Aircraft
Takeoff Weight430 g
DimensionsFolded:
168×83×49 mm (L×W×H)
Unfolded:
168×184×64 mm (L×W×H)
Diagonal Distance213 mm
Max Ascent Speed4 m/s (S - mode[1])
2 m/s (P - mode)
2 m/s (Wi-Fi mode)
Max Descent Speed3 m/s (S - mode[1])
1.5 m/s (P - mode)
1 m/s (Wi-Fi mode)
Max Speed (near sea level, no wind)68.4 kph (S - mode[1])
28.8 kph (P - mode)
28.8 kph (Wi-Fi mode)
Maximum Takeoff Altitude5000 m
Max Flight Time (no wind)21 minutes (at a consistent 25 kph)
Max Hovering Time (no wind)20 minutes
Max Flight Distance (no wind)10 km
Max Wind Speed Resistance29 - 38 kph
Max Pitch Angle35° (S - mode[1])
15° (P - mode)
Max Angular Velocity250°/s (S - mode[1])
250°/s (P - mode)
Operating Temperature Range0°C - 40°C
Operating Frequency2.400 - 2.4835 GHz
5.725 - 5.850 GHz
Transmission Power (EIRP)2.400 - 2.4835 GHz
FCC: ≤28 dBm
CE: ≤19 dBm
SRRC: ≤19 dBm
MIC: ≤19 dBm
5.725 - 5.850 GHz
FCC: ≤31 dBm
CE: ≤14 dBm
SRRC: ≤27 dBm
GNSSGPS + GLONASS
Hovering Accuracy RangeVertical:
±0.5 m (with GPS Positioning)
Horizontal:
±1.5 m (with GPS Positioning)
Internal Storage8 GB
Sensing System
ForwardPrecision Measurement Range: 0.5 - 12 m
Detectable Range: 0.5 - 24 m
Effective Sensing Speed: ≤ 8 m/s
Field of View (FOV): Horizontal 50°, Vertical ±19°
BackwardPrecision Measurement Range: 0.5 - 10 m
Detectable Range: 0.5 - 20 m
DownwardAltitude Range: 0.1 - 8 m
Operating Range: 0.5 - 30 m
Operating EnvironmentForward:
Surface with clear pattern and adequate lighting (lux > 15)
Backward:
Downward:
Detects clearly patterned surfaces with adequate lighting (lux>15) and diffuse reflectivity (>20%)
Remote Controller
5.725 - 5.850 GHz
Max Transmission Distance (unobstructed, free of interference)2.400 - 2.4835 GHz:
FCC: 4000 m
CE: 2000 m
SRRC: 2000 m
MIC: 2000 m
5.725 - 5.850 GHz:
FCC: 4000 m
CE: 500 m
SRRC: 2500 m
Operating Temperature Range0℃ - 40℃
Transmission Power (EIRP)2.400 - 2.4835 GHz:
FCC:≤26 dBm
CE: ≤18 dBm
SRRC: ≤18 dBm
MIC:≤18 dBm
5.725 - 5.850 GHz:
FCC: ≤30 dBm
CE: ≤14 dBm
SRRC: ≤26 dBm
Battery2970 mAh
Operating Current/Voltage1400 mA ⎓ 3.7 V (Android)
750 mA ⎓ 3.7 V (iOS)
Supported Mobile Device SizeMax length: 160 mm
Supported Thickness: 6.5-8.5 mm
Supported USB Port TypesLightning, Micro USB (Type-B), USB-C
Charger
Input100 - 240 V, 50/60 Hz, 1.4 A
OutputMain: 13.2 V ⎓ 3.79 A
USB: 5 V ⎓ 2 A
Voltage13.2 V
Rated Power50 W
APP
Video Transmission SystemEnhanced Wi-Fi
NameDJI GO 4
Live View QualityRemote Controller:
720p@30fps
Smart Device:
720p@30fps
DJI Goggles:
720p@30fps
Latency (depending on environmental conditions and mobile device)170 - 240 ms
Footnotes
Footnotes[1] Remote controller reqired.
