OSMO PRO / RAW
Professional Stability Handheld
Osmo Pro and Raw
Watch Intro Video
Osmo Pro
Handle
Dimensions2.4 x 1.9 x 6.4 inches
(61.8 x 48.2 x 161.5 mm)
Weight (including battery)201 g
Camera
SensorType 4/3 CMOS sensor
LensDJI MFT 15mm f/1.7 ASPH *
Panasonic Lumix 15mm f/1.7 *
Olympus M. ED 12mm f/2.0
Olympus M.Zuiko 17mm f/1.8 *
Olympus M.Zuiko ED 14-42mm f/3.5-5.6 EZ *
(For still photography)
Olympus M.Zuiko 25mm f1.8
Olympus M.Zuiko 45mm f1.8
*Balance ring required
ISO Range100-25600
Electronic Shutter Speed8s -1/8000s
Max Image Size4608x3456
Burst shooting: 3/5/7 frames
Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7EV bias
Interval (5/7/10/20/30s)
Video Resolution4K(4096×2160)24/25p
4K(3840×2160)25/30p
FHD: 1920×1080 24/25/30/48/50/60p
Max Video Bitrate60 Mbps
Supported File SystemsFAT32(<=32 GB);exFAT(> 32 GB)
Photo FormatsJPEG、DNG(RAW)
Video FormatsMP4/MOV(MPEG-4/AVC/H.264F)
Supported SD CardsMicro SD; Max capacity: 64 GB; Class 10 or UHS-1 rating required.
Operating Temperature 32° F to 104° F (0° to 40° C)
Audio Output48 KH; AAC
Intelligent Battery
ModelHB02-542465
TypeLiPo
Capacity1225 mAh
Energy14.1 Wh
Voltage11.55V
Charging Temperature41° F to 104° F (5° to 40° C)
Operating Temperature32° F to 104° F (0° to 40° C)
Gimbal
Weight526 g
Output Power (With Camera)Static: 8 W, Peak: 13 W
Angular Vibration Range±0.02°
MountingDetachable
Controllable RangeTilt: -90°to +30°; Pan: ±320°; Roll: ±40°
Mechanical RangeTilt: -130°to +45°; Pan: ±330°; Roll: ±45°
Wi-Fi Video Link
Operating Frequency2.412-2.462 GHz; 5.180-5.805 GHz
Max. Transmission Distance2.4G: 82 feet (25 m); 5G: 328 feet (100 m)
Transmitter Power(EIRP)2.4G:8 dBm; 5G: 12 dBm
Battery Charger
Model OS1C11
Input100-240V, 50/60Hz
Output12.6/13.2V, 0.8A
Osmo Raw
Handle
Dimensions2.4 x 1.9 x 6.4 inches (61.8 x 48.2 x 161.5 mm)
Camera
ISO Range100-25600
Video Resolution4K (4096×2160)24/25p
4K (3840×2160)25/30p
Max Video Bitrate2.4Gbps (Average: 1.7 Gbps)
Supported File SystemsFAT32 (<=32 GB);exFAT (> 32 GB)
Photo FormatsJPEG, DNG
Video FormatsMP4/MOV(MPEG-4/AVC/H.264F), JPEG-Lossless (RAW)
Supported SD CardsMicro SD: Max capacity: 64 GB; Class 10 or UHS-1 rating required.
SSD: 512 GB (compatible with Zenmuse X5R camera)
Intelligent Battery
ModelHB02-542465
TypeLiPo
Capacity1225 mAh
Energy14.1 Wh
Voltage11.55V
Gimbal
Weight583 g
Output Power (With Camera)Static: 13.5W; Peak: 25W
MountingDetachable
Wi-Fi Video Link
Battery Charger
Model OS1C11
ZENMUSE X5R STRAIGHT-FROM-THE-CAMERA SAMPLE FILES
  • Zenmuse X5R Iceland Raw Footage (55s)
    2016-04-26
  • Zenmuse X5R Straight-from-the-camera DNG Sequence
    2016-03-23
  • Zenmuse X5R Sample Video
    2016-03-23
Software & Drivers
  • X5 LOG mode Transcoding Tool v1.0.0
    2015-12-07
  • X5 LOG mode Transcoding Tool v0.9.2
    2015-10-20
  • DJI Camera Exporter
    2016-03-18
  • DJI Camera Exporter User Manual
    2016-03-18
  • X5 Transcoding Tool v0.9.2
    2015-10-20
  • DJI CineLight
    2016-05-30
  • DJI CineLight Release Note
    2016-05-30
  • DJI CineLight User Manual
    2016-03-24
APP / LIVE VIEW
    iOS Version v3.1.22.
    Android Version v3.1.22.
