Specs
Camera
  • Sensor
  • 1/1.7-inch CMOS
    Effective Pixels: 48 MP
  • Lens
  • FOV: 155°
    Equivalent Focal Length: 12.7 mm
    Focal Length: 2.34 mm
    Aperture: f/2.8
    Focus Mode: FF
    Focus Range: 0.6 m to ∞
  • ISO Range
  • 100-6400 (Auto)
    100-25600 (Manual)
  • Shutter
  • Rolling Shutter
  • FOV
  • 155°
  • Video Resolution
  • With DJI Goggles 2:
    4K@30/50/60/100/120fps
    2.7K@30/50/60/100/120fps
    1080p@30/50/60/100/120fps
    With DJI FPV Goggles V2:
  • Video Format
  • MP4
  • EIS
  • Supports RockSteady
  • Weight
  • Approx. 8.3 g (coaxial cable included)
Air Unit
  • Weight
  • Air Unit (camera module excluded): Approx. 28 g
    Air Unit (camera module included): Approx. 36.4 g
    Antenna: Approx. 3 g
  • Dimensions
  • Transmission Module (L×W×H): 32.5×30.5×14.5 mm
    Camera Module (L×W×H): 21.2×20×19.5 mm
    Coaxial Cable: 115 mm
    3-in-1 Cable: 100 mm
    Antenna: 85 mm
  • Communication Frequency
  • 2.400-2.4835 GHz (RX only)
    5.725-5.850 GHz (RX and TX) [1]
  • Transmission Power (EIRP)
  • FCC: < 33 dBm
    CE: < 14 dBm
    SRRC: < 30 dBm
  • End-to-End Latency [2]
  • With DJI FPV Goggles V2:
    810p/120fps Video Transmission Quality: The latency is lower than 28 ms.
    810p/60fps Video Transmission Quality: The latency is lower than 40 ms.
    With DJI Goggles 2:
    1080p/100fps Video Transmission Quality: The latency is as low as 30 ms.
    1080p/60fps Video Transmission Quality: The latency is as low as 40 ms.
  • Max Video Transmission Range [3]
  • 10 km (FCC), 2 km (CE), 6 km (SRRC)
  • Supported Flight Control System
  • The DJI O3 Air Unit supports Betaflight 4.3.0 and higher versions.
  • Input Voltage
  • 7.4-26.4 V
  • Operating Temperature
  • -10º to 40º C (14° to 104° F)
  • Channels
  • Supports auto mode
    Supports manual mode: 40 MHz: 1 channel; 20 MHz: 3 channels; 10 MHz: 3 channels
  • Channels Info
  • FCC/SRRC/CE:
    40 MHz:
    Channel 1: 5794.5 MHz
    20 MHz/10 MHz:
    Channel 1: 5768.5 MHz
    Channel 2: 5804.5 MHz
    Channel 3: 5839.5 MHz
  • Supported SD Cards
  • microSD (up to 256 GB)
  • Recommended microSD Cards
  • SanDisk Extreme U3 V30 A1 32GB microSDXC
    SanDisk Extreme Pro U3 V30 A1 32GB microSDXC
    Kingston Canvas Go!Plus U3 V30 A2 64GB microSDXC
    Kingston Canvas React Plus U3 V90 A1 64GB microSDXC
    Kingston Canvas React Plus U3 V90 A1 128GB microSDXC
    Kingston Canvas React Plus U3 V90 A1 256GB microSDXC
    Samsung PRO Plus V30 U3 V30 A2 256GB microSDXC
  • Supported DJI Goggles
  • DJI Goggles 2 and DJI FPV Goggles V2
  • Supported DJI Remote Controller
  • DJI FPV Remote Controller 2
DJI Goggles 2
  • Model
  • RCDS18
  • Weight
  • Approx. 290 g (headband included)
  • Dimensions
  • With antennas folded: 167.40×103.90×81.31 mm
    With antennas unfolded: 196.69×103.90×104.61 mm
  • Screen Size (single screen)
  • 0.49-inch
  • Resolution (single screen)
  • 1920×1080
  • Refresh Rate
  • Up to 100 Hz
  • Interpupillary Distance Range
  • 56-72 mm
  • Diopter Adjustment Range
  • -8.0 D to +2.0 D
  • FOV (single screen)
  • 51°
  • 2.400-2.4835 GHz
    5.725-5.850 GHz [1]
  • 2.4 GHz: < 30 dBm (FCC), < 20 dBm (CE/SRRC/KC)
    5.8 GHz [1]: < 30 dBm (FCC), < 23 dBm (SRRC), < 14 dBm (CE/KC)
  • Wi-Fi Protocol
  • Wi-Fi 802.11b/a/g/n/ac
  • Wi-Fi Communication Frequency
  • 2.400-2.4835 GHz
    5.150-5.250 GHz (indoor use only) [4]
    5.725-5.850 GHz [1]
  • Wi-Fi Transmission Power (EIRP)
  • 2.4 GHz: < 20 dBm (FCC/CE/SRRC/KC)
