Specs
Aircraft
  • Dimensions
    (unfolded, excl. propellers)
  • 470×585×215 mm (L×W×H)
  • Dimensions (folded)
  • 365×215×195 mm (L×W×H)
  • Diagonal Wheelbase
  • 668 mm
  • Weight (incl. two batteries)
  • 3770 ± 10 g
  • Max Takeoff Weight
  • 4069 g
  • Max Takeoff Weight for C2 Certification in EU
  • 3998 g
  • Operation Frequency[1]
  • 2.4000-2.4835 GHz; 5.725-5.850 GHz
  • Transmitter Power (EIRP)
  • 2.4 GHz: <33 dBm (FCC); <20 dBm (CE/SRRC/MIC)
    5.8 GHz: <33 dBm (FCC/SRRC); <14 dBm (CE)
  • Hovering Accuracy
    (windless or breezy)
  • Vertical: ±0.1 m (Vision System enabled); ±0.5 m (N-mode with GPS); ±0.1 m (RTK)
    Horizontal: ±0.3 m (Vision System enabled); ±1.5 m (N-mode with GPS); ±0.1 m (RTK)
  • RTK Positioning Accuracy
    (fixed RTK enabled)
  • 1 cm+1 ppm (horizontal)
    1.5 cm+1 ppm (vertical)
  • Max Angular Velocity
  • Pitch: 150°/sec.; Yaw: 100°/sec.
  • Max Pitch Angle
  • 35° (N-mode and Forward Vision System enabled: 25°)
  • Max Ascent/Descent Speed
  • 6 m/s, 5 m/s
  • Max Tilt Descent Speed
  • 7 m/s
  • Max Horizontal Speed
  • 23 m/s
  • Max Service Ceiling Above Sea Level (without other payload)
  • 5,000 m (with 1671 propellers)
    7,000 m (with 1676 propellers)
  • Max Wind Resistance
  • 12 m/s
  • Max Hover Time [2]
  • 36 min
  • Max Flight Time[2]
  • 41 min
  • Motor Model
  • 3511
  • Propeller Model
  • 1671
    1676 High Altitude (not included)
  • Ingress Protection Rating[3]
  • IP55
  • GNSS
  • GPS+Galileo+BeiDou+GLONASS
    (GLONASS is supported only when RTK module is enabled)
  • Operating Temperature
  • -20° to 50° C (-4° to 122° F)
Gimbal
  • Angular Vibration Range
  • ±0.01°
  • Controllable Range
  • Pan: ±90°
    Tilt: -120° to +45°
  • Mechanical Range
  • Pan: ±105°
    Tilt: -135° to +60°
    Roll: ±45°
Zoom Camera
  • Sensor
  • 1/2" CMOS, Effective pixels: 48M
  • Lens
  • Focal length: 21-75 mm (equivalent: 113-405 mm)
    Aperture: f/2.8-f/4.2
    Focus: 5 m to ∞
  • Exposure Compensation
  • ±3 ev (using 1/3 ev as step length)
  • Electronic Shutter Speed
  • Auto Mode:
    Photo: 1/8000-1/2 s
    Video: 1/8000-1/30 s
    M Mode:
    Photo: 1/8000-8 s
    Video: 1/8000 -1/30 s
  • ISO Range
  • 100-25600
  • Max. Video Resolution
  • 3840×2160
  • Max Photo Size
  • 8000×6000
Wide Camera
  • Sensor
  • 1/2" CMOS, Effective pixels: 12M
  • Lens
  • DFOV: 84°
    Focal length: 4.5 mm (equivalent: 24 mm)
    Aperture: f/2.8
    Focus: 1 m to ∞
  • Auto Mode:
    Photo: 1/8000-1/2 s
    M Mode:
    Photo: 1/8000-8 s
  • ISO Range
  • 100-25600
  • 3840×2160
  • Photo Size
  • 4000×3000
Thermal Camera
  • Thermal Imager
  • Uncooled VOx Microbolometer
  • Lens
  • DFOV: 61°
    Focal length: 9.1 mm (equivalent: 40 mm)
    Aperture: f/1.0
    Focus: 5 m to ∞
  • Noise Equivalent Temperature Difference (NETD)
  • ≤50 mK@F1.0
  • Infrared Temperature Measurement Accuracy[4]
  • ±2°C or ±2% (using the larger value)
  • Video Resolution
  • Infrared Image Super-resolution Mode: 1280×1024
    Normal Mode: 640×512
  • Photo Size
  • Pixel Pitch
  • 12 um
  • Temperature Measurement Method
  • Spot Meter, Area Measurement
  • Temperature Measurement Range
  • High Gain Mode: -20° to 150° C (-4° to 302° F)
    Low Gain Mode: 0° to 500° C (32° to 932° F)
  • Temperature Alert
  • Supported
  • Palette
  • White Hot/Black Hot/Tint/Iron Red/Hot
    Iron/Arctic/Medical/Fulgurite/Rainbow 1/Rainbow 2
FPV Camera
  • Resolution
  • 1920×1080
  • DFOV
  • 161°
  • Frame Rate
  • 30 fps
Laser Module
  • Wavelength
  • 905 nm
  • Max Laser Power
  • 3.5 mW
  • Single Pulse Width
  • 6 ns
  • Measurement Accuracy
  • ± (0.2 m + D×0.15%)
    D is the distance to a vertical surface
  • Measuring Range
  • 3-1,200 m (0.5×12 m vertical surface with 20% reflectivity)
  • Safety Regulation Level
  • Class 1M
  • Accessible Emission Limit (AEL)
  • 304.8 nJ
  • Reference Aperture
  • 18mm length, 18mm width (20.3mm diameter if equivalent to circular)
  • Max Laser Pulse Emission Power Within 5 Nanoseconds
  • 60.96 W
Vision Systems
  • Obstacle Sensing Range
  • Forward: 0.6-38 m
    Upward/Downward/Backward/Sideward: 0.5-33 m
  • FOV
  • 65° (H), 50° (V)
