The new Phantom 4 Pro V2.0 features an OcuSync HD transmission system, which supports automatic dual-frequency band switching and connects to DJI Goggles wirelessly. Like the Phantom 4 Pro and Advanced, the Phantom 4 Pro V2.0 is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video and Burst Mode stills at 14 fps. Plus, its FlightAutonomy system includes dual rear vision sensors and infrared sensing systems for a total of 5 directions of obstacle sensing and 4 directions of obstacle avoidance.
Aircraft
Weight (Battery & Propellers Included)1375 g
Max Ascent SpeedS-mode: 6 m/s
P-mode: 5 m/s
Max Descent SpeedS-mode: 4 m/s
P-mode: 3 m/s
Max SpeedS-mode: 45 mph (72 kph)
A-mode: 36 mph (58 kph)
P-mode: 31 mph (50 kph)
Max Tilt AngleS-mode: 42°
A-mode: 35°
P-mode: 25°
Max Angular SpeedS-mode: 250°/s
A-mode: 150°/s
Max Flight TimeApprox. 30 minutes
Hover Accuracy RangeVertical:
±0.5 m (with GPS Positioning)
Horizontal:
±1.5 m (with GPS Positioning)
Vision System
Vision SystemForward Vision System
Backward Vision System
Downward Vision System
Velocity Range≤31 mph (50 kph) at 6.6 ft (2 m) above ground
Altitude Range0 - 33 feet (0 - 10 m)
Operating Range0 - 33 feet (0 - 10 m)
Obstacle Sensory Range2 - 98 feet (0.7 - 30 m)
FOVForward: 60°(Horizontal), ±27°(Vertical)
Backward: 60°(Horizontal), ±27°(Vertical)
Downward: 70°(Front and Rear), 50°(Left and Right)
Measuring FrequencyForward: 10 Hz
Backward: 10 Hz
Downward: 20 Hz
Camera
Sensor1’’ CMOS
Effective pixels: 20M
LensFOV 84° 8.8 mm/24 mm (35 mm format equivalent) f/2.8 - f/11 auto focus at 1 m - ∞
ISO RangeVideo:
100 - 3200 (Auto)
100 - 6400 (Manual)
Photo:
100 - 3200 (Auto)
100- 12800 (Manual)
Mechanical Shutter Speed8 - 1/2000 s
Image Size3:2 Aspect Ratio: 5472 × 3648
4:3 Aspect Ratio: 4864 × 3648
16:9 Aspect Ratio: 5472 × 3078
PIV Image Size4096×2160(4096×2160 24/25/30/48/50p)
3840×2160(3840×2160 24/25/30/48/50/60p)
2720×1530(2720×1530 24/25/30/48/50/60p)
1920×1080(1920×1080 24/25/30/48/50/60/120p)
1280×720(1280×720 24/25/30/48/50/60/120p)
Still Photography ModesSingle Shot
Burst Shooting: 3/5/7/10/14 frames
Interval: 2/3/5/7/10/15/20/30/60 s
Video Recording ModesH.265
C4K:4096×2160 24/25/30p @100Mbps
4K:3840×2160 24/25/30p @100Mbps
2.7K:2720×1530 24/25/30p @65Mbps
2.7K:2720×1530 48/50/60p @80Mbps
FHD:1920×1080 24/25/30p @50Mbps
FHD:1920×1080 48/50/60p @65Mbps
FHD:1920×1080 120p @100Mbps
HD:1280×720 24/25/30p @25Mbps
HD:1280×720 48/50/60p @35Mbps
HD:1280×720 120p @60Mbps
H.264
C4K:4096×2160 24/25/30/48/50/60p @100Mbps
4K:3840×2160 24/25/30/48/50/60p @100Mbps
2.7K:2720×1530 24/25/30p @80Mbps
2.7K:2720×1530 48/50/60p @100Mbps
FHD:1920×1080 24/25/30p @60Mbps
FHD:1920×1080 48/50/60 @80Mbps
HD:1280×720 24/25/30p @30Mbps
HD:1280×720 48/50/60p @45Mbps
HD:1280×720 120p @80Mbps
Max Video Bitrate100 Mbps
PhotoJPEG, DNG (RAW), JPEG + DNG
VideoMP4/MOV (AVC/H.264; HEVC/H.265)
Supported SD CardsMicro SD
Max Capacity: 128GB
Write speed ≥15MB/s, Class 10 or UHS-1 rating required
Charger
Voltage17.4 V
Rated Power100 W
App / Live View
Mobile AppDJI GO 4
Live View Working Frequency2.4 GHz ISM, 5.8 GHz ISM
Live View Quality720P @ 30fps, 1080P @ 30fps
LatencyPhantom 4 Pro V2.0: 220 ms (depending on conditions and mobile device)
Phantom 4 Pro + V2.0:160 - 180 ms
Gimbal
Angular Vibration Range±0.02°
Infrared Sensing System
Obstacle Sensory Range0.6 - 23 feet (0.2 - 7 m)
FOV70° (Horizontal), ±10° (Vertical)
Measuring Frequency10 Hz
Operating EnvironmentSurface with diffuse reflection material, and reflectivity > 8% (such as wall, trees, humans, etc.)
