• Zoom Camera
  • Dual Camera
  • OcuSync 2.0
  • Modular Accessories
  • Password Protection
  • DJI AirSense
Aircraft
Takeoff Weight(Without Accessories)Zoom Edition:905 g
Dual Edition:899 g
Max Takeoff Weight1100 g
Dimensions(L×W×H) Folded: 214×91×84 mm
Unfolded: 322×242×84 mm
Unfolded+Spotlight:322×242×114 mm
Unfolded+Beacon:322×242×101 mm
Unfolded+Speaker:322×242×140 mm
Diagonal Length354 mm
Max Ascent Speed5 m/s (S-mode[1])
4 m/s (P-mode)
4 m/s (S-mode with accessories[1])
4 m/s (P-mode with accessories)
Max Descent Speed3 m/s (S-mode[1])
3 m/s (P-mode)
Max Speed (near sea level, no wind)72 kph (S-mode,without wind)
50 kph (P-mode,without wind)
Max Service Ceiling Above Sea Level6000 m
Max Flight Time (no wind)31 min (at a consistent speed of 25 kph)
Max Hovering Time (no wind)29 min
27 min (with beacon turned on)
28 min (with beacon turned off)
22 min (with spotlight turned on)
26 min (with spotlight turned off)
25 min (with speaker turned on)
26 min (with speaker turned off)
Max Wind Speed Resistance29–38 kph
Max Tilt Angle35° (S-mode, with remote controller)
25° (P-mode)
Max Angular Velocity200°/s(S-Mode)
100°/s(P-Mode)200°/s(S-Mode)
100°/s(P-Mode)
Operating Temperature Range-10°C to 40°C
GNSSGPS+GLONASS
Hovering Accuracy RangeVertical:
±0.5 m (with GPS Positioning)
Horizontal: ±0.3m (with Vision Positioning)
±1.5 m (with GPS Positioning)
Operating Frequency2.400 - 2.4835 GHz
5.725 - 5.850 GHz
Transmission Power (EIRP)2.400 - 2.4835 GHz
FCC:≤26 dBm
CE:≤20 dBm
SRRC:≤20 dBm
MIC:≤20 dBm5.725-5.850 GHz
FCC:≤26 dBm
CE:≤14 dBm
SRRC:≤26 dBm
Internal Storage24 GB
Gimbal
Mechanical RangeTilt: -135 – +45°
Pan: -100 – +100°
Controllable RangeTilt: -90 – +30°
Pan: -75 – +75°
Stabilization3-axis (tilt, roll, pan)
Max Control Speed (tilt)120°/s
Angular Vibration Range±0.005°
Sensing System
Sensing SystemOmnidirectional Obstacle Sensing [3]
ForwardPrecision Measurement Range:0.5 - 20 m
Detectable Range: 20 - 40 m
Effective Sensing Speed: ≤ 14m/s
FOV: Horizontal: 40°, Vertical: 70°
BackwardPrecision Measurement Range: 0.5 - 16 m
Detectable Range: 16 - 32 m
Effective Sensing Speed: ≤ 12m/s
FOV: Horizontal: 60°, Vertical: 77°
UpwardPrecision Measurement Range: 0.1 - 8 m
DownwardPrecision Measurement Range: 0.5 - 11 m
Detectable Range: 11 - 22 m
SidesPrecision Measurement Range:0.5 - 10 m
Effective Sensing Speed: ≤ 8m/s
FOV: Horizontal: 80°, Vertical: 65°
Operating EnvironmentForward, Backward and Sides:
Surface with clear pattern and adequate lighting (lux > 15)
Upward:
Detects diffuse reflective surfaces (>20%)
(walls, trees, people, etc.)