These specs have been determined through tests conducted with the latest firmware. Firmware updates can enhance performance, so updating to the latest firmware is highly recommended.
Gimbal
Mechanical RangeTilt: -100° to 22°
Roll: -30° to 30°
Pan: -12° to 12°
Controllable RangeTilt: -90° to 0° (default setting)
-90° to +17° (extended)
Stabilization3-axis (tilt, roll, pan)
Max Control Speed (tilt)120°/s
Angular Vibration Range±0.005°
Camera
Sensor1/2.3” CMOS
Effective Pixels: 12 MP
LensFOV: 85°
35 mm Format Equivalent: 24 mm
Aperture: f/2.8
Shooting Range: 0.5 m to ∞
ISO RangeVideo:
100 - 3200 (auto)
100 - 3200 (manual)
Photo:
100 - 1600 (auto)
100 - 3200 (manual)
Shutter SpeedElectronic Shutter: 8 - 1/8000s
Still Image Size4:3: 4056×3040
16:9: 4056×2280
HDR
Burst shooting: 3/5/7 frames
Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7EV Bias
Interval: 2/3/5/7/10/15/20/30/60 s
Pano: 3×1: 42°×78°, 2048×3712 (W×H)
3×3: 119°×78°, 4096×2688 (W×H)
180°: 251°×88°, 6144×2048 (W×H)
Sphere (3×8+1): 8192×4096 (W×H)
Video Resolution4K Ultra HD: 3840×2160 24/25/30p
2.7K: 2720×1530 24/25/30/48/50/60p
FHD: 1920×1080 24/25/30/48/50/60/120p
HD: 1280×720 24/25/30/48/50/60/120p
Max Video Bitrate100Mbps
Supported File SystemFAT32
Photo FormatJPEG/DNG (RAW)
Video FormatMP4/MOV (H.264/MPEG-4 AVC)
Mobile Device Control
5.725 - 5.850 GHz
Max Transmission Distance (unobstructed, free of interference)Distance: 80 m
Height: 50 m
Intelligent Flight Battery
Capacity2375 mAh
Voltage11.55 V
Max Charging Voltage13.2 V
Battery TypeLiPo 3S
Energy27.43 Wh
Net Weight140 g
Charging Temperature Range5℃ - 40℃
Max Charging Power60 W
Supported SD Cards
Supported SD CardsmicroSD
Class 10 or UHS-1 rating required
Recommended microSD Cards16G
Sandisk Extreme
Kingston 16GB SDHC-I SDCAC/16GB
32G
Sandisk Extreme V30
Sandisk Extreme V30 A1
Sandisk Extreme V30 Pro A1
64G
Sandisk Extreme Pro V30 A1
128G
Sandisk Extreme Plus V30 A1
Tutorials
DJI - Mavic Air Tutorials, Part 1: Unboxing
2018-01-29
DJI - Mavic Air Tutorials, Part 2: Your First Flight
2018-01-29
DJI - Mavic Air Tutorials, Part 3: QuickShots
2018-01-29
QuickTips
Mavic Air QuickTips - Preparing Flights
2018-03-19
Mavic Air QuickTips – ActiveTrack
2018-03-19
Mavic Air QuickTips – Boomerang
2018-03-19
Product
There are three ways to fly the Mavic Air. You can use the dedicated remote controller, your smartphone, or both together. For the other two options, the Mavic Air connects to your smartphone via DJI GO 4.
Connect the Mavic Air with your mobile device and follow the instructions in DJI GO 4 to complete activation.
No.
SD Card Capacity Class/UHS
16 GB Sandisk Extreme;
Kingston SDHC-I SDCAC/16GB
32 GB Sandisk Extreme V30;
Sandisk Extreme V30 A1;
64 GB Sandisk Extreme V30 A1;
128 GB Sandisk Extreme V30 A1;Sandisk Extreme Plus V30 A1
No. Although the two USB ports on the remote controller support video signal, they are unable to output video signal simultaneously.
