Aircraft
Weight (Battery & Propellers Included)1216 g
Max Ascent Speed5 m/s
Max Descent Speed3 m/s
Max Speed16 m/s (ATTI mode)
Max Flight TimeApprox. 25 minutes
Satellite Positioning SystemsGPS
Camera
Sensor1/2.3” CMOS
Effective pixels:12 M
LensFOV 94° 20 mm (35 mm format equivalent) f/2.8
ISO Range
  • 100-3200 (video)
  • 100-1600 (photo)
Max Image Size4000×3000
Still Photography Modes
  • Single Shot
  • Burst Shooting: 3/5/7 frames
  • Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7 EV Bias
  • Timelapse
Video Recording Modes
  • 2.7K: 2704 x1520p 24/25/30 (29.97)
  • FHD: 1920x1080p 24/25/30
Max Video Bitrate40 Mbps
PhotoJPEG, DNG (RAW)
Supported SD CardsMicro SD Card 8 GB included
Charger
Voltage17.4 V
Rated Power57 W
App / Live View
Mobile AppDJI GO
EIRP100mW
Live View Working Frequency2.4GHz ISM
Live View Quality720P @ 30fps
LatencyLow Latency Video (depending on conditions and mobile device)
Required Operating Systems
  • iOS 8.0 or later
  • Android 4.1.2 or later
Recommended Devices
  • Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD
Power Spectral Density6.9mW/MHz
Gimbal
Remote Controller
Operating Frequency5.725 - 5.825 GHz, 922.7 - 927.7 MHz (Japan)
Max Transmission Distance FCC: 1000 m
CE: 500 m
(outdoors and unobstructed, aircraft's altitude at 400 feet (120 m))
Battery2600 mAh LiPo 18650
Transmitter Power (EIRP)
  • FCC: 19 dBm
  • CE: 14 dBm
Operating Current/Voltage 600 mA@3.7V
Charging PortMicro USB
Intelligent Flight Battery
Capacity4480 mAh
Voltage15.2 V
Battery TypeLiPo 4S
Energy68 Wh
Net Weight365 g
Operating Temperature Range14° to 104°F (-10° to 40°C)
Max Charging Power100 W
DJI GO – Intelligent Flight Mode: Waypoints
2015-09-08
DJI GO – Intelligent Flight Mode: Course Lock and Home Lock
2015-09-08
DJI GO – Intelligent Flight Mode: Point of Interest
2015-09-08
DJI GO – Intelligent Flight Mode: Follow Me
2015-09-08
Documents & Manuals
  • How to Update the Firmware v1.4
    2015-10-28
  • Phantom 3 Standard Release Notes
    2017-01-11
  • Phantom 3 Standard User Manual (EN) v1.4
    2016-01-12
  • Phantom 3 Standard User Manual (ES) v1.0
    2016-02-05
  • Phantom 3 Standard Quick Start Guide (EN) v1.0
    2016-04-19
  • Phantom 3 Standard Quick Start Guide (IT) v1.0
    2015-11-26
  • Phantom 3 Standard In the Box
    2015-08-05
  • Phantom 3 Intelligent Flight Battery Safety Guidelines v1.0 (EN)
    2015-12-01
  • Charging Hub for Phantom 3 Intelligent Flight Batteries v1.0
    2015-09-01
  • Phantom 3 Prop Guards Installation Guide
    2015-12-17
  • Phantom 3 Safety Guidelines and Disclaimer v1.4
    2016-02-05
  • Car Charger for Phantom 3 User Manual
    2016-06-17
  • Phantom 3 Intelligent Flight Battery Heater User Manual
    2016-06-17
APP / LIVE VIEW
    iOS Version v3.1.2.
    Android Version v3.1.2.
    Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
  • * Disclaimer of Warranties:SZ DJI Technology Co. Ltd. provides the firmware “as is” and “as available” for your use, without warranty of any kind, either express or implied, including all implied warranties of merchantability, and fitness for a particular purpose. You expressly agree that your use of, or inability to use the firmware is at your sole risk. In no case shall SZ DJI Technology Co. Ltd. be liable for any direct, indirect, punitive, special, or consequential damages arising from your use of any of the firmware, including but not limited to, any loss or damage of any kind incurred as a result of your misuse, transmitted, etc.
FAQ
The Phantom 3 Standard is the most streamlined addition to the Phantom 3 series. It connects to the DJI GO app over WiFi and has a 2.7K video camera. The Phantom 3 Professional and Advanced add DJI’s Vision Positioning system, GLONASS in addition to standard GPS, an extended range via DJI Lightbridge, and a remote controller with extended functionality. The Phantom 3 Professional also has a 4K camera. All models use the DJI GO app and the DJI Intelligent Flight Battery and take 12 megapixel photos. Compare the Phantom 3 Series>
The Phantom 3 Standard is a significant upgrade over the Phantom 2 Vision and Vision+ with an enhanced camera, fully integrated remote, compatibility with the DJI GO app, updated flight controller, live HD view, and increased flight range.