Downward:
Remote Controller
Operating Frequency2.400 - 2.483 GHz; 5.725 - 5.850 GHz
Max Transmission Distance(Unobstructed, free of interference)2.400 - 2.483 GHz; 5.725 - 5.850 GHz
FCC: 8000 m
CE: 5000 m
SRRC: 5000 m
MIC: 5000 m
Operating Temperature Range0℃ to 40℃
Transmitter Power(EIRP)2.4 - 2.4835 GHz
FCC:≤26 dBm;CE:≤20 dBm;SRRC:≤20 dBm MIC:≤20 dBm
5.725 - 5.850 GHz
FCC:≤26 dBm;CE:≤14 dBm;SRRC:≤26 dBm
Battery 3950mAh
Charging Time2 hours 15 min
Operating Current/Voltage1800mA ⎓ 3.83V
Mobile Device HolderThickness Supported:6.5-8.5 mm,Max length: 160 mm
RC SizeFolded: 145×80×48 mm (L×W×H)
Unfolded: 190×115×100 mm (L×W×H)
Supported USB port typesLightning, Micro USB (Type-B), USB Type-C™
M2E Spotlight
Dimensions68x60x41 mm
Port TypeUSB Micro-B
Operating Range30 m
PowerMax 26W
IlluminanceFOV17°, Max:11lux @ 30m Straight
M2E Beacon
Dimensions68x40x27.8 mm
PowerAvg. 1.6W
Controllable Range5000 m
Light intensityMin Angle:55 cd;
Light intensity:157 cd
M2E Speaker
Dimensions68x55x65 mm
PowerMax 10W
Decibel100 db @ 1 meter distance
Bitrate 16 kbps
Footnotes
Footnotes[1] Remote controller required.
[2] Due to real-time digital enhancements, the photo and video size of the thermal data is larger than the sensor's native resolution.
[3] Omnidirectional Obstacle Sensing includes left/right, up/down, and forward/backward obstacle sensing. Sensing for left/right directions is only available in ActiveTrack or Tripod Mode. Omnidirectional Obstacle Sensing does not fully cover the circumference of a 360-degree arc. And left and right obstacle sensing system only works in specific modes and environments. DJI warranty does not cover any loss caused by crashing when flying left or right, even when ActiveTrack or Tripod mode is activated. Please be aware of your surroundings and App notifications when operating the Mavic 2 to ensure safety. These specs have been determined through tests conducted with the latest firmware. Firmware updates can enhance performance, so updating to the latest firmware is highly recommended."
[4]These specs have been determined through tests conducted with the latest firmware. Firmware updates can enhance performance, so updating to the latest firmware is highly recommended."
M2ED Thermal Camera
SensorUncooled VOx Microbolometer
LensHFOV: 57°
Aperture: f/1.1
Sensor Resolution160×120
Pixel Pitch12 μm
Spectral Band8-14 μm
Image Size [2]640×480 (4:3);
640×360 (16:9)
Burst shooting: 3/5/7 frames
Video Recording Modes640×360 @8.7fps
AccuracyHigh Gain: Max ±5% (typical)
Low Gain: Max ±10% (typical)
Scene RangeHigh Gain: -10° to +140°C
Low Gain: -10°to +400°C
PhotoJPEG
M2ED Visual Camera
Sensor1/2.3" CMOS; Effective pixels: 12M
LensFOV: approx. 85°
35 mm format equivalent:24 mm
Aperture: f/2.8
Focus: 0.5 m to ∞
ISO RangeVideo: 100-3200 (auto)
Photo: 100-1600 (auto)
Max Image Size4056×3040(4:3);4056×2280(16:9)
Interval (2/3/5/7/10/15/20/30/60 s)