Remote Controller
Yes. You can use an ordinary USB cable to connect your smartphone to the remote controller via the USB port at the bottom of the controller, but this may result in more discomfort when handling. Different cables come with the aircraft to meet your needs.
For safety reasons, every Mavic Air has a unique Wi-Fi name and password. These are listed on the side of the aircraft body, in the battery compartment, and on the carrying case. (For iOS systems, iOS v9.0 or later is required.)
Connect your smartphone to the aircraft’s Wi-Fi by scanning the QR code with DJI GO 4 app for first-time use. Alternatively, you can manually type in the Wi-Fi name and password.
First, connect your smartphone to the aircraft via Wi-Fi. Next, enter the DJI GO 4 app and go to Wi-Fi Settings to change the Wi-Fi name and password. You can also change the Wi-Fi name and password with DJI Assistant 2 on a computer.
No. You can only scan the QR code to connect to the aircraft’s Wi-Fi using DJI GO 4.
Propulsion
Doing so isn’t necessary.
The non-foldable propellers are more streamlined, making the Mavic Air smaller and more portable when folded.
The Mavic Air can withstand wind speeds up to 10 m/s.
16,400 ft (5000 m).
Features
The control range is 8.2–19.68 ft (2–6 m).
The Mavic Air supports the following panorama modes:
Vertical: The camera automatically takes three vertical photos, stitching them into one panorama.
Horizontal: The camera will take nine photos from different angles, stitching them into one panorama.
180°: The Mavic Air automatically rotates its body and gimbal shooting 21 pictures, stitching them together in DJI GO 4 for a breathtaking 180° panorama.
Sphere: The Mavic Air automatically rotates its body and gimbal to shoot 25 photos, stitching them together for an eye-catching spherical panorama.
SmartCapture only allows the Mavic Air to fly at eye level when it’s 9.8 feet (3 meters) or less away from you. This is to ensure better flight safety and control precision. You can gesture to fly higher or lower when it’s farther away from you.
Batteries
Yes.
Users can insert the adaptor into a battery and turn it into a mobile power bank.
The power button powers on and off the battery. To do this, press it once, and then press again, holding it for at least two seconds to power on or off the battery.
The power button also allows you to check the battery level. To do this, press the power button once and observe how many LEDs light up for the power level.
It takes 55 minutes to charge a battery fully when using a standard charger or a Charging Hub.
It is recommended to charge batteries at least once every three months fully.
Updating Firmware
No. If you do, the update will fail. You will then need to download the firmware and update again.
Before the update is complete, the aircraft will need to restart. Once it does, reconnect your mobile device to the Mavic Air’s Wi-Fi. DJI GO 4 is just reminding you that you will need to do this for a successful update.
Yes.
Connect the Mavic Air to DJI GO 4, and the app will inform you of appropriate updates to ensure consistency.
a. Low-battery level. Make sure the battery level is higher than 50%.
b. Powering off the Mavic Air or the remote controller during the update. If this happens, please restart the Mavic Air and the remote controller and begin the update again.
c. Internet disconnection when downloading firmware.
d. If update failure persists, or the remote controller does not link with the aircraft, there may be firmware inconsistencies between devices. In this case, use DJI Assistant 2 on your computer to update your aircraft and the remote controller to the latest versions separately.
Video Transmission
When connected to the remote controller:
2.4GHz
FCC: 4000 m, CE: 2000 m, SRRC: 2000 m (unobstructed, free of interference, when FCC compliant).
5.8GHz
FCC: 4000 m, CE: 500 m, SRRC: 2500 m (unobstructed, free of interference, when FCC compliant).
When connected to a mobile device:
Max height: 50 m
Max distance: 80 m
720p at 30 fps.
The video transmission latency to your mobile device is 170 to 240 ms. However, this is subject to the performance of your mobile device and signal interference.
DJI GO 4 chooses a frequency band automatically by default, but users can manually select between 2.4 GHz and 5.8 GHz frequencies, according to actual needs.
