Matrice Serie 30
| Diagonal Wheelbase | 1045mm |
| Frame Arm Length | 386mm |
| Frame Arm Weight (Including Motor, ESC, Propeller ) | 325g |
| Center Frame Diameter | 337mm |
| Center Frame Weight (with Landing Gear Mounting Base, Servos) | 1520g |
| Landing Gear Size | 460mm(Length)×511mm(Width)×305mm(Height) |
| Working Current | 40A |
| Working Voltage | 6S LiPo |
| Signal Frequency | 30Hz ~ 450Hz |
| Drive PWM Frequency | 8KHz |
| Weight(with Radiators) | 35g |
| Takeoff Weight | 6.0Kg ~ 11.0Kg |
| Total Weight | 4.4Kg |
| Power Battery | LiPo (6S,10000mAh~20000mAh,15C(Min)) |
| Max Power Consumption | 4000W |
| Hover Power Consumption | 1500W (@9.5Kg Takeoff Weight) |
| Hover Time | 15min (@15000mAh & 9.5Kg Takeoff Weight) |
| Working Environment Temperature | -10 °C ~ +40 °C |
| Stator Size | 41×14mm |
| KV | 400rpm/V |
| Max Power | 500W |
| Weight(with Cooling Fan) | 158g |
| Material | High strength performance engineered plastics |
| Size | 15×5.2inch |
| Weight | 13g |
| For A2 flight controller | Basic: Roll 120%, Pitch 120%, Yaw 120% Attitude: Roll 170%, Pitch 170%, Vertical 120% |
| For WooKong-M flight controller | Basic: Roll 130%, Pitch 130%, Yaw 120% Attitude: Roll 180%, Pitch 180%, Vertical 120% |
