Aircraft
Weight (Battery & Propellers Included)1388 g
Max Ascent SpeedS-mode: 6 m/s
P-mode: 5 m/s
Max Descent SpeedS-mode: 4 m/s
P-mode: 3 m/s
Max SpeedS-mode: 45 mph (72 kph)
A-mode: 36 mph (58 kph)
P-mode: 31 mph (50 kph)
Max Tilt AngleS-mode: 42°
A-mode: 35°
P-mode: 25°
Max Angular SpeedS-mode: 250°/s
A-mode: 150°/s
Max Flight TimeApprox. 30 minutes
Hover Accuracy RangeVertical:
±0.5 m (with GPS Positioning)
Horizontal:
±1.5 m (with GPS Positioning)
Vision System
Vision SystemForward Vision System
Backward Vision System
Downward Vision System
Velocity Range≤31 mph (50 kph) at 6.6 ft (2 m) above ground
Altitude Range0 - 33 feet (0 - 10 m)
Operating Range0 - 33 feet (0 - 10 m)
Obstacle Sensory Range2 - 98 feet (0.7 - 30 m)
FOVForward: 60°(Horizontal), ±27°(Vertical)
Backward: 60°(Horizontal), ±27°(Vertical)
Downward: 70°(Front and Rear), 50°(Left and Right)
Measuring FrequencyForward: 10 Hz
Backward: 10 Hz
Downward: 20 Hz
Camera
Sensor1’’ CMOS
Effective pixels: 20M
LensFOV 84° 8.8 mm/24 mm (35 mm format equivalent) f/2.8 - f/11 auto focus at 1 m - ∞
ISO RangeVideo:
100 - 3200 (Auto)
100 - 6400 (Manual)
Photo:
100 - 3200 (Auto)
100- 12800 (Manual)
Mechanical Shutter Speed8 - 1/2000 s
Image Size3:2 Aspect Ratio: 5472 × 3648
4:3 Aspect Ratio: 4864 × 3648
16:9 Aspect Ratio: 5472 × 3078
PIV Image Size4096×2160
3840×2160
2720×1530
1920×1080
1280×720
Still Photography ModesSingle Shot
Burst Shooting: 3/5/7/10/14 frames
Interval: 2/3/5/7/10/15/20/30/60 s
Video Recording ModesH.265
C4K:4096×2160 24/25/30p @100Mbps
4K:3840×2160 24/25/30p @100Mbps
2.7K:2720×1530 24/25/30p @65Mbps
2.7K:2720×1530 48/50/60p @80Mbps
FHD:1920×1080 24/25/30p @50Mbps
FHD:1920×1080 48/50/60p @65Mbps
FHD:1920×1080 120p @100Mbps
HD:1280×720 24/25/30p @25Mbps
HD:1280×720 48/50/60p @35Mbps
HD:1280×720 120p @60Mbps
H.264
C4K:4096×2160 24/25/30/48/50/60p @100Mbps
4K:3840×2160 24/25/30/48/50/60p @100Mbps
2.7K:2720×1530 24/25/30p @80Mbps
2.7K:2720×1530 48/50/60p @100Mbps
FHD:1920×1080 24/25/30p @60Mbps
FHD:1920×1080 48/50/60 @80Mbps
HD:1280×720 24/25/30p @30Mbps
HD:1280×720 48/50/60p @45Mbps
HD:1280×720 120p @80Mbps
Max Video Bitrate100 Mbps
PhotoJPEG, DNG (RAW), JPEG + DNG
VideoMP4/MOV (AVC/H.264; HEVC/H.265)
Supported SD CardsMicro SD
Max Capacity: 128GB
Write speed ≥15MB/s, Class 10 or UHS-1 rating required
Charger
Voltage17.4 V
Rated Power100 W
App / Live View
Mobile AppDJI GO 4
Live View Working Frequency2.4 GHz ISM, 5.8 GHz ISM
Live View Quality720P @ 30fps
LatencyPhantom 4 Pro: 220 ms (depending on conditions and mobile device)
Phantom 4 Pro +:160 - 180 ms
Required Operating SystemsiOS 9.0 or later
Android 4.4.0 or later
Recommended DevicesiOS:iPhone 5s, iPhone SE, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4 and iPad mini 4 Wi-Fi + Cellular.
This app is optimized for iPhone 7, iPhone 7 Plus.
Android:Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
Gimbal
Angular Control Accuracy±0.02°
Infrared Sensing System
Obstacle Sensory Range0.6 - 23 feet (0.2 - 7 m)
FOV70° (Horizontal), ±10° (Vertical)
Measuring Frequency10 Hz
Operating EnvironmentSurface with diffuse reflection material, and reflectivity > 8% (such as wall, trees, humans, etc.)