  • Operating Environment
  • Surfaces with clear patterns and adequate lighting (> 15 lux)
Infrared Sensing Systems
  • 0.1 to 10 m
  • FOV
  • 30°
  • Large, diffuse, and reflective obstacles (reflectivity >10%)
TB30 Intelligent Flight Battery
  • Capacity
  • 5880 mAh
  • Voltage
  • 26.1 V
  • Battery Type
  • Li-ion 6S
  • Energy
  • 131.6 Wh
  • Net Weight
  • Approx. 685 g
  • Storage Temperature
  • 20° to 30° C (68° to 86° F)
  • Charging Temperature
  • -20° to 40° C (-4° to 104° F)
    (When the temperature is lower than 10° C (50° F), the self-heating function will be automatically enabled. Charging in a low temperature may shorten the lifetime of the battery)
  • Chemical System
  • LiNiMnCoO2
Auxiliary Lights
  • Effective Illumination Distance
  • 5 m
  • Illumination Type
  • 60 Hz, solid glow
Remote Controller
  • Screen
  • 7.02 inch LCD touchscreen, with a resolution of 1920×1200 pixels, and high brightness of 1200 cd/m2
  • Internal Battery
  • Type: Li-ion (6500 mAh @ 7.2 V)
    Charge Type: Supports battery station or USB-C charger maximum rated power 65W (max voltage of 20V)
    Charge Time: 2 hours
    Chemical System: LiNiCoAIO2
  • External Battery(WB37 Intelligent Battery)
  • Capacity: 4920 mAh
    Voltage: 7.6 V
    Battery Type: Li-ion
    Energy: 37.39 Wh
    Chemical System: LiCoO2
  • Operating Time[5]
  • Internal Battery: Approx. 3 hours 18 min
    Internal Battery + External Battery: Approx. 6 hours
  • IP54
  • GNSS
O3 Enterprise
  • Operating Frequency[1]
  • 2.4000-2.4835 GHz, 5.725-5.850 GHz
  • Max Transmission Distance (unobstructed, free of interference)
  • 15 km (FCC); 8 km (CE/SRRC/MIC)
  • Max Transmission Distance (with interference)
  • Strong Interference (urban landscape, limited line of sight, many competing signals): 1.5-3 km (FCC/CE/SRRC/MIC)
    Medium Interference (suburban landscape, open line of sight, some competing signals): 3-9 km (FCC); 3-6 km (CE/SRRC/MIC)
    Weak Interference (open landscape abundant line of sight, few competing signals): 9-15 km (FCC); 6-8 km (CE/SRRC/MIC)
    5.8 GHz: <33 dBm (FCC); <14 dBm (CE); <23 dBm (SRRC)
Wi-Fi
  • Protocol
  • Wi-Fi 6
  • 2.4000-2.4835 GHz; 5.150-5.250 GHz; 5.725-5.850 GHz
  • 2.4 GHz: <26 dBm (FCC); <20 dBm (CE/ SRRC/MIC)
    5.1 GHz: <26 dBm (FCC); <23 dBm (CE/ SRRC/MIC)
    5.8 GHz: <26 dBm (FCC/SRRC); <14 dBm(CE)
Bluetooth
  • Protocol
  • Bluetooth 5.1
  • 2.4000-2.4835 GHz
  • <10 dBm
BS30 Intelligent Battery Station
  • Dimensions
  • 353×267×148 mm
  • Net Weight
  • 3.95 kg
  • Compatible Battery Type
  • TB30 Intelligent Flight Battery
  • Input
  • 100-240 VAC, 50/60 Hz
  • Output
  • TB30 Battery Port: 26.1 V, 8.9 A (supported up to two outputs simultaneously)
    WB37 Intelligent Battery: 8.7 V, 6 A
  • Output Power
  • 525 W
  • USB-C port
  • Max. output power of 65 W
  • USB-A port
  • Max. output power of 10 W (5 V, 2 A)
  • Power Consumption (when not charging battery)
  • < 8 W
  • Output Power (when warming up battery)
  • Approx. 30 W
  • IP55 (with the cover closed properly)
  • Charging Time[6]
  • Approx. 30 min (charging two TB30 batteries from 20% to 90%)
    Approx. 50 min (charging two TB30 batteries from 0% to 100%)
  • Protection Features
  • Anti-Backflow Protection
    Short Circuit Protection
    Over Voltage Protection
    Over Current Protection
    Temperature Protection
Other
  • Footnotes
  • [1] 5.8 and 5.1GHz frequencies are prohibited in some countries. In some countries, the 5.1GHz frequency is only allowed for use indoors.
    [2] The maximum flight time and the hover time were tested in a lab environment and is for reference only.
    [3] This protection rating is not permanent and may reduce over time after long-term use.
    [4] Infrared temperature measurement accuracy was tested in a lab environment and is for reference only.
    [5] The maximum operating time was tested in a lab environment and is for reference only.
    [6] The charging time was tested in a lab environment at room temperature. The value provided should be used for reference only.
  • The terms HDMI, HDMI High-Definition Multimedia Interface, HDMI Trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc.
