General
Gimbal DimensionsUnfolded: 264.5×111.1×92.3 mm
Folded: 174.7×74.6×37 mm
WeightGimbal: 292 g
Magnetic Phone Clamp: 34 g
Max Length of Built-in Extension Rod215 mm
Compatible Phone Weight230 ± 60 g
Compatible Phone Thickness6.9-10 mm
Compatible Phone Width67-84 mm
Gimbal
Power Consumption1.2 W (under ideal conditions with the gimbal fully balanced)
Mechanical RangePan: -161.12° to 172.08°
Roll: -127.05° to 208.95°
Tilt: -101.46° to 229.54°
Max Control Speed120° /s
Others
AppDJI Mimo
Battery
TypePouch Cell
Capacity1000 mAh
Energy7.74Wh
Voltage6-8.8 V
Charging Temperature5° to 40°C (41° to 104°F)
Operating Temperature0° to 40°C (32° to 104°F)
Operating Time6.4 hrs (under ideal conditions with the gimbal fully balanced)
Charging Time1.5 hrs (measured with a 10W charger)
Gimbal Charging PortUSB-C
External Device Charging PortNo.
Universal Mount1/4" Threaded Hole
Wireless Mode
ModelBluetooth Low Energy 5.0
Grip Tripod
Gimbal DimensionsLength: 138 mm
Diameter: 32 mm
Weight72 g
Intro
DJI OM 5 | Master Every Shot
2021-09-08
DJI OM 5 | Meet DJI OM 5
2021-09-08
Tutorials
DJI OM5 | First Use
DJI OM5 | First Use
2021-09-08
DJI OM5 | ShotGuides
2021-09-08
DJI OM5 | DJI OM Fill Light Phone Clamp
2021-09-08
General
Yes.
The magnetic force of DJI OM 5 is 47.5 Newtons, which is approximately the weight of two 2-liter soda bottles. This is more than enough strength to keep smartphones attached securely.
DJI OM 5 will not affect the performance of the phone attached to it. However, some phones may require calibration after mounting. The magnetic design may influence other magnetic products. Do not put OM 5 near a bank card, cardiac pacemaker, hard drive, or similar devices. Additionally, phones transmitting data with magnetic signals may also be affected (for example, Samsung phones supporting MST). It is recommended to take off the phone clamp before using such functions.
For more information, please refer to the phone compatibility list on the official DJI website.
Align the dots on the phone clamp and the roll motor of the gimbal. After attaching your phone onto the gimbal, rotate the roll motor and make sure the phone and gimbal are locked.
Due to wide-angle lenses and/or irregular phone sizes (for example, those of Huawei P40, and Huawei Mate 20 Pro), some users may see the gimbal in their camera view.  Users can try the following: Adjust the position of the Magnetic Phone Clamp, moving it away from the camera until the gimbal is not visible in the camera's view (applicable to iPhone 11 Pro, OPPO realme X2 Pro, OPPO Reno 2, Samsung S10+, etc.).
No. Due to its powerful motors, accurate balancing is not needed for DJI OM 5. When using the Magnetic Phone Clamp, you only need to keep it approximately in the middle of the phone.
For detailed information, please refer to the phone compatibility list on the official DJI website.
Yes. Connect your phone to DJI OM 5, launch the DJI Mimo app, tap the gesture icon next to the shutter, and tap (?) to view detailed instructions.
There are three ways to use ActiveTrack: 1. Press the trigger to track the subject in the middle of the frame automatically; 2. Manually select and track the subject in the app interface; 3. Enable Gesture Control and use the gestures indicated in (?) to begin tracking, take a photo, or record a video.
Power on DJI OM 5, and press the composition button twice to switch between the two orientations. You can also transition between portrait and landscape by rotating the roll axis manually.
Power on DJI OM 5 and press the M button twice to enter Standby mode. Once standby mode is enabled, press any button to exit the mode.
When the gimbal is in video, photo, slow motion, or hyperlapse mode, go to Settings->Gimbal and enable SpinShot. Use the joystick to complete a shot with your smartphone spinning 270 degrees.
Go to Story mode in the live camera view and select Custom Story.
Tap DynamicZoom mode in the live camera view, and start using this function by walking steadily forward or backward.
Select CloneMe from Pano, tap the shutter, and DJI OM 5 will automatically take a photo every five seconds and move the gimbal to the next position. After taking three photos, it will automatically stitch them into one photo.
Yes.
Connecting via Bluetooth is faster than connecting via Wi-Fi. Devices using Bluetooth will link automatically once they have been paired. Connecting via Bluetooth also saves energy compared to connecting via Wi-Fi.
1. Forget connected devices in the Bluetooth settings of your mobile phone; 2. Press and hold the shutter button, trigger, and switch button simultaneously for one second to forget the connected device.