    Requires Android 4.1.2 or later.Compatible with LG V20, VIVO X9, OPPO R11, Google Pixel, Nexus 6P, Huawei P9, Huawei MATE 9, Samsung Galaxy Tab S2, Samsung Galaxy S5, Samsung Galaxy S6 Edge, Samsung Galaxy S6, Samsung Galaxy S7, Samsung Galaxy S7 Edge, Samsung Galaxy S8, Samsung Galaxy S8+, Samsung Galaxy Note 8, Samsung Galaxy Note 5, MI 6, MI5.
Firmware
  • Osmo RAW Firmware v1.4.0.70
    2017-05-09
  • Osmo Pro Firmware v1.4.0.70
    2017-05-09
  • Osmo RAW Firmware v1.3.0.40
    2016-08-25
  • Osmo Pro Firmware v1.3.0.40
    2016-08-25
  • Osmo Pro & RAW Firmware Upgrade Guide
    2016-04-21
Documents & Manuals
  • Osmo RAW Release Notes
    2017-05-09
  • Osmo Pro Release Notes
    2017-05-09
  • DJI Media Maker Release Note
    2016-04-05
  • DJI Media Maker User Manual V1.2
    2016-04-05
  • OSMO Intelligent Battery Safety Guidelines v1.0
    2015-10-08
  • Osmo External Battery Extender Quick Start Guide v1.0
    2016-05-06
  • Zenmuse X5R SSD Quick Start Guide
    2016-06-03
  • Zenmuse X5R Reader Quick Start Guide
    2016-06-03
  • DJI Focus Handwheel User Guide
    2016-08-06
  • zenmuse x5R User Manual
    2016-04-05
  • Zenmuse x5R in the box
    2016-04-05
  • Zenmuse X5R Disclaimer and Safety Guidelines
    2016-04-05
  • Zenmuse X5 User Manual
    2016-05-23
  • Zenmuse X5 In the Box
    2015-11-10
  • Zenmuse X5 Disclaimer and Safety Guidelines
    2015-09-29
  • Osmo Pro/RAW Wired Video Adapter User Guide v1.0
    2017-06-05
  • * Disclaimer of Warranties:
    *Notice:
    Users of the X5R SSD Reader may encounter data access issues after updating OS X to the latest version (10.11.4). The issue can be resolved in the following ways:
    1.Use a compatible USB 3.0 HUB for OS X 10.11.4 to connect the OS X device and SSD Reader.
    2.Use USB2.0 cable to connect the OS X device and SSD Reader. Noted that the data transfer speed is reduced in this case.
    3.Install OS X 10.10.5, then install and run DJI CineLight.
Battery
The new 4.4V High Capacity Intelligent Battery uses new battery cells (24% higher energy density), increasing shooting time.
Using the new battery, you can shoot for 80 minutes with the Osmo Pro and 34 minutes with the Osmo RAW. This compares to 59 minutes for the Osmo Pro and 25 minutes for the Osmo RAW using the regular battery.
100 minutes using the Osmo Charger; 120 minutes using the Osmo Quad Charger System, which charges up to four High Capacity Intelligent Batteries.
The Osmo High Capacity Intelligent Battery has over charge protection. Charging automatically stops when the battery is fully charged or if errors occur during charging. There is no need remove the battery when fully charged.
25℃.
0℃ -40℃.
System Status Indicator will blink red quickly then the Osmo Pro or RAW will turn off. Video captured will be stored in the SD card as a temporary file. When a charged battery is inserted the file will be restored.
Camera and Gimbal
Both cameras capture 4K video and 16 megapixel photos. The Osmo RAW is capable of capturing video in 4K CinemaDNG RAW.
20cm (with the DJI standard 15mm lens)
No.
Yes. A tripod is required as handheld long exposures are less stable than using the standard Osmo.
0℃ -40℃
Class 10, UHS1 or above.
Accessories
Connect the DJI Focus Handwheel and the X5 Adapter using an Osmo CAN-Bus cable.
The DJI Focus Handwheel can currently only be connected to the Osmo Pro and RAW. It does not feature a wireless transmission function or an air system.
Others
Max. controllable range will vary by operating frequency. 2.4G has a maximum range of 82ft (25m) and 5G has a maximum range of 328ft (100m).
Osmo is the Osmo handheld gimbal with the Zenmuse X3 camera; Osmo Pro is the Osmo handheld gimbal and Zenmuse X5 camera; and Osmo RAW is the Osmo handheld gimbal and Zenmuse X5R camera;
Yes. Handheld gimbals in the Osmo Series are interchangeable, with the exception of the Osmo Mobile. When using either the X5 or X5R camera, adaptors are required and the camera will need to be updated to the latest version.
No, you can only do this through Wi-Fi.
BUY OSMO PRO / RAW
