GENERAL
Operating Frequency2.400 GHz ~ 2.483 GHz
5.725 GHz ~ 5.825 GHz
Max Transmission Distance2.4 GHz:
10 km(FCC)
5 km(CE)
5.6 km(SRRC)
5.8 GHz:
10 km(FCC)
2.6 km(CE)
7km(SRRC)
Transmitter Power (EIRP)2.4 GHz:
26 dBm(FCC)
17 dBm(CE)
20 dBm(SRRC)
5.8 GHz:
28 dBm(FCC)
14 dBm(CE)
20 dBm(SRRC)
Antenna pointing rangeYAW:-330° ~ 330°
Pitch:-25° ~ 90°
Antenna gain2.4 GHz:12 dBi
5.8 GHz:18 dBi
PortSMA,CAN,USB,Power port
Operating Temperature Range-20 °C to 55 °C
Power6 W
DimensionDiameter: 345 mm Height: 169 mm
Weight2 kg
Tracktenna is a dedicated high-gain directional antenna that tracks and points towards DJI aircraft midflight. It uses multiple sensors and data from the remote controller to calculate its own and the aircraft’s position, rotating to face the aircraft in real time. Standard antennas, on the other hand, are omnidirectional with lower gain and without onboard sensors.
No. Inspire 2 remote controller antennas are not detachable.
No. Tracktenna needs flight status information from the remote controller to locate an aircraft’s position. Right now, such data can only be transferred by the Cendence remote controller.
Yes. Tracktenna currently has an IPX3 rating.
Yes, but we recommend not to. Signals get blocked when the aircraft is flying at lower altitudes and performance may be adversely affected.
Tracktenna will keep tracking the aircraft, but its gain will decrease. The power indicator will warn you when power is low.
We recommend not to, as this will break the terms of the product’s warranty.