No. However, the DJI Mimo app will provide the correct firmware version once connected.
Use the adjustable zoom slider on the left side of the handle to zoom in and out. Image quality is subject to the phone's camera performance.
There are four modes: Upright, Underslung, Low Position, and Side Grip.
No.
1. Check if the phone has been properly mounted onto the gimbal; 2. Perform Gimbal Auto Calibration; 3. Perform Horizontal Gimbal Adjustment in the DJI Mimo app.
Yes.
215 mm.
1. Directly extend it to the maximum length (215 mm) for use; 2. Adjust the angle manually by rotating the pivot joint on the top of the extension rod to a suitable angle anywhere between 0-90°. *Angle adjustment is especially helpful when shooting in low-angle scenarios.
 DJI Mimo
Yes.
The front and back cameras perform similarly in terms of tracking. However, only the back camera is able to track a person’s profile and continue tracking reliably, even if the subject turns or moves dramatically in ways that cause their shape to change from the camera's perspective.
Yes. However, the precision may differ depending on the smartphone being used, and it performs better when tracking one subject at a time.
1. Timelapse is suitable for recording the passing of time at a fixed scene by mounting DJI OM 5 on a tripod or base. 2. Motionlapse allows users to record a moving timelapse video by setting camera points. 3. Hyperlapse allows users to record everything passing by as they hold the gimbal and walk. ActiveTrack 4.0 provides more options for flexible shooting.
1. For iPhones, tap the camera icon to adjust ISO, shutter speed, EV, or to change the white balance in settings; 2. For Android phones, due to compatibility differences among manufacturers, only some models support the manual adjustment of camera parameters at this time. Check the compatibility list on the official DJI website for more details.
The related functions are under development and subject to the latest DJI Mimo App update.
Yes.
Yes.
Yes. However, the maximum video resolution depends on your phone’s camera. Please visit the official DJI website for the full compatibility list.
No
No.
On iPhones, yes. For smartphones with other operating systems, it depends on your phone’s camera. Please visit the official DJI website for a full compatibility list.
The stabilization and zooming algorithms require more time for calculations.
Motionlapse does not support manual zoom, but you can adjust other general parameters.
2-4 points.
Yes. You can enable the “Save Pano Original” function in the camera settings under Pano mode.
All photos and videos will be saved to your smartphone's album.
Yes. Some smartphones support shooting 1080p or 720p videos with Glamour Effects enabled.
Yes.
No.
Yes.
It supports all lenses on iPhone devices. You can choose whichever one you need. For Android devices, it depends on the camera of your phone. Generally, it supports the main camera and ultra-wide-angle cameras on most smartphones.
There are three different panoramas, all of which support landscape and portrait shooting: 1. 3×3 Panorama automatically takes and stitches together nine photos; 2. 240° Panorama automatically takes and merges seven photos; 3. CloneMe Pano automatically takes and merges three photos.
iOS will save the photos and videos to the album. Android will save photos and videos in storage or on a microSD card.
There are two ways to enable ShotGuides: 1. Launch the DJI Mimo App, select Video mode, and point your camera toward a subject or scene. DJI OM 5 will automatically recognize the content in the frame and provide corresponding shooting guides. Tap to switch to ShotGuides mode; 2. Launch the DJI Mimo app and select ShotGuides in camera mode.
Battery
No.
You can charge DJI OM 5 via the Type-C USB charging port on the right side of the handle. The recommended charging current is 2 A.
No.
No.
Yes.
It is not recommended.
Bluetooth
Each device has a number on the side of the phone holder. Users can choose the device in the DJI Mimo app. Users can also change the device name in the app.
1. Disconnect the previous phone and disable its Bluetooth, then connect DJI OM 5 to another smartphone. 2. When powering on OM 5, press the switch button, trigger, and shutter button at the same time for one second to clear the existing connection, and then connect OM 5 to another smartphone.
1. Turn off your DJI OM 5; 2. Clear the previous connection in the Bluetooth settings of your smartphone. Disable and then enable the Bluetooth of the smartphone; 3. Restart DJI Mimo. * If the above steps do not solve the problem, you can directly connect to Bluetooth in the DJI Mimo app, and choose not to pair the devices.
Accessories
The mounting hole at the bottom of DJI OM 5 is the standard 1/4"- 20 UNC port, which is compatible with most tripods.
Yes. However, external lenses may affect the balance of the gimbal. Large, heavy lenses are not recommended. Please ensure the total weight of the lense and smartphone is less than 290 grams.
Yes.
Yes.
The DJI OM Fill Light Phone Clamp support three color temperature options: neutral, cold, and warm.
The built-in LED lights support three brightness levels: high, mid, and low.
