A
Operating Frequency2.400 GHz to 2.483 GHz
Max Transmission Range 1 km (unobstructed, free of interference)
EIRP≤20 dBm
Built-in Battery9000 mAh,2S LiPo
Output Power7 W
Operating Temperature Range-10 ℃ to 40 ℃
Storage Temperature RangeLess than 3 months: -20 to 45℃
More than 3 months: 22 to 28℃
Charge Temperature Range5 ℃ to 40 ℃
RADAR MODULE
Detection Range1- 5 m
Working Range1.5 - 3.5 m
Precision< 10 cm
PEMOTE CONTROLLER CHARGER
ModelA14-057N1A
Voltage17.4 V
Rated Power57 W
PROPULSION SYSTEM
MOTOR
Stator Size60×10 mm
KV130 rpm/V
Max Thrust5.1 kg/rotor
Max Power770 W
Weight280g (with cooling fan)
FOLDABLE PROPELLER
MaterialHigh-performance engineered plastics
Diameter/Pitch21×7 inch
Weight58 g
ESC
Max Allowable Current (Continuous)25 A
Operating Voltage50.4 V(12S LiPo)
Drive PWM Frequency12 kHz
DJI MG-1S - Agricultural Wonder Drone
2017-03-21
DOCUMENTS & MANUALS
  • AGRAS MG-1S Product Release Notes
    2017-10-11
  • AGRAS MG-1S / MG-1S RTK In the Box
    2017-07-17
  • AGRAS MG-1S / MG-1S RTK Quick Start Guide v1.0
    2017-07-17
  • AGRAS MG-1S / MG-1S RTK Disclaimer and Safety Guidelines v1.2
    2017-10-17
  • AGRAS MG-1S / MG-1S RTK User Manual v1.0
    2017-10-17
  • MG Smart Charging Hub User Guide v1.0
    2017-04-13
  • D-RTK Base Station User Guide v1.0
    2017-09-30
  • D-RTK Handheld Mapper User Guide v1.0
    2017-09-30
  • Obstacle Avoidance Radar User Guide v1.0
    2017-07-17
  • Droplet Analyzer User Guide v1.0
    2017-06-28
Product Brochure
  • AGRAS MG-1S Brochure
    2017-07-25
SOFTWARE
    2017-09-18
  • DJI Assistant 2 v1.1.6
    2017-09-07
  • MG Smart Charging Hub Update Kit v2.0
    2017-11-13
    2017-09-07
FIRMWARE
  • Firmware of AGRAS MG-1S Remote Controller V1.3.0.0
    2017-05-16
  • How to Update the Firmware of AGRAS MG-1S Remote Controller
    2017-05-16
  • Firmware of AGRAS MG-1S Remote Controller V1.3.2.0
    2017-07-25
  • Firmware of AGRAS MG-1S Remote Controller V2.1.0.0
    2017-09-01
  • Firmware of AGRAS MG-1S Remote Controller V2.2.0.0
    2017-10-11