Remote Controller
Operating Frequency2.400 - 2.483 GHz and 5.725 - 5.850 GHz
Max Transmission Distance2.400 - 2.483 GHz (Unobstructed, free of interference)
FCC: 4.3 mi (7 km)
CE: 2.5 mi (4 km)
SRRC: 2.5 mi (4 km)
5.725 - 5.850 GHz (Unobstructed, free of interference)
FCC: 4.3 mi (7 km)
CE: 1.2 mi (2 km)
SRRC: 3.1 mi (5 km)
Battery6000 mAh LiPo 2S
Transmitter Power (EIRP)2.400 - 2.483 GHz
FCC: 26 dBm
CE: 20 dBm
SRRC: 20 dBm
MIC: 17 dBm
5.725 - 5.850 GHz
FCC: 26 dBm
CE: 14 dBm
SRRC: 20 dBm
MIC: -
Video Output PortGL300K: HDMI
GL300L: USB
Mobile Device HolderGL300K: Built-in display device (5.5 inch screen, 1920×1080, 1000 cd/m2, Android system, 4 GB RAM+16 GB ROM)
GL300L: Tablets and smart phones
Intelligent Flight Battery
Capacity5870 mAh
Voltage15.2 V
Battery TypeLiPo 4S
Energy89.2 Wh
Net Weight468 g
Max Charging Power160 W
tutorials
DJI - Phantom 4 Pro - Narrow Sensing
2017-03-08
DJI – Phantom 4 Pro – How to Fly – Safe Flight Advice
2017-03-08
DJI – Phantom 4 Pro – ActiveTrack
2017-03-08
SHOWCASE
DJI – Phantom 4 Pro – Hawaiian Lava
2016-11-15
DJI – Introducing Phantom 4 Pro V2.0
2018-05-08
DJI – Phantom 4 Pro - Sharper Vision
2016-11-15
Documents & Manuals
  • Phantom 4 Pro/Pro+ V2.0 Release Notes
    2019-12-25
  • Phantom 4 Pro/Pro+ Series User Manual v1.6
    2018-05-08
  • Phantom 4 Pro V2.0 Quick Start Guide
    2018-05-17
  • Phantom 4 Pro+ V2.0 Quick Start Guide
    2018-05-17
  • Phantom 4 Series Disclaimer and Safety Guidelines
    2018-05-08
  • Phantom 4 Pro V2.0 In the Box
    2018-05-08
  • Phantom 4 Pro+ V2.0 In the Box
    2018-05-08
  • Phantom 4 Series Intelligent Flight Battery Safety Guidelines
    2018-05-08
FIRMWARE
  • Phantom 4 Pro+ V2.0 Remote Controller Firmware v01.00.04.00
    2018-10-26
  • How to Update Phantom 4 Pro+ V2.0 Remote Controller Firmware
    2018-06-14
APP / LIVE VIEW
    iOS V 4.3.29
    Requires iOS 10.0.0 or later (Mavic 2 Pro/Zoom requires iOS 10.0.2 or later).
    Compatible with iPhone X, iPhone 8 Plus, iPhone 8, iPhone 7 Plus, iPhone 7, iPhone 6s Plus, iPhone 6s, iPhone 6 Plus, iPhone 6, iPhone SE, iPad Pro, iPad, iPad Air 2, iPad mini 4.
    Optimized for iPhone X.
    Android V4.3.25
    Requires Android 5.0 or later.
