Specs
Core module
Computing unit
  • CPU
  • Dual-core 64-bit RISC-V CPU, base frequency: 400MHz, each with independent single-precision FPU
  • NPU
  • Neural network accelerator, supports operator acceleration such as convolution, pooling, and activation, computing power: 0.8Tops
  • SRAM
  • 8MB 64-bit
  • Flash
  • 16MB NOR Flash
AI performance
  • Task type
  • Supports machine vision - target detection tasks
  • Toolchain
  • All-in-one visual AI training platform, allows beginners to easily train their own models
  • Neural network model
  • Customized and improved YOLOv2
  • Model input
  • 320x240RGB, 16-bit
  • Model calculation time
  • <9ms
Camera
  • Sensors
  • 1/4-inch, color, global exposure, 60fps
  • Output image
  • Resolution: 320x240, 16-bit color depth
  • Lens
  • FOV: 40°, fixed focal length: 8mm
  • Lens holder
  • Manually adjustable pitch axis
General
  • Weight
  • 9g
  • Dimensions
  • 54x32x11mm
  • Power supply
  • Micro USB power supply or 14pin expansion port 5V power supply, supports hot swapping, short circuit protection, overcurrent protection, and overheating protection
  • Power consumption
  • About 1.25W
  • Output port
  • Serial port (inference results), SPI (video stream)
  • Auxiliary functions
  • Button x1, RGB LED x1
Touchscreen
Touchscreen
  • Screen size
  • 2.4 inches
  • Display image
  • Display port
  • 8-bit MCU parallel interface
General
  • Weight
  • 42g
  • Dimensions
  • 67x49x15mm
  • Power supply
  • 5V, supports hot swapping
  • Power consumption
  • About 250mW
  • Button x2, SD card slot x1 (must be used with core module)
Universal expansion module
General
  • Dimensions
  • 58x46x15mm
  • Weight
  • 22.5g
  • Power supply
  • 5V/12V, supports hot swapping
  • Power consumption
  • About 500mW
  • MCU
  • i.MX RT1064, base frequency: 600MHz, 1MB RAM + 4MB ROM
  • Open source
  • SDK development supported
  • Expandability
  • 14-pin extended interface (I2C, UART, SPI, GPIO, PWM, and power supply)
  • 100-pin expanded interface (power supply, GPIO, and other reusable functions)
  • Button x2, SD slot x1
Software
  • No. of labeling tasks
  • Advanced Edition:3
    Professional Edition:5
    Professional Edition - AI Service Package:15
  • No. of datasets
    Professional Edition:8
    Professional Edition - AI Service Package:25
  • No. of datasets per training round
    Professional Edition - AI Service Package:8
  • No. of algorithms for training
  • No. of simultaneous algorithm training tasks
  • Advanced Edition:1
    Professional Edition:2
    Professional Edition - AI Service Package:3
  • No. of models
  • No. of algorithm applications
  • Avg. algorithm training time
  • Advanced Edition:Long
    Professional Edition:Long
    Professional Edition - AI Service Package:Shorter
