Spreading Wings S1000+
Your DSLR in Flight
Diagonal Wheelbase1045mm
Frame Arm Length386mm
Frame Arm Weight
(Including Motor, ESC, Propeller )
Center Frame Diameter337mm
Center Frame Weight (with Landing Gear Mounting Base, Servos)1520g
Landing Gear Size460mm(Length)×511mm(Width)×305mm(Height)
Working Current40A
Working Voltage6S LiPo
Signal Frequency30Hz ~ 450Hz
Drive PWM Frequency8KHz
Weight(with Radiators)35g
Flight Parameters
Takeoff Weight6.0Kg ~ 11.0Kg
Total Weight4.4Kg
Power BatteryLiPo (6S,10000mAh~20000mAh,15C(Min))
Max Power Consumption4000W
Hover Power Consumption1500W (@9.5Kg Takeoff Weight)
Hover Time15min (@15000mAh & 9.5Kg Takeoff Weight)
Working Environment Temperature-10 °C ~ +40 °C
Stator Size41×14mm
Max Power500W
Weight(with Cooling Fan)158g
Foldable Propeller (1552/1552R)
MaterialHigh strength performance engineered plastics
Gain Value Settings
For A2 flight controllerBasic: Roll 120%, Pitch 120%, Yaw 120%
Attitude: Roll 170%, Pitch 170%, Vertical 120%
For WooKong-M flight controllerBasic: Roll 130%, Pitch 130%, Yaw 120%
Attitude: Roll 180%, Pitch 180%, Vertical 120%
DJI S1000+ Installation Demonstration
  • S1000+ Release Notes
  • S1000+ User Manual v1.4
  • * Important Notice:
    As DJI Innovations has no control over use, setup, final assembly, modification (including use of non-specified DJI parts i.e. motors, ESCs, propellers, etc.) or misuse, no liability shall be assumed nor accepted for any resulting damage or injury. By the act of use, setup or assembly, the user accepts all resulting liability.
  • You will need Adobe Reader to read PDF documents.
  • * Go to DJI Wiki for release history!
Buy Spreading wings 1000+
Launch your DSLR into the sky.