Video Recording Modes4K Ultra HD:3840×2160 30p
2.7K:2688×1512 30p
FHD:1920×1080 30p
Max Video Bitrate100 Mbps
PhotoJPEG
Video FormatMP4,MOV (MPEG-4 AVC/H.264)
M2E Camera
Sensor1/2.3” CMOS;
Effective pixels:12 Megapixels
LensFOV:82.6°(24 mm);47.8°(48 mm)
Format equivalent:24-48 mm
Aperture:f/2.8(24 mm)-f/3.8(48 mm)
Auto focus at :0.5 - ∞
ISO RangeVideo:
100-3200
Photo:
100-1600(Auto)
100-3200(Manual)
Shutter Speed 8-1/8000s
Still Image Size4000×3000
Interval (JPEG: 2/3/5/7/10/15/20/30/60s RAW:5/7/10/15/20/30/60s)
Video Resolution4K: 3840×2160 24/25/30p
2.7K: 2720×1530 24/25/30/48/50/60p
FHD: 1920×1080 24/25/30/48/50/60/120p
Color ModeD-Cinelike
Supported File SystemFAT32(≤ 32 GB );exFAT(> 32 GB)
Photo FormatJPEG,DNG (RAW)
Video FormatMP4 / MOV (MPEG-4 AVC/H.264)
Charger
Input100-240V, 50-60Hz, 1.8A
OutputMain: 17.6V ⎓ 3.41A or 17.0V⎓3.53
USB: 5 V ⎓ 2 A
Voltage17.6±0.1V
Rated Power60W
Intelligent Flight Battery
Capacity3850 mAh
Voltage15.4 V
Max Charging Voltage17.6 V
Battery TypeLiPo
Energy59.29 Wh
Net Weight297 g
Charging Temperature5℃ - 40℃
Operating Temperature Range-10℃ to 40℃
Heating MethodsManual Heating;Auto Heating
Heating Temperature-20℃ to 6℃
Heating duration:500s (Max)
Heating Power55W (Max)
Charging Time90 min
Max Charging Power80W
APP / Live View
Video Transmission SystemOcuSync 2.0
Mobile AppDJI PILOT
Live View QualityRemote Controller:
720p@30fps / 1080p@30fps
Max Live View Bitrate40 Mbps
Latency120 - 130 ms
Required Operating Systemsios 10.0 or later Android 5.0 or later
Supported SD Cards
Supported SD CardsMicro SD™
Supporting Micro SD with capacity up to 128 GB and R/W speed up to UHS-I Speed Grade 3
Intro
Introducing the DJI Mavic 2 Enterprise
2018-10-29
DJI Mavic 2 Enterprise – A Tool for Everyday Heroes
2018-10-29
Case Study
DJI Mavic 2 Enterprise – Saving Lives in the Desert
2018-10-29
DJI Mavic 2 Enterprise – Wherever Duty Calls
2018-10-29
Tutorials
How to Use Mavic 2 Enterprise's Spotlight
2018-10-29
How to Use Mavic 2 Enterprise‘s Speaker
2018-10-29
How to Use Mavic 2 Enterprise‘s Beacon
2018-10-29
MANUALS
  • Mavic 2 Enterprise Series User Manual v1.2
    2018-12-20
  • Mavic 2 Enterprise Quick Start Guide v1.0
    2018-10-29
  • Mavic 2 Enterprise Dual Quick Start Guide v1.0
    2018-12-20
  • Mavic 2 Enterprise In the Box
    2018-10-29
  • Mavic 2 Enterprise Disclaimer and Safety Guidelines
    2018-12-20
  • Mavic 2 Enterprise Intelligent Flight Battery Safety Guidelines
    2018-10-29
ASSISTANT SOFTWARE
  • DJI Assistant 2 For Mavic Release Notes
    2019-03-21
  • DJI Assistant 2 For Mavic v2.0.7
    2019-03-21
  • DJI Assistant 2 For Mavic v2.0.6
    2018-12-21
APP / DJI PILOT
    iOS
    Requires iOS 10.0 or above.
    Compatible with iPhone XS Max, iPhone XS, iPhone XR, iPhone X, iPhone 8 Plus, iPhone 8, iPhone 7 Plus, iPhone 7, iPhone 6s Plus, iPhone 6s, iPhone 6 Plus, iPhone 6, iPhone SE, iPhone 5S
    Android
    Requires Android 5.0 or above.
