Zenmuse X5R
Zenmuse X5R
Aerial Imaging Evolved
  • 4K
  • Cinema DNG
  • 12-Bit RAW
  • M43 Mount
  • 24-30
    FPS
  • 12.8
    Stops
  • 512GB SSD
  • ProRes
Download Straight-from-the-camera Files
SENSOR
Size17.3 x 13.0 mm (4:3 Aspect Ratio)
TypeCMOS
Effective Pixels16.0M
ISO Range100~25600
MAX-PIXELS
Max-Pixels16.0M
Burst ShootingFull pixels 7fps
Shutter Speed8~1/8000 sec
EV Range-3~+3, 1/3
AEBSupport
IntervalSupport
Time LapsedSupport, 5/7/10/20/30 sec
DNGSupport
MISC.
ExposureP/S/A/M/C
AE MeteringAuto/spot metering
AE LockSupport
WBauto/manual/spot
Focus ModeAFS/AFF/MFT
Focus Mode256-zone / Pinpoint/(Touch focus is available)
AF AUXSupport
AE LockYes (AF/AE LOCK button)
Focus PeakingSupport
ZebraSupport
AdjustmentSupport
StylesRGB,Color looks, LOG, Cine-D, , D-LOG (RAW)
EnhancementHDR/Video DR
SoftwareDJI CineLight*(Mac)
LENS
OpticsUser Selectable (default DJI MFT 15mm F/1.7 ASPH)
IrisF/1.7-F/16 (default DJI lens)
Diagonal FOV72 degree (default DJI lens)
Equivalent30mm (default DJI lens)
Distortion0.40%
Focus Range20cm-infinite (default DJI lens)
Auto-FocusSupport (default DJI lens)
VIDEO
Resolution4096x2160(23.98p)
3840x2160(29.97/23.98p)
2704x1520(30/25p)
1920x1080(59.94/29.97p)
EncoderMPEG4/AVC/H.264/JPEG-Lossless(RAW)
Max-BitrateAverage:
1.6Gbps@4096x2160(23.98p),
1.9Gbps@3840x2160(29.97p/23.98p),
1Gbps@2704x1520(30p/25p),
500Mbps@1920x1080(29.97p)
FormatMP4/MOV/Cinema DNG (RAW)
StorageMicro-SD Class 10/SSD default 512GB (RAW)
Video NRSupport
StabilizerSupport
Zenmuse X5R - Tuned Footage
2016-04-26
DJI Zenmuse X5R – Color Grading Session
2015-09-11
Inspire 1 RAW Straight-from-the-camera Sample Files
  • Inspire 1 RAW Iceland Sample Footage (55s)
    2016-04-26
  • Inspire 1 RAW Straight-from-the-camera DNG Sequence
    2016-03-23
  • Inspire 1 RAW Sample Video
    2016-03-23
Documents & Manuals
  • Inspire 1 RAW Release Notes
    2017-07-10
  • Inspire 1 RAW User Manual
    2016-08-09
  • Zenmuse X5R SSD Quick Start Guide
    2016-06-03
  • Zenmuse X5R Reader Quick Start Guide
    2016-06-03
  • Inspire 1 Car Charger User Manual
    2016-06-17
  • zenmuse x5R User Manual
    2016-04-05
  • Zenmuse x5R in the box
    2016-04-05
  • Zenmuse X5R Disclaimer and Safety Guidelines
    2016-04-05
Firmware
  • Inspire 1 RAW Firmware v01.11.01.50
    2017-07-10
SOFTWARE
  • Dlog to sRGB 3DLUT
    2016-05-12
  • Dlog to sRGB 3DLUT User Instruction
    2016-05-12
  • DJI Camera Exporter
    2016-03-18
  • DJI Camera Exporter User Manual
    2016-03-18
  • DJI CineLight
    2016-05-30
  • DJI CineLight Release Notes
    2016-05-30
  • DJI CineLight User Manual
    2016-03-24
FAQ
The X3 gimbal and camera system is included with Inspire 1 and has 1/2.3” sensor, enabling it to shoot 4K video and capture 12 Megapixel photos, with an ISO range of 100-3200. The new ZENMUSE X5 Series camera and gimbal systems are the world’s first Micro Four Thirds (M4/3) cameras made specifically for aerial photography and videography. The M4/3 sensor is eight times the size of X3 camera and enables high quality, high sensitivity image recording at an ISO range of 100-25600. The ZENMUSE X5 cameras capture 16 Megapixel images with stunning details and records 4K video. With 12.8 stops of dynamic range, shadows and highlights in everything you capture is brought out in perfect clarity.The ZENMUSE X5 has a M4/3 lens mount which gives your photography flexibility by letting you change lenses. Currently, there are three lenses for the ZENMUSE X5 M4/3 lens mount: the Panasonic Lumix 15mm, Olympus M.Zuiko Digital 12mm and DJI MFT 15mm.