Remote Controller
Operating Frequency2.400 - 2.483 GHz and 5.725 - 5.825 GHz
Max Transmission Distance2.400 - 2.483 GHz (Unobstructed, free of interference)
FCC: 4.3 mi (7 km)
CE: 2.2 mi (3.5 km)
SRRC: 2.5 mi (4 km)
5.725 - 5.825 GHz (Unobstructed, free of interference)
FCC: 4.3 mi (7 km)
CE: 1.2 mi (2 km)
SRRC: 3.1 mi (5 km)
Battery6000 mAh LiPo 2S
Transmitter Power (EIRP)2.400 - 2.483 GHz
FCC: 26 dBm
CE: 17 dBm
SRRC: 20 dBm
5.725 - 5.825 GHz
FCC: 28 dBm
CE: 14 dBm
SRRC: 20 dBm
Video Output PortGL300E: HDMI
GL300F: USB
Mobile Device HolderGL300E: Built-in display device (5.5 inch screen, 1920×1080, 1000 cd/m2, Android system, 4 GB RAM+16 GB ROM)
GL300F: Tablets and smart phones
Intelligent Flight Battery
Capacity5870 mAh
Voltage15.2 V
Battery TypeLiPo 4S
Energy89.2 Wh
Net Weight468 g
Max Charging Power100 W
DJI – Introducing Phantom 4 Pro
2016-11-15
DJI – Phantom 4 Pro – Hawaiian Lava
2016-11-15
DJI – Phantom 4 Pro - Sharper Vision
2016-11-15
Documents & Manuals
  • Phantom 4 Pro/Pro+ Release Notes
    2017-01-11
  • Phantom 4 Pro/Pro+ User Manual v1.2
    2017-01-25
  • Phantom 4 Pro Quick Start Guide v1.0
    2017-01-25
  • Phantom 4 Pro+ Quick Start Guide v1.0
    2017-01-25
  • Phantom 4 Pro/Pro+ Disclaimer and Safety Guidelines
    2017-01-25
  • Phantom 4 Pro In the Box
    2017-01-25
  • Phantom 4 Pro+ In the Box
    2017-01-25
  • Phantom 4 Series Intelligent Flight Battery Safety Guidelines v1.0
    2017-01-25
FIRMWARE
  • Phantom 4 Pro+ Remote Controller Firmware v01.01.01.01
    2016-12-09
  • How to Update Phantom 4 Pro+ Remote Controller Firmware
    2016-12-09
APP / LIVE VIEW
    iOS Version v4.0.4.
    Requires iOS 9.0 or later. Compatible with iPhone 5s, iPhone SE, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4 and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 7, iPhone 7 Plus.
    Android Version v4.0.3.
    Android version 4.4.0 or later. Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
Straight-from-the-Phantom-4-Pro
  • Straight-from-the-Phantom-4-Pro
    2016-11-16
SOFTWARE
    2017-01-05
  • DJI Assistant 2 v1.0.9
    2017-01-05
    2017-01-05
PRODUCT
The Phantom 4 Pro redefines the iconic Phantom series, bringing imaging and intelligence to new heights. Its uprated camera shoots 4K/60fps at a bitrate of 100Mbps and stills up to 20-megapixels, creating dramatically better images. The FlightAutonomy system adds dual rear vision sensors and two Time of Flight range imaging cameras for a total of 5 directions of obstacle sensing with a range of up to 30m in all directions. The upgraded Lightbridge HD video transmission system offers an extended maximum transmission range of 4.3mi (7km) and also enables you to switch between 2.4GHz and 5.8GHz. It can also be used with an optional integrated monitor for even more reliable transmission. Operators are also further empowered with a new suite of ActiveTrack and TapFly functions. The aircraft’s Intelligent Flight Battery also have increased capacity by 520mAh to enable an extended flight time of 30 minutes.
Currently supported Micro SD cards are:
Sandisk Extreme 32GB UHS-3 V30 MicroSDHC;
Sandisk Extreme 64GB UHS-3 V30 MicroSDXC;
Panasonic 32GB UHS-3 MicroSDHC;
Panasonic 64GB UHS-3 MicroSDXC;
Samsung PRO 32GB UHS-1 MicroSDHC;
Samsung PRO 64GB UHS-3 MicroSDXC;
Samsung PRO 128GB UHS-3 MicroSDXC;
CAMERA
The Phantom 4 Pro camera is equipped with a 1-inch 20-megapixel sensor and has a manually adjustable aperture from F2.8 to F11. It also supports auto focus by half-pressing the shutter button, and has a focus range, from 1m to infinity. Always refocus before capturing additional shots in the event that the subject has moved beyond the focus point. Focus at infinity if the subject is over 98ft (30m) away. Refocusing is also needed when switching from close shots to long shots during recording.
