Dimensions | Unfolded, propellers and landing gears included, 883×886×398 mm Folded, propellers and landing gears excluded, 722×247×242 mm |
Diagonal Wheelbase | 643 mm |
Weight | Approx. 4.69 kg (with two TB55 batteries) |
Max Takeoff Weight | 6.14 kg |
Max Payload | 1.45 kg |
Operating Frequency | 2.4000-2.4835 GHz; 5.725-5.850 GHz |
EIRP | 2.4 GHz: ≤ 26 dBm (NCC/FCC); ≤ 20 dBm (CE/MIC); ≤ 20 dBm (SRRC) 5.8 GHz: ≤ 26 dBm (NCC/FCC); ≤ 14 dBm (CE); ≤ 26 dBm (SRRC) |
Hovering Accuracy (P-mode with GPS) | Vertical:±1.64 feet (±0.5 m) or ±0.33 feet (±0.1 m, Downward Vision System enabled) Horizontal:±4.92 feet (±1.5 m) or ±0.98 feet (±0.3 m, Downward Vision System enabled) |
Max Angular Velocity | Pitch: 300°/s, Yaw: 120°/s |
Max Pitch Angle | S-mode: 35°; P-mode: 30° (Forward Vision System enabled: 25°); A-mode: 30° |
Max Ascent Speed | 16.4 ft/s (5 m/s) |
Max Descent Speed (vertical) | 9.8 ft/s (3 m/s) |
Max Speed | S-mode/A-mode 81 kph (50.3 mph); P-mode: 61.2 kph (38 mph) |
Max Service Ceiling Above Sea Level | 9842 feet (3000 m, with 1760S propellers) |
Max Wind Resistance | 39.4 ft/s (12 m/s) |
Max Flight Time (with two TB55 batteries) | 38 min (no payload), 24 min (takeoff weight: 6.14 kg) |
Supported DJI Gimbals | Zenmuse X4S/X5S/X7/XT/XT2/Z30 |
Supported Gimbal Mounting | Single Gimbal, Downward |
Ingress Protection Rating | IP43 |
GNSS | GPS+GLONASS |
Operating Temperature | -4° to 122° F (-20° to 50° C) |
Velocity Range | <32.8 ft/s (10 m/s) at the height of 6.56 feet (2 m) |
Altitude Range | <32.8 feet (10 m) |
Operating Range | <32.8 feet (10 m) |
Operating Environment | Surfaces with clear patterns and adequate lighting (> 15 lux) |
Ultrasonic Sensor Operating Range | 0.33-16.4 feet (0.1-5 m) |
Ultrasonic Sensor Operating Environment | Non-absorbing material, rigid surface (thick indoor carpeting will reduce performance) |
Obstacle Sensing Range | 0-16.4 feet (0-5 m) |
FOV | ±5° |
Operating Environment | Large, diffuse and reflective obstacles (reflectivity >10%) |
Voltage | 26.1 V |
Rated Power | 180 W |
Max Transmitting Distance(unobstructed, free of interference) | NCC/FCC: 5 mi (8 km); CE/MIC: 3.1 mi (5 km); SRRC: 3.1 mi (5 km) |
Power Supply | Extended Intelligent Battery (Model: WB37-4920mAh-7.6V) |
Output Power (max) | 13 W (Without supplying power to monitor) |
USB Power Supply | 1 A⎓ 5.2 V (max) |
Obstacle Sensing Range | 2.3-98.4 feet (0.7-30 m) |
FOV | Horizontal 60°; Vertical: 54° |
Capacity | 7660 mAh |
Voltage | 22.8 V |
Battery Type | LiPo 6S |
Energy | 174.6 Wh |
Net Weight (Single One) | Approx. 885 g |
Charging Temperature | 41° to 104° F (5° to 40° C) |
Max Charging Power | 180 W |
Input Voltage | 26.1 V |
Input Current | 6.9 A |
Dimensions | M210 V2: Unfolded, propellers and landing gears included, 883×886×398 mm Folded, propellers and landing gears excluded, 722×282×242 mm M210 RTK V2: Unfolded, propellers and landing gears included, 883×886×427 mm Folded, propellers and landing gears excluded, 722×282×242 mm |
Weight | M210 V2: Approx. 4.8 kg (with two TB55 batteries); M210 RTK V2: Approx. 4.91 kg (with two TB55 batteries) |
Max Payload | M210 V2: 1.34 kg; M210 RTK V2: 1.23 kg |
Hovering Accuracy (P-mode with GPS) | Vertical: ±1.64 feet (±0.5 m) or ±0.33 feet (±0.1 m, Downward Vision System enabled) Horizontal: ±4.92 feet (±1.5 m) or ±0.98 feet (±0.3 m, Downward Vision System enabled) |
Hovering Accuracy (D-RTK, M210 RTK V2) | Vertical: ±0.33 feet (±0.1 m); Horizontal: ±0.33 feet (±0.1 m) |
Max Pitch Angle (Dual Downward Gimbal/Single Upward Gimbal) | S-mode: 30°; P-mode: 30° (Forward Vision System enabled: 25°); A-mode: 30° |
Max Pitch Angle [Single Downward Gimbal (Gimbal Connector I)] | S-mode: 35°; P-mode: 30° (Forward Vision System enabled: 25°); A-mode: 30° |
Max Speed (Dual Downward Gimbal/Single Upward Gimbal) | S-mode/A-mode: 73.8 kph (45.9 mph); P-mode: 61.2 kph (38 mph) |
Max Speed [ Single Downward Gimbal (Gimbal ConnectorI) ] | S-mode/A-mode: 81 kph (50.3 mph); P-mode: 61.2 kph (38 mph) |
Max Flight Time (with two TB55 batteries) | M210 V2: 34 min (no payload), 24 min (takeoff weight: 6.14 kg) M210 RTK V2: 33 min (no payload), 24 min (takeoff weight: 6.14 kg) |
Supported Gimbal Configurations | Single Downward Gimbal, Dual Downward Gimbals, Single Upward Gimbal |
GNSS | M210 V2: GPS+GLONASS; M210 RTK V2: GPS+GLONASS+BeiDou+Galileo |
Operating Environment | Surfaces with clear patterns and adequate lighting (>15 lux) |
Ultrasonic Sensor Operating Environment | Non-absorbing material, rigid surfaces (thick indoor carpeting will adversely affect performance) |
FOV | ±5° |
Operating Environment | Large, diffuse, and reflective obstacles (reflectivity >10%) |
Voltage | 26.1 V |
USB Power Supply | 1 A⎓5.2 V (max) |
CrystalSky Monitor | DJI CrystalSky 7.85inch, Resolution: 2048×1536; Brightness: 2000 cd/m2; Operating System: Android 5.1; Storage: ROM 128GB |
FOV | Horizontal: 60°; Vertical: 54° |
Voltage | 22.8 V |
Energy | 174.6 Wh |
Android
Requires Android 5.0 or above.
Compatible with DJI Crystalsky, Mi Pad 3, Mi Pad 2, Samsung S2, Samsung S3, Huawei M2, Huawei M3, Nexus 9.
Huawei honor 9, Huawei P10, Google Pixel 2. One plus 6, LG G6, OPPO R15, VIVO X21, Nokia 7 plus, Mi Mix 2s, Samsung Galaxy S8.
