Aircraft
Weight (including battery and propellers)1280 g
Diagonal Size (Excluding Propellers)350 mm
Max Ascent Speed5 m/s
Max Descent Speed3 m/s
Hover AccuracyVertical:
+/- 0.1 m (when Vision Positioning is active) or +/-0.5 m
Horizontal:
+/- 0.3 m (when Vision Positioning is active) or +/-1.5 m
Max Speed16 m/s (ATTI mode, no wind)
Max Service Ceiling Above Sea Level6000 m (Default altitude limit: 120 m above takeoff point)
Operating Temperature0°C to 40°C
GPS ModeGPS
Max Flight TimeApprox. 25 minutes
Gimbal
Controllable RangePitch -90° to +30°
Remote Controller
Operating Frequency
  • 5.725 GHz – 5.825 GHz
  • 922.7 MHz – 927.7 MHz (Japan)
Max Transmission Distance
  • FCC: 1200m
  • CE: 500m (unobstructed, free of interference, 120m above takeoff point)
Operating Temperature32° to 104° F ( 0° to 40° C )
Battery2600 mAh LiPo18650 2S
Transmitter Power (EIRP)
  • FCC: 19 dBm
  • CE: 14 dBm
Operating Voltage300 mA @7.4 V
Intelligent Flight Battery
Capacity4480 mAh
Voltage15.2 V
Battery TypeLiPo 4S
Energy68 Wh
Net Weight365 g
Max Charging Power100 W
Camera
SensorSony EXMOR 1/2.3" CMOS
LensFOV 94° 20 mm (35 mm format equivalent) f/2.8, focus at ∞
ISO Range
  • 100-3200 (video)
  • 100-1600 (photo)
Shutter Speed8s - 1/8000s
Image Max Size4000×3000
Still Photography Modes
  • Single Shot
  • Burst Shots: 3/5/7 shots
  • Auto Exposure Bracketing (AEB): 3/5 shots
  • Bracket Frames at 0.7EV Bias
  • Time-lapse
Video Recording Modes
  • UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
Supported SD Card Types
  • Micro-SD
  • Max capacity: 64 GB. Class 10 or UHS-1 rating required
Max Video Bitrate60 Mbps
Supported File FormatsFAT32 ( ≤ 32 GB ); exFAT ( > 32 GB )
PhotoJPEG, DNG
Downward Vision System
Velocity RangeLess than 8 m/s (2 m above ground)
Altitude Range30 cm-300 cm
Operating Range50 cm-300 cm
Operating EnvironmentSurface with clear pattern and adequate lighting (Lux > 15)
Charger
Voltage17.4 V
Rated Power57 W
App / Live View
Mobile AppDJI GO
Live View Quality480P @ 30fps
Required Operating Systems
  • iOS 8.0 or later
  • Android 4.1.2 or later
Recommended Devices
  • Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei Mate 8, Nubia Z7 mini, SONY Xperia Z3, MI 3, MI PAD
EIRP100mW
Power Spectral Density6.9mW/MHz
Live View Working Frequency2.4GHz ISM
Latency220ms (depending on conditions and mobile device)
Documents & Manuals
  • How to Update the Firmware v1.4
    2016-01-25
  • Phantom 3 4K Release Note
    2017-06-23
  • Phantom 3 4K User Manual v1.2
    2016-05-23
  • Phantom 3 4K Quick Start Guide v1.0
    2016-01-08
  • Phantom 3 4K In the Box
    2016-01-04
  • Phantom 3 Intelligent Flight Battery Safety Guidelines v1.0
    2016-01-04
  • Phantom 3 Safety Guidelines and Disclaimer
    2016-01-04
  • Car Charger for Phantom 3 User Manual
    2016-06-17
  • Phantom 3 Intelligent Flight Battery Heater User Manual
    2016-06-17
APP / LIVE VIEW
    iOS Version v3.1.10.
    Android Version v3.1.5.
