Zenmuse Z15-5D III (HD)
High Definition, Low Weight, Perfect Stability
General
Built-In Functions
  1. Three Working Modes
    · Orientation-locked control
    · Non orientation-locked control
    · FPV mode (Reset)
  2. Built-in independent IMU module
  3. DJI gimbal special servos drive module
  4. HDMI HD/AV module
  5. Wireless video transmission supported
  6. Camera shutter control supported
  7. Wide range voltage input supported
  8. S-Bus/PPM Receiver support
  9. 360° panoramic photograph function
  10. Auto-calibration function
Mechanical& Electrical Characteristics
Working CurrentStatic current: 200mA (@25V)
Dynamic current: 400mA (@25V)
Locked-rotor current: 4A (@25V)
Operating Temperature-10°C ~ 50°C
Weight1.53Kg
Dimensions281mmX242mmX222mm
GCU Weight63g
GCU Dimensions64.2 mm × 34.1mm × 19.5mm
Peripheral
Supported CameraCANON EOS 5D MARK III
Supported Lens CurrentlyCANON EF 24mm f/2.8 IS USM
GCU Input Power4S~12S LiPo (Recommend 6S if with S1000)
Control RequirementAt least four spare receiver channels
Assistant Software System RequirementWindows XP SP3; Windows 7; Windows 8 (32 or 64 bit)
Working Performance
Load Weight (Reference Value)2664g(5D MARK III with SD Card & Battery & CANON EF 24mm f/2.8 IS USM Lens)
Controlled Angle Accuracy±0.02°
Maximum Controlled Rotation SpeedPan axis: ±90°/s
Tilt axis: ±130°/s
Roll axis: ±30°/s
RotationPan axis control: ±360° continuous rotation
Tilt axis control: +15°/-90°
Roll axis control: ±25°
DJI - Sailing the South China Sea
2014-10-09
Zenmuse Z15-5D III (HD) <br>Gimbal Installation Demonstration
2014-09-17
Latest
  • Zenmuse Z15-5D III (HD) Release Notes
    2016-01-14
  • Zenmuse Z15-5D III (HD) User Manual v1.4
    2015-09-28
  • Zenmuse Assistant Software v1.4
    2015-01-04
Drivers
  • DJI WIN Driver Installer
    2013-01-18
  • * Important Note:
    As DJI Innovations has no control over use, setup, final assembly, modification (including use of non-specified DJI parts or misuse, no liability shall be assumed nor accepted for any resulting damage or injury. By the act of use, setup or assembly, the user accepts all resulting liability.
Buy ZENMUSE Z15-5D III (HD)
Keep your camera level however you fly