The biggest difference between them is in video recording capabilities, storage media, and workflow. The ZENMUSE X5R shoots video in lossless format to preserve maximum detail and enable precise editing and post-processing, giving cinematographers full control over the look of their footage. The ZENMUSE X5R has an integrated 512GB SSD drive for storing the lossless video recorded. DJI has designed an editing software specifically for lossless videos, enabling high-end filmmakers to easily edit and process the videos according to their own needs.
The ZENMUSE X5 Series are the first M4/3 cameras designed specifically for aerial photography. The cameras come with an integrated 3-axis gimbal stabilization system, and are designed for use with the Inspire 1. The camera shoots 16 Megapixel photos and 4K video, and can be fully controlled via the new DJI GO app.
No. The ZENMUSE X5 Series cameras must be used together with the Inspire 1 or future supported DJI products.
The ZENMUSE X5 Series is currently compatible with the DJI Inspire 1 and the Matrice 100. More compatible products will be available in future.
The M4/3 sensor is eight times larger than the sensor in the ZENMUSE X3, enabling it to capture incredibly detailed images and videos, including UHD 4K, and gives it improved low-light performance. The M4/3 lens mount allows the use three lenses currently.
The M4/3 lens mount is the interface between the camera body and the attached M4/3 lens. Thanks to the standardized M4/3 mount, you can select three lenses currently. The size of M4/3 is between the size of super 35mm and super 16mm, and super 35 mm lenses can be added to the MFT mount which enables you to shoot high-quality aerial videos.
Currently, there are three prime lenses compatible with the X5: the Panasonic Lumix 15mm, Olympus M.Zuiko Digital 12mm and DJI MFT 15mm.
To ensure that the 3-axis gimbal’s movements are unrestricted, the lenses are required to fit the gimbal in terms of weight and size. Not all existing lenses fit these requirements, which is why not all MFT lenses are compatible with the ZENMUSE X5 Series.
DJI GO is an easy-to-use mobile application for iOS and Android devices for use together with DJI products. For more information please visit: http://www.dji.com/product/goapp
If you have an Inspire 1 with a ZENMUSE X3 installed, the mounting mechanism should be changed to the new one that's included with the ZENMUSE X5 series. The new mounting mechanism that's provided with ZENMUSE X5 Series are also backwards compatible with the Zenmuse X3 camera.
Because the ZENMUSE X5R's footage captured is lossless and uncompressed, it requires a large amount of memory for storage. We offer a 512GB SSD with the ZENMUSE X5R for this reason.
It depends on the lens used. The 3-axis gimbal is sensitive to the weight of the mounted lens. When you are using an Olympus M.Zuiko Digital 12mm, the lens hood can be removed without disturbing the gimbal’s operations. However, if you are using a Panasonic Lumix 15mm or DJI MFT 15mm, the lens hood must be attached. For more detail, please go to the download page for official guidance.
Yes, you can view your photos and videos by going to the Library in the DJI GO app.
Yes, you can go to the Library and find the video and photo editor.
To focus on a specific area, all you have to do is to tap on the screen of your mobile device just like the way you are using it on a smartphone.
Auto, Aperture Priority, Shutter Priority and Manual Exposure.
Yes. Specified zoom lenses are supported for photography only. Find out more in Supported Lenses section of the specs.
buy zenmuse x5r
Aerial imaging evolved