    Compatible with DJI Crystalsky, Mi Pad 3, Mi Pad 2, Samsung S2, Samsung S3, Huawei M2, Huawei M3, Nexus 9.
    Huawei honor 9, Huawei P10, Google Pixel 2. One plus 6, LG G6, OPPO R15, VIVO X21, Nokia 7 plus, Mi Mix 2s, Samsung Galaxy S8.
Case Study
  • Police Operations Made More Effective
    2018-11-06
  • Reach Where Help is Needed
    2018-11-06
  • Saving Lives in the Desert
    2018-11-06
Purchase
You can click here to view available sales channels of the Mavic 2 Enterprise.
No. You can only purchase the Mavic 2 Enterprise from DJI authorized dealers.
Aircraft
The Mavic 2 Enterprise is built on the Mavic 2 flight platform. It is an all-in-one drone solution for industrial applications.
It features an extended port to mount DJI modular accessories, and comes with a self-heating battery, 24 GB onboard storage, DJI AirSense, and is compatible with the DJI Pilot mobile app.
The Mavic 2 Enterprise was specifically built to serve industries and applications in public safety, inspection, search & rescue, fire response, and law enforcement.
No. We strongly advise that you do not fly your Mavic 2 Enterprise during rainy weather.
Sensing for the left and right directions is only available with Tripod Mode, please pay attention to the surroundings when flying in P Mode and S Mode.
No.
Password Protection
Password protection is used to protect the data that the user stores on the device's onboard storage.
No. The password protection function only works on the device's 24 GB onboard storage.
1.When powering on the aircraft;
2. After connecting the aircraft with the remote controller;
3. When accessing the onboard storage data via a computer.
Yes.
GPS Timestamping
GPS timestamping records the time and GPS coordinates of when and where images are taken.
You can enable GPS timestamping in Camera Settings.
Yes, but the GPS Timestamp can only be added in Visible Mode.
Accessories
No. Currently, you can only adjust the spotlight angle manually before flight.
The spotlight is capable of assisting the onboard camera to shoot clearly at around 30 meters away.
Depending on background noise conditions, about 20 to 40 meters in general conditions.
You can use the speaker to:
1.Play voice messages that are pre-recorded with the DJI Pilot app.
2.Transmit real-time voice call-outs on the ground.
Depending on environments, approximately 5 kilometers in general conditions.
Remote Controller
In addition to all the newly added and improved features like the modular accessories, AirSense, Password Protection, and more, the Mavic 2 Enterprise features OcuSync 2.0 - a new transmission system, capable of operating at a distance of up to 8 kilometers, and offers higher resolution, better anti-interference during flight, and lower latency.
Approximately 2 hours and 15 minutes.
Battery
Yes.
Yes.
Approximately 1.5 hours.
When the temperature is between -20°C to 6°C and the battery power is higher than 50%, if the battery is powered off, press and hold the battery power button for 5 seconds to enable self-heating.
If it is powered on and is mounted on an aircraft, the self-heating function will be automatically enabled.
The batteries are capable of managing their battery levels automatically at all times.
Software
The Mavic 2 Enteprise is only compatible with the DJI Pilot mobile app.
Yes.
The Mavic 2 Enterprise Dual supports Spot Meter and Area Measurement.
FFC stands for Flat Field Correction. After the calibration, the thermal image quality will be improved, and the temperature change is easier to be observed.
Others
A. The influence of the atmosphere: The higher the temperature and the humidity of the atmosphere, the greater the temperature measurement error.
B. The distance between the camera and the object: The farther the distance, the greater the temperature measurement error.
C. The emissivity and background temperature of the object: When the surface emissivity of the measured object is low, and the background temperature is high, it will cause a large temperature measurement error.
