Motion with Zoom
Motion with Zoom
Handle
Dimensions2.4x1.9x6.4 inches
(61.8x48.2x161.5 mm)
Weight (including battery)201 g
Supported Mobile DeviceMax Size: 6.2 (L) x3.1 (W) inches
158.2 (L) x 77.9 (W) mm
Camera
ModelX3 ZOOM / FC350Z
Sensor1/2.3” CMOS
Effective pixels:12.40 M
(Total pixels: 12.76 M)
Lens3.5× Optical Zoom
22 - 77mm Equivalent
F2.8 (Wide) - F5.2 (Tele)
FOV 92° (Wide) - 35° (Tele)
Focus0.5 m to infinity
ISO Range100-3200 (video); 100-1600 (photo)
Electronic Shutter Speed8 s-1/8000 s
(up to 30 s when camera is in M mode)
Max. Image Size4000 x 3000 pixels
Still Photography ModesSingle Shot
Photo Burst Mode: 3/5/7 shots
Auto Exposure Bracketing (AEB):
3/5 bracketed frames @ 0.7 EV bias
Interval
Auto Panorama
Selfie Panorama
9-shot Panorama
Motion Timelapse
Regular Timelapse
Video ResolutionC4K (4096×2160) 24/25p
4K (3840×2160) 24/25/30p
2.7K (2704×1520) 24/25/30p
FHD: 1920×1080 24/25/30/48/50/60/100p
Video Recording ModesAuto; Slow Motion
Max. Video Bitrate60 Mbps
Supported File FormatsFAT32(≤32 GB); exFAT (>32 GB)
Photo FormatsJPEG, DNG(RAW)
Video FormatsMP4/MOV (MPEG-4 AVC/H.264)
Supported SD CardsMicro SD; Max. Capacity: 64 GB;
Class 10 or UHS-1
Operating Temperature32° to 104° F (0° to 40° C)
Audio Output48 KHz; AAC
Intelligent Battery
ModelHB02-542465
TypeLiPo
Capacity1225 mAh
Energy14.1 Wh
Voltage11.55 V
Charging Temperature41° to 104° F (5° to 40°C)
Operating Temperature32° to 104° F (0° to 40°C)
Flexi Microphone
Sensitivity-32 ± 3 dB (0 dB = 1V/Pa)
Frequency Response100 -10000 Hz
Signal-to-Noise Ratio60 dBA
Pin Diameter3.5 mm
Length88 mm
Weight4 g
Gimbal
ModelZenmuse X3 Zoom
Weight268 g
Output Power (with camera)8 W
Angular Vibration Range±0.02°
MountDetachable
Controllable RangeTilt: -35° to +135°
Pan: ±320°
Roll: ±30°
Mechanical RangeTilt: -50° to +140°
Pan: ±330°
Roll: - 50° to +90°
Max Controllable Speed120°/s
Wi-Fi Video Link
Operating Frequency2.412-2.462 GHz; 5.180-5.805 GHz
Max. Transmission Distance2.4G: 82 feet (25 m); 5G: 328 feet (100 m)
Transmitter Power (EIRP)2.4G: 8 dBm; 5G: 12 dBm
Battery Charger
ModelOS1C11
Input100-240 V; 50/60 Hz
Output12.6/13.2 V, 0.8 A
Compatible Device
Microphones (Confirmed)Sennheiser MKE400
Sony ECM DS70P
Rode VideoMic Pro
Rode VideoMicro
Mymyk Smartmyk
DED DV-889
Firmware
  • OSMO+ Firmware v1.5.0.90
    2017-05-17
  • OSMO+ Firmware v1.4.0.70
    2017-01-22
  • OSMO+ Firmware v1.3.0.50
    2016-11-16
  • OSMO+ Firmware v1.2.0.40
    2016-10-20
  • OSMO+ Firmware v1.1.0.30
    2016-09-13
APP / LIVE VIEW
    iOS Version v3.1.10.
    Android Version v3.1.5.
    Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
DOCUMENTS & MANUALS
  • Osmo+ Release Notes
    2017-05-17
  • Osmo+ Quick Start Guide_v1.0
    2017-06-12
  • Osmo+ User Manual_v1.0
    2017-06-12
  • Osmo+ Disclaimer and Safety Guidelines_v1.0
    2016-09-13
  • Osmo+ Intelligent Battery Safety Guidelines_v1.0
    2016-09-13
  • Osmo+ In the Box_v1.0
    2016-09-13
  • Osmo+ User Manual_v1.0 (IT)
    2017-06-12
  • Osmo+ User Manual_v1.0 (PT)
    2017-06-12
  • Osmo+ User Manual_v1.0 (NL)
    2017-06-12
  • * Disclaimer of Warranties:
Camera and Gimbal
The Osmo+ uses a Zenmuse X3 zoom camera offering up to 7x zoom when shooting 1080p HD video. This is made up of a 3.5x optical zoom and 2x lossless digital zoom. The Zenmuse X3 camera on the Osmo uses a 20mm prime lens with a fixed focal length and focus. It provides a 2x lossless digital zoom when taking 1080p videos.
Yes. The Osmo+ will automatically focus on where you tap on the screen.
4K video; 12 megapixel photos.
Yes, you can.
Yes.
Others
With the standard Osmo High Capacity Intelligent battery you can shoot up to 100 minutes.
No, because the software and hardware solutions of the two products are different.
0℃ to 40℃ .
Max. controllable range will vary by operating frequency. 2.4G has a maximum range of 82ft (25m) and 5G has a maximum range of 328ft (100m).
Class10 and UHS1 or above.
Yes. As the Osmo+ is heavier, you will need to adjust the balance by turning the tension adjustment knob after mounting the Osmo+ on the Z-Axis.
buy osmo+
Motion with Zoom