    Compatible with Samsung S9+, Samsung S9, Samsung S8+, Samsung S7, Samsung S7 Edge, Samsung S6, Samsung S6 Edge, Samsung Note 8, Huawei P20 Pro, Huawei P20, Huawei P10 Plus, Huawei P10, Huawei Mate 10 Pro, Huawei Mate 10, Huawei Mate 9 Pro, Huawei Mate 9, Huawei Mate 8, Honor 10, Honor 9, Vivo X20, Vivo X9, OPPO Find X, OPPO R15, OPPO R11, Mi Mix 2S, Mi Mix 2, Mi 8, Mi 6, Redmi Note 5, Google Pixel 2XL, OnePlus 6, OnePlus 5T.
SOFTWARE
  • DJI Assistant 2 For Phantom
PRODUCT
The Phantom 4 Pro V2.0 uses the same camera as the Phantom 4 Pro and is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video at 100Mbps. Also, like the Phantom 4 Pro, V2.0 features a 30-minute maximum flight time and 7-kilometer long-range control. The remote controller of the Phantom 4 Pro V2.0 also supports 2.4 and 5.8GHz frequency switching, and a remote controller a with built-in screen is also available. Different from the Phantom 4 Pro, the Phantom 4 Pro V2.0 is equipped with an OcuSync transmission system, which allows the drone to connect to DJI Goggles wirelessly. The Phantom 4 Pro V2.0 also features an upgraded propulsion system with FOC sinusoidal driver ESCs and 9455S quick-release propellers that reduce noise and make the drone more aerodynamic. *The remote controller of Phantom 4 Pro V2.0 is not compatible with the Phantom 4 Pro, which uses Lightbridge transmission. Other accessories such as batteries, chargers, and ND filters are compatible with both the Phantom 4 Pro and Phantom 4 Pro V2.0.
The Phantom 4 Pro Obsidian comes in a matte black casing. Functionally, the Phantom 4 Pro Obsidian is the same as the Phantom 4 Pro. As such, the main differences between the Phantom 4 Pro Obsidian and Phantom 4 Pro V2.0 are mentioned in question 1.
Currently supported Micro SD cards are:
Sandisk Extreme 32GB UHS-3 V30 MicroSDHC
Sandisk Extreme 64GB UHS-3 V30 MicroSDXC
Panasonic 32GB UHS-3 MicroSDHC
Panasonic 64GB UHS-3 MicroSDXC
Samsung PRO 32GB UHS-1 MicroSDHC
Samsung PRO 64GB UHS-3 MicroSDXC
Samsung PRO 128GB UHS-3 MicroSDXC
*It's not recommend to use the Patriot EPPRO 64GB MicroSDXC UHS-3.
No.
CAMERA
The Phantom 4 Pro V2.0 camera is still equipped with a 1-inch 20-megapixel sensor and has a manually adjustable aperture from F2.8 to F11. It also supports autofocus by half-pressing the Shutter button and has a focus range from 1m to infinity. Always refocus before capturing additional shots if the subject has moved beyond the focus point. Focus at infinity if the subject is over 98ft (30m) away. Refocusing is also needed when switching from close shots to long shots during recording.
The Phantom 4 Pro V2.0 can record UHD 4K (4096×2160) at 60fps, at a maximum bitrate of 100Mbps using the H.264 codec and also supports H.265. It also allows you to capture still images while filming.
Photos will be captured as JPEG in the same resolution as the video recording.
H.265 retains 50% more information than H.264, creating more detailed and vivid images.
An electronic shutter may cause artifacts and distortion, such as jello, when shooting fast moving objects. A mechanical shutter prevents this and guarantees a high-quality image.
Yes. Tap a point on the display to focus at that point after switching from Metering to Focus mode. Autofocus can also be triggered by half-pressing the Shutter button before fully pressing the button to capture an image. Focus can be set between 1m and infinity.
The Phantom 4 Pro V2.0 uses a camera lens optimized for aerial imaging, with an aperture range from F2.8 to F11 and a 24mm equivalent focal length. It’s equipped with a mechanical shutter and adjustable aperture range, with autofocus support.
OBSTACLE SENSING SYSTEM
Only in Beginner mode and Tripod mode.
Available in Beginner Mode and Tripod Mode only, the infrared sensing system has a sensing field with a 70° angle horizontally and 20° angle vertically. The radiated infrared light is reflected back by obstacles, allowing the sensors to “see” them at a distance of up to 23ft (7m) by calculating the difference in projection and reflection times and using this information to create a 3D model of the environment and obstacles in it.
The Phantom 4 Pro V2.0 uses the same obstacle sensing system as the Phantom 4 Pro. Phantom 4 Pro V2.0’s maximum forward obstacle sensing range has been extended to 98ft (30m), with the rear sensing system sharing the same capability. Additionally, the Phantom 4 Pro V2.0 is equipped with infrared sensors on both sides of the aircraft, precisely detecting the distance between the aircraft and obstacles within a range of up to 23ft (7m).