    Requires Android 4.1.2 or later.Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Huawei Mate 8, LG V20, Nubia Z7 mini, Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
Software & Drivers
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v1.0.0
    2015-12-07
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v0.9.2
    2015-10-20
  • DJI DNG Cleaner v1.1
    2015-04-10
  • Inspire 1/Phantom 3/ X5 Transcoding Tool v0.9.2
    2015-10-20
    2015-04-10
FAQ
Phantom 3 4K features a powerful camera capable of 4K video and Wi-Fi connectivity for the live video feed.
Option 1: Turn on the remote controller, then, while holding down the C1 and C2 buttons on the back of the remote controller, press the camera settings dial to reset.
Option 2: Flick the flight mode switch back and forth until the remote controller status indicator blinks red and green. This shows that the reset is in progress. Wi-Fi download reset is successful when the remote controller status indicator turns solid green.
The Phantom 3 4K is linked to the remote controller by default. Re-linking is only necessary if the remote controller is replaced.
To link a new remote controller:
1) Turn on the remote controller and connect to your mobile device.
2) Launch the DJI GO app.
3) Turn on the Intelligent Battery.
4) Enter “Camera” and tap on the remote controller icon and then tap the “Linking RC” button. The remote controller is now ready to link. The Remote Controller Status Indicator will blink blue and the controller will beep.
5) Locate the linking button on the side of the aircraft and press it to link. The Remote Controller Status Indicator LED will display a solid green once the remote controller has been successfully linked to the aircraft.
The remote controller is CE compliant by default and switching between CE and FCC is automatic based on aircraft location as determined by the DJI GO app.The CE compliant remote controller has an effective signal range of 0.31 miles (500 m) in open spaces.The FCC compliant remote controller has an effective signal range of 0.74 miles (1200 m) in open spaces. Be aware of your flying distance as the aircraft will enter Failsafe Return to Home if it flies beyond transmission range.
About 1.5 hours. It can be used for 6 hours per charge.
57 W.
Flight times will vary depending on environmental conditions and flying style. In ideal environments, flight times of up to 25 minutes are achievable with a full battery.
It weighs 1280g including the propellers and battery.
No.
Yes.
Yes.
The remote controller of the Phantom 3 4K has the same function as that of the Phantom 3 Professional/Advanced, yet features Wi-Fi video downlink. The FCC compliant remote controller of the Phantom 3 4K has an effective signal range of 0.74 miles (1200 m) in open spaces.
No.
Yes. For the best experience we recommend using a smartphone instead of a tablet.
Through the DJI GO app. A prompt will appear whenever an update is required.
The Phantom 3 4K comes with a 16 GB Micro SD card and supports Micro SD cards with a capacity of up to 64 GB. UHS-1 or Class 10 Micro SD cards are recommended to minimize delay when reading or writing high resolution image files. Do not insert or remove the Micro SD card when the Phantom 3 4K is turned on.
The Phantom 3 4K has 480p30 video downlink and other specs are the same.
Yes.
1) Switch on the remote controller.
2) Turn on the aircraft.
3) On your mobile device, select “PHANTOM3_XXXXXX”“from your Wi-Fi network list, and enter the default password “12341234”.
4) Launch the DJI GO app and enter Camera View. A video signal from the aircraft’s camera indicates that the aircraft has established a connection to the Wi-Fi video downlink successfully.
1) Make sure it is sufficiently charged before each flight.
2) Lock the mobile device holder firmly in place to avoid slipping.
3) Unfold the antennae and keep them perpendicular to the Phantom for optimal transmission quality. Do not point the antenna at the Phantom.
4) Repair or replace the remote controller if damaged. A damaged remote controller antenna will greatly decrease performance. If a remote controller is replaced, please see Question 3 of this FAQ: How do I link the remote controller?
mobile
Revolutionize Industries with your Game-Changing App
Using the Mobile SDK, create a customized mobile app to unlock the full potential of your DJI aerial platform.
Learn More