    5.1 GHz [4]: < 20 dBm (FCC/CE/KC)
    5.8 GHz [1]: < 20 dBm (FCC/SRRC/KC), < 14 dBm (CE)
  • Bluetooth Protocol
  • Bluetooth 5.2
  • Bluetooth Communication Frequency
  • 2.400-2.4835 GHz
  • Bluetooth Transmitter Power (EIRP)
  • < 8 dBm
  • Max Video Transmission Bitrate [5]
  • 50 Mbps
  • Video Recording Format
  • MOV
  • Supported Video and Audio Playback Formats
  • MP4 and MOV (video coding formats: H.264 and H.265; audio format: ACC, PCM)
  • Wi-Fi Wireless Streaming
  • Supports DLNA Protocol
  • -10° to 40° C (14° to 104° F)
  • Power Input
  • DJI Goggles 2 Battery
  • Capacity
  • 1800 mAh
  • Voltage
  • 7-9 V (1.5 A)
  • Type
  • Li-ion
  • Chemical System
  • LiNiMnCoO2
  • Energy
  • 18 Wh
  • Charging Temperature
  • 0° to 45° C (32° to 113° F)
  • Max Charging Power
  • 12.6 W (5 V/2 A, 9 V/1.4 A)
  • Weight
  • Approx. 122 g
  • Dimensions (L×W×H)
  • 73.04×40.96×26 mm
  • Operating Time
  • Approx. 2 hours
DJI FPV Goggles V2
  • Model
  • FGDB28
  • Weight
  • Approx. 420 g (headband and antennas included)
  • MP4, MOV, MKV (video coding format: H.264; audio formats: AAC-LC, AAC-HE, AC-3, MP3)
  • 0° to 40° C (32° to 104° F)
  • MOV (video coding format: H.264)
  • FOV
  • 30° to 54°, adjustable
    Image Size: 50% to 100%
  • 2.400-2.4835 GHz
    5.725-5.850 GHz [1]
  • 50 Mbps
  • Dimensions
  • Without antennas: 184×122×110 mm
    With antennas: 202×126×110 mm
  • 2.400-2.4835 GHz
    FCC: ≤ 28.5 dBm
    CE: ≤ 20 dBm
    SRRC: ≤ 20 dBm
    5.725-5.850 GHz [1]
    FCC: ≤ 31.5 dBm
    CE: ≤ 14 dBm
    SRRC: ≤ 19 dBm
  • 2-inch
  • Power Input
  • Dedicated DJI Goggles batteries
  • Communication Bandwidth
  • Max 40 MHz
  • 58-70 mm
  • Refresh Rate
  • 144 Hz
  • Screen Resolution
  • 1440×810
DJI FPV Goggles V2 Battery
  • Weight
  • Approx. 119 g
  • 73.04×40.96×26 mm
  • Capacity
  • 1800 mAh
  • Voltage
  • Max 9 V
  • Chemical System
  • LiNiMnCoO2
  • Type
  • Li-Po 2S
  • Energy
  • 18 Wh
  • 10 W
  • Operating Time
  • Approx. 110 mins
  • Model
  • FC7BGC
  • Weight
  • Approx. 346 g
  • 2.400-2.4835 GHz
    5.725-5.850 GHz [1]
  • 2.4 GHz: ≤ 28.5 dBm (FCC), ≤ 20 dBm (CE/SRRC)
    5.8 GHz [1]: ≤ 31.5 dBm (FCC), ≤ 19 dBm (SRRC), ≤ 14 dBm (CE)
  • 190×140×51 mm
  • Operating Time
  • Approx. 9 hours
  • Charging Time
  • 2.5 hours
Other
  • Footnotes
  • 1. The 5.8 GHz frequency band is currently banned in certain countries or regions. For details, please refer to local laws and regulations.
    2. Tested in an outdoor open environment without interference. The video transmission latency data varies with different models.
    3. Data is tested under different standards in an outdoor open environment without interference. Only to serve as a reference for the max one-way communication distance without considering RTH. Please pay attention to the RTH prompts during actual flight. Max one-way communication distance of DJI O3 Air Unit in countries/regions of different standards:
    FCC: United States, Australia, Canada, Hong Kong, Taiwan, Chile, Colombia, Puerto Rico, and other regions.
    SRRC: Mainland China.
    CE: UK, France, Germany, Portugal, Spain, Switzerland, Macau, New Zealand, UAE, and other regions.
    4. The 5.1 GHz frequency band is currently banned in Thailand and Israel. For details, please refer to local laws and regulations.
    5. Tested in an outdoor open environment without interference. The video transmission bitrate varies with operating environments.
  • Guaranteed software updates until
  • 2026/12/31