No.
REMOTE CONTROLLER
No. The remote controller of Phantom 4 Pro V2.0 cannot be used with other Phantom series drones.
The Phantom 4 Pro V2.0 remote controller is equipped with an OcuSync transmission system and can be connected to DJI Goggles wirelessly for immersive FPV flight at up to 72 kph in S-mode.
The Phantom 4 Pro V2.0 is compatible with two remote controller types: the standard version and the built-in screen version. Both can switch between 2.4GHz and 5.8GHz frequency bands with a maximum controllable range of 4.3mi (7km) (unobstructed, free of interference, FCC compliant), and both can focus by half-pressing the shutter release button.
The Phantom 4 Pro+ controller has a 5.5-inch 1080p display, with 1000 cd/m2 brightness and built-in DJI GO 4 app. Its remote controller is also equipped with an HDMI port, Micro SD slot, microphone, loudspeaker, and Wi-Fi connectivity.
No.
No.
Yes.
1920*1080
Popular social media apps and DJI GO 4.
It uses a customized DJI system.
Both.
Users can install third-party apps when the Phantom 4 Pro+ V2.0 remote controller is updated to the latest firmware. However, DJI cannot be held responsible for any compatibility issues or other problems that occur as a result. If you experience any problems after installing a third-party app, we recommend uninstalling the app and/or restoring the controller to its original factory settings.
It supports Wi-Fi but not Bluetooth.
INTELLIGENT FUNCTIONS
The Phantom 4 Pro V2.0 features Intelligent Flight Modes such as TapFly, ActiveTrack, Draw, Gesture, Tripod, and more.
The Phantom 4 Pro V2.0’s Return to Home function forms a map of its environment in real time. The aircraft will choose the best flight path to return home and senses as far as 300m away to avoid obstacles more effectively. If the control signal is lost, the Phantom 4 Pro V2.0 will retrace its original path to regain its connection after one minute. When it reconnects, it will return to home following a straight route. If it fails to regain connection, it will also revert to straight line RTH.
First, set C1 or C2 to activate Narrow Sensing. When flying in a narrow space, activate Narrow Sensing, and the aircraft will adjust its sensing range and flight speed to fly safely through narrows gaps.
PROPULSION SYSTEM
Yes. Phantom 4 Pro V2.0 and Phantom 4 Pro propellers are cross-compatible. However, Phantom 4 Pro propellers (9450S) are less aerodynamic and louder than Phantom 4 Pro V2.0 propellers (9455S propellers).
New FOC sinusoidal driver ESCs not only reduce electromagnetic noise, but also improve the overall efficiency of the ESCs. Also, new 9455S quick-release propellers make the Phantom 4 Pro V2.0 more aerodynamic and reduce noise. It has the same maximum flight time and maximum speed as the Phantom 4 Pro.
VIDEO TRANSMISSION SYSTEM
The Phantom 4 Pro V2.0 uses an OcuSync video transmission system and time division multiplexer that supports uploading remote control signal and receiving video transmission signal in the same frequency band. The Phantom 4 Pro uses a Lightbridge video transmission system.
Both drones have a transmission distance of up to 4.3 mi (7km), and users can switch between 2.4 and 5.8GHz control frequencies to improve signal stability and cut through interference.
BATTERIES and BATTERY CHARGER
Yes.
The battery capacity is 5870mAh. It flies for two additional minutes compared to the Phantom 4.
FIRMWARE UPGRADE
Yes. Always use a battery with more than 50% power when upgrading.
Use DJI GO 4 to update the battery firmware to the appropriate version.
When updating firmware with the DJI GO 4 app for Phantom 4 Pro V2.0, confirm that the remote controller and aircraft are connected. Then download the firmware for the update following the prompts in the app. No OTG cable is required, unlike with the Phantom 4 Pro. Please refer to the instructions below when using DJI Assistant 2 to update. 1. To update the remote controller only: Power off the aircraft and connect the remote controller to your computer via USB. 2. To update the aircraft only: Connect the aircraft to your computer via USB. 3. To update the aircraft and remote controller together: Power on the aircraft and link it to the remote controller then connect the remote controller to the computer via USB; Once the aircraft and remote controller are connected to your computer, DJI Assistant 2 will respond to the device that was connected first.
