zenmuse x4s
  • 1-Inch
    8.8mm/F2.8-11 FOV 84°
  • 20MP 11.6 Stops
    Leaf Shutter
  • 4K 60FPS
    Fast AF
  • H.264/H.265 100Mbps
    3-Axis Gimbal
General
NameZenmuse X4S
Dimensions125×100×80 mm
Weight253 g
Camera
SensorCMOS, 1"
Effective Pixels: 20 MP
LensF/2.8-11, 8.8mm (35 mm Equivalent: 24mm)
FOV84°
Photo Resolutions3:2, 5472×3648
4:3, 4864×3648
16:9, 5472×3078
Video ResolutionsH.264
C4K: 4096×2160
23.976/24/25/29.97/47.95/50/59.94p @100Mbps
4K: 3840×2160
2.7K: 2720×1530
23.976/24/25/29.97p @80Mbps
FHD: 1920×1080
23.976/24/25/29.97p @60Mbps
47.95/50/59.94p @80Mbps
119.88p @100Mbps
H.265
C4K: 4096×2160
23.976/24/25/29.97p @100Mbps
4K: 3840×2160
2.7K: 2720×1530
23.976/24/25/29.97p @65Mbps
FHD: 1920×1080
23.976/24/25/29.97p @50Mbps
47.95/50/59.94p @65Mbps
119.88p @100Mbps
Photo FormatsDNG, JPEG, DNG+JPEG
Video FormatsMOV, MP4
Operation ModesCapture, Record, Playback
Still Photography ModesSingle shot, Burst shooting: 3/5/7/10/14 frames, Auto Exposure
Bracketing, 3/5 bracketed frames at 0.7EV bias, Interval
Exposure ModeAuto, Manual, Shutter Priority, Aperture Priority
Exposure Compensation±3.0 (1/3 increments)
Metering ModeCenter-weighted metering,
Spot metering (area option 12×8)
AE LockSupported
Shutter SpeedMechanical Shutter: 8 – 1/2000s
Electronic Shutter: 1/2000 – 1/8000s
White BalanceAuto, Sunny, Cloudy, Incandescent, Neon,
Custom (2000K – 10000K)
ISO Range100 – 6400 (Video)
100 – 12800 (Stills)
Video CaptionsSupported
Anti-FlickerAuto, 50Hz, 60Hz
PAL/NTSCSupported
Gimbal
Angular Vibration Range±0.01°
MountDetachable
Controllable RangeTilt: +30° to -90°, Pan: ±320°
Mechanical RangeTilt: +50° to -140°, Pan: ±330°, Roll: +90° to -50°
Max Controllable Angular SpeedTilt: 90°/s, Pan: 90°/s
Environmental
Operating Temperature14° – 104°F (-10 to 40℃)
Storage Temperature-4° – 140°F (-20 to 60℃)
DOCUMENTS & MANUALS
  • Zenmuse X4S User Manual v1.2
    2017-01-20
  • Zenmuse X4S Quick Start Guide
    2016-12-30
APP / LIVE VIEW
    iOS Version v4.1.0.
    Requires iOS 9.0 or later. Compatible with iPhone 5s, iPhone SE, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4 and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 7, iPhone 7 Plus.
    Android Version v4.1.0.
    Android version 4.4.0 or later. Compatible with Samsung S7 edge, Samsung S7, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Samsung tabs 705c, Ascend Mate 9, Ascend Mate 7, Huawei P10 Plus, Huawei Honor 8, Huawei P8 Max, Vivo X7, Xiaomi 5, Google Nexus 6p, Nexus 9, Google Nexus 7 II, LG V20.
FAQ
While both cameras capture 20 megapixel photos, the X4S features a 1-inch Exmor R CMOS sensor and a fixed prime lens specially designed to fit the sensor and the imaging engine. Additionally, the X4S captures 4K video in the H.264 and H.265 formats.
The Zenmuse X5S features a M4/3 sensor and an interchangeable lens mount for M4/3 lenses. Combined with the Inspire 2’s internal CineCore 2.0 image processing system, the Zenmuse X5S can capture video H.264 and H.265 formats as well as CinemaDNG and Apple ProRes and is suitable for a wide range of professional filmmaking and television production applications.
The Zenmuse X4S is different from the Zenmuse X3 in the following ways:
a. The image sensor on the Zenmuse X4S has been upgraded to 1-inch and 20 megapixels, meaning less noise, higher dynamic range and more powerful color expression. In comparison, the Zenmuse X3 features a 1/2.3-inch, 12 megapixel sensor.
b. The Zenmuse X4S’s high-resolution lens is ultra-compact and equipped with a manually adjustable aperture, quick Auto Focus and a Leaf Shutter.
c. In addition to 20 megapixel photos, the X4S can also shoot oversampled video at 4096x2160/60fps and supports a maximum bitrate of 100Mbps as well as H.265 encoding for superior image quality.
No. The Zenmuse X4S must be used with the Inspire 2. It will be supported on additional products in future.
No. The lens hood protects the lens from dirt and damage.
Equipped with a quick AF function, the Zenmuse X4S has a focus range of 1m to infinity. For best results, we recommend that you focus before shooting. To do this, open the DJI GO app and tap the screen to focus (you might need to change Focus or Metering modes first). Focusing on a patterned area makes AF quicker and more accurate.
The X4S features an adjustable aperture and supports four exposure modes: Program (P), Aperture Priority (A), Shutter Priority (S) and Manual (M).
No. The Zenmuse X4S does not support optical zoom.
The Zenmuse X4S’s Leaf Shutter will automatically engage when the shutter speed is below or slower than 1/2000s. The Zenmuse X4S’s Leaf Shutter will automatically engage when the shutter speed is below or slower than 1/2000s. The Leaf Shutter cuts out electronic rolling shutter distortion and prevents motion blur when shooting fast moving objects.
H.265 is the new video compression standard that follows H.264. H.265 has 50% more information, better compression performance and a lower bandwidth utilization ratio. Please be aware that you will need an upgraded device to play or decode H.265 video.
No. The Zenmuse X4S does not support either format.
buy zenmuse x4s
