Zenmuse Z30
Closing the distance
Zenmuse Z30
General
NameZenmuse Z30
Dimensions152×137×61 mm
Weight556 g
Camera
SensorCMOS, 1/2.8"
Effective Pixels: 2.13 M
Lens30x Optical Zoom
F1.6 (Wide) - F4.7 (Tele)
Zoom Movement Speed:
- Optical Wide – Optical Tele: 4.6 sec
- Optical Wide – Digital Tele: 6.4 sec
- Digital Wide – Digital Tele : 1.8 sec
Focus Movement Time:
∞ - near: 1.1 sec
FOV63.7°(Wide) - 2.3°(Tele)
Digital Zoom6x
Min. Working Distance10 mm - 1200 mm
Photo Formats JPEG
Video FormatsMOV, MP4
Working ModesCapture, Record, Playback
Still Photography ModesSingle shot, Burst shooting: 3/5 frames, Interval (2/3/4/7/10/15/20/30 sec)
Exposure ModeExposure Mode Auto, Manual, Shutter priority, Aperture priority
Exposure Compensation±2.3 (1/3 increments)
Metering Mode Center-weighted metering, Spot metering (Area option 12x8)
AE LockSupported
Electronic Shutter Speed 1/30 – 1/6000 s
White Balance Auto, Sunny, Cloudy, Incandescent, Custom (2000K - 10000K)
Video Captions Supported
TapZoomSupported
TapZoom Range1-5
DefogSupported
One Key to 1x ImageSupported
Anti-flicker 50 Hz, 60 Hz
PAL/NTSC Supported
Supported SD Cards MicroSD (SD / SDHC / SDXC)
Max. Capacity: 64 GB, Class 10 or UHS-1
Supported File Systems FAT32 (≤ 32 GB)
exFAT (> 32 GB)
Gimbal
Angular Vibration Range ±0.01°
MountDetachable
Controllable RangePitch : +40° to -90°, Yaw: ±320°
Mechanical RangePitch ‘: +50° to -140°, Yaw: ±330°, Roll: +90° to -50°
Max Controllable SpeedPitch ‘: 180°/s, Yaw: 180°/s
Environmental
Operating Temperature 14° to 113° F (-10° to 45° C)
Non-Operating Temperature -4° to 140° F (-20° to 60° C)
Intro
Z30 Intro
Z30 Intro
2016-12-26
Z30 Cell Tower Inspection
2016-12-26
Z30 Fire Firefighter
2016-12-26
Tutorials
Zenmuse z30 Mounting To The Matrice 100
2016-12-28
Documents and Manuals
  • Zenmuse Z30 Release Notes
    2017-08-29
  • Zenmuse Z30 User Manual
    2016-12-28
  • Zenmuse Z30 Quick Start Guide
    2016-12-28
CAMERA FIRMWARE
  • Zenmuse Z30 Firmware
    2017-08-29
The Zenmuse Z30 offers a 30 times optical zoom with an additional 6 times digital zoom.
No. It is designed for industrial applications and is not compatible with the Osmo series.
The Zenmuse Z30 is built for different industrial applications including traffic law enforcement, equipment and infrastructure inspection, firefighting, and search and rescue. Details are as follows:
Traffic law enforcement: Capture a detailed image of traffic violations from a distance. Tap on the screen and the camera will zoom in to focus on the target vehicle.
Firefighting: Discover sources of ignition from a distance, measure areas on fire, and maintain safe distances when dealing with explosives.
Cell tower inspection: Zoom in on critical structures for a detailed look, eliminating the risk of close quarters flying.
Construction inspection: Pinpoint areas of interest from afar.
No. It is only compatible with the Matrice series, Matrice 100 and Matrice 600.
The Zenmuse Z30 offers a 30 times optical zoom while the Zenmuse Z3 only has a 3 times optical zoom. It also has a number of unique intelligent features including TapZoom, which makes zooming easier.
When zooming large amounts, micro-movements and aircraft vibration will be magnified, resulting in a slight shake during video capture. However, this will not affect photo capture, therefore long-range zooming is ideal for real-time inspection and photography.
It supports TapZoom, One Key to 1x Image, Defog and more.