The DJI GO app is free to download from the Apple App Store and Google Play. Search for “DJI GO” and download/install the app as usual.
The Phantom 3 Standard connects to the DJI GO app on your mobile device via its own WiFi network. First power on your remote controller and Phantom 3 Standard. Then connect your mobile device to the dedicated “PHANTOM 3_XXXXX” WiFi network, and open the DJI GO app. Details can be found in the user manual.
These switches are called the S1 and S2 switches.
The S1 switch allows you to change between advanced flight modes, including P-Mode, A-Mode, and F-Mode. More information about these modes can be found in the user manual. Beginners should keep this switch in the uppermost position (P-Mode) when flying.
The S2 switch can be used to trigger Return to Home. When flying, simply toggle this switch up and down several times to tell your Phantom 3 Standard to return to the Home Point and land.
No. The camera that comes with the Phantom 3 Standard is permanently attached. Attempting to remove, replace, or modify the camera may damage the product and will void your warranty.
The signal transmission distance will vary depending on environmental conditions and local regulations, but the Phantom 3 Standard can reach distances of up to 0.5 miles (1 kilometer) away from the pilot.
The Phantom 3 Standard is compatible with the DJI Go app for iOS and Android*, which is also used for other DJI products. The app will detect which aircraft is connected and automatically adjust accordingly.
*Android version coming soon.
The DJI GO app is only compatible with devices running iOS 8.0 or later or Android v4.1.2 or later. A full list of suggested deceives can be found on the Phantom 3 Standard webpage at DJI.com.
Director is an automatic video editor built into the DJI GO app. After recording several video clips, simply tap “Library” from the app’s home screen. You can then select your clips and a template, which are automatically combined to create a short film that can be shared immediately.
By default, the remote controller is set to Mode 2. This means that the right control stick controls the movement of the aircraft and the left control stick controls the throttle and orientation of the aircraft. These controls can be changed to Mode 1 or set to a customized configuration in the DJI GO app. This is only recommended for advanced users.
No. The Phantom 3 series uses a newly designed Intelligent Flight Battery with greater power. The Phantom 3 has a 4 cell battery with a capacity of 4480 mAh and a voltage of 15.2 V.
Yes, the Phantom 3 series batteries are the same.
This is normal. After you attempt to power off the Intelligent Flight Battery, it may remain on for a few seconds as any video data is saved to the Micro SD card. This helps prevent your data from being lost or corrupted.
No, there is no need to buy a separate remote controller. Your Phantom 3 Standard comes with a custom-built remote controller that is already linked to the aircraft.
No. The included Remote Controller can be used to control both the aircraft and the gimbal tilt at the same time.
Flight time will vary depending on environmental conditions and usage patterns, but the Intelligent Flight Battery is designed to provide up to 25 minutes of uninterrupted flight time when fully charged.
Do not remove the Micro SD card from the camera. If it has been removed, place it back in the camera. Turn on the Phantom 3 Standard and wait approximately 30 seconds as the video file is restored.
You may need to adjust the settings of your mobile device. Open the Settings menu, select the Privacy tab, select the Photos tab, and then toggle the switch next to the DJI GO app icon. If the GO app has not been granted access to your albums, the photos and videos cannot be synchronized.
Hover the aircraft over a flat, level surface. Slowly pull the throttle stick down until the aircraft touches the ground.
Every Intelligent Flight Battery is tested prior to being packaged and shipped. This affects the discharge time of a new battery and is the reason that the discharge time displayed in the GO app is not zero. The battery is safe to use.
A compass error may occur when the aircraft is flying close to strong electric magnetic sources (e.g. power transmission lines). The Aircraft Status Indicators will blink red and yellow rapidly when a compass error occurs and the DJI GO app will display one of the following messages:
- Compass error, calibration required
This warning message indicates the aircraft is receiving abnormal compass readings. It is recommended that you power off the aircraft and re-calibrate the compass at a different location and then resume the flight.
- Compass error, exit P-GPS Mode
This warning message indicates that the aircraft is drifting severely. Bring the aircraft to a higher altitude to acquire connections with enough GPS satellites when this warning message appears. The flight controller will automatically adjust the orientation of the aircraft in the midair to mitigate the drifts. The aircraft will switch back to P-GPS mode when the automatic adjustment is completed.
mobile
Revolutionize Industries with your Game-Changing App
Using the Mobile SDK, create a customized mobile app to unlock the full potential of your DJI aerial platform.
Learn More
BUY PHANTOM 3 STANDARD
Start reaching for the skies today