The Phantom 4 Pro is able to record UHD 4K (4096X2160) at 60fps, at a maximum bitrate of 100Mbps using the H.264 codec and also supports H.265. It also allows you to capture still images while filming. The Phantom 4 Pro camera’s sensor is also larger than before, ensuring clearer images.
Photos will be captured as JPEG in the same resolution as the video recording.
H.265 retains 50% more information than H.264, creating more detailed and vivid images.
An electronic shutter may cause artifacts and distortion, such as jello, when shooting fast moving objects. A mechanical shutter prevents this and guarantees a high-quality image.
Tap a point on the display to focus at that point after switching from metering to focus modes. Auto focus can also be triggered by half-pressing the shutter button, before fully pressing the shutter to capture an image. Focus can be set between 1m and infinity.
The Phantom 4 Pro uses a brand new camera lens optimized for aerial imaging, with an aperture range from F2.8 to F11 and a 24mm equivalent focal length. It’s equipped with a mechanical shutter and adjustable aperture range, with auto focus support.
OBSTACLE SENSING SYSTEM
Only in Beginner mode and Tripod mode
Available in Beginner Mode and Tripod Mode only, the infrared sensing system has a sensing field with a 70° angle horizontally and 20° angle vertically. The radiated infrared light is reflected back by obstacles, allowing the sensors to “see” them at a distance of up to 23ft (7m) by calculating the difference in projection and reflection times and using this information to create a 3D model about the environment and obstacles in it.
Phantom 4 Pro’s maximum front obstacle sensing range has been extended to 98ft (30m), with the rear sensing system sharing the same capability. Additionally, the Phantom 4 Pro is equipped with infrared sensors on both sides of the aircraft, precisely detecting the distance between the aircraft and obstacles within a range of up to 23ft (7m).
No.
REMOTE CONTROLLER
Currently no.
The Phantom 4 Pro is compatible with two types of controllers, standard and optional. both can switch between 2.4GHz and 5.8GHz frequency bands with a maximum controllable range of 4.3mi (7km) (Unobstructed, free of interference, FCC compliant.). Both can focus by half-pressing the shutter release button. The Phantom 4 Pro + has a 5.5-inch 1080p display, with 1000 cd/m2 brightness and built-in DJI GO 4 app. Its remote controller is also equipped with HDMI port, Micro SD slot, microphone, loudspeaker and Wi-Fi connectivity.
No.
No.
Yes.
1920*1080
Popular social media apps and DJI GO 4.
It uses a customized DJI system.
Both.
No. Currently the Phantom 4 Pro + controller does not support downloading additional third party apps.
It supports Wi-Fi but not Bluetooth.
INTELLIGENT FUNCTIONS
AR Route, TapFly Backward, TapFly Free in Tap Fly mode, Circle, Profile, and Spotlight in ActiveTrack, as well as Draw and Gesture Mode. It also supports Narrow Sensing and uses new RTH algorithms.
The new Smart Return Home forms a map of its environment in real-time. The aircraft will choose the best flight path to return home and senses as far as 300m to avoid obstacles more effectively. If the control signal is lost, the Phantom 4 Pro will retrace its original path to regain its connection after 1-minute. When it reconnects, it will return to home following a straight route. If it fails to regain connection, it will also revert to straight line RTH.
Set C1 or C2 as activation switch for Narrow Sensing. When flying in a complex environment, activate Narrow Sensing and the aircraft will adjust its sensing range and flying speed to fly through narrows gaps.
PROPULSION SYSTEM
Yes.
It has the same Sport Mode max speed as the Phantom 4 and faster Obstacle Avoidance enabled flight, achieving 31mph (50kph).
VIDEO TRANSMISSION SYSTEM
The Phantom 4 Pro uses a new dual-signal Lightbridge video transmission system. It has a transmission distance of up to 4.3mi (7km) (Unobstructed, free of interference, FCC compliant). Users can also switch between 2.4GHz and 5.8GHz control frequencies to cut through interference.
BATTERIES and BATTERY CHARGER
Yes.
The battery capacity is 5870mAh. It flies for two additional minutes compared to the Phantom 4.
FIRMWARE UPGRADE
Yes. Always use a battery with more than 50% power when upgrading.
Use DJI GO 4 to upgrade the battery firmware to the appropriate version.
buy phantom 4 pro
VISIONARY INTELLIGENCE. ELEVATED IMAGINATION.
