Zenmuse Z15-A7
Lightweight Stabilizer for Low-Light SHOOTING
Zenmuse Z15-A7
General
Built-In Functions
  1. Three Modes
    · Orientation-locked control
    · Non orientation-locked control
    · FPV mode (Reset)
  2. Built-in independent IMU module
  3. DJI gimbal special servos drive module
  4. HDMI-HD/AV module
  5. Infrared remote control module
  6. Wireless video transmission supported
  7. Camera shutter/video recording control supported
  8. Wide range voltage input supported
  9. S-Bus Receiver supported
Mechanical& Electrical Characteristics
Working CurrentStatic current: 200 mA (@25 V)
Dynamic current: 400 mA (@25 V)
Locked-motor current: 4 A (@25 V)
Operating Temperature-10°C ~ 50°C
Weight1.3 Kg
Dimensions210mmX204mmX246mm
GCU Weight63g
GCU Dimensions64.2 mm ×34.1mm ×19.5mm
Peripheral
Supported CameraSony ILCE-7S; Sony ILCE-7R
Supported LensSony FE 35 mm f2.8 ZA
GCU Input Power4S~12S LiPo (Recommend 6S if with S1000+)
Control RequirementAt least four spare receiver channels
Assistant Software System RequirementsWindows XP SP3; Windows 7; Windows 8 (32 or 64 bit)
Working Performance
Load Weight (Reference Value)622 g(@Sony ILCE-7S with Sony FE 35 mm f2.8 ZA, battery, lens hood and SD Card)
580 g(@Sony ILCE-7R with Sony FE 35 mm f2.8 ZA, battery, lens hood and SD Card)
Angular Vibration Range±0.01°
Maximum Controlled Rotation SpeedPan axis: ±130°/s
Tilt axis: ±130°/s
Roll axis: ±30°/s
Controlled Rotation RangePan axis control: ±360° continuous rotation
Tilt axis control: +50°/-140°
Roll axis control: ±40°
DJI - Mounting The Zenmuse Z15-A7 Gimbal
2015-05-25
Documents & Manuals
  • Zenmuse Z15-A7 Release Notes
    2016-01-14
  • Zenmuse Z15-A7 User Manual v1.2
    2015-09-28
Software & Drivers
  • Zenmuse Assistant Software v1.6
    2015-04-14
  • DJI WIN Driver Installer
    2013-01-18
  • * Important Note:
    As DJI Innovations has no control over use, setup, final assembly, modification (including use of non-specified DJI parts or misuse, no liability shall be assumed nor accepted for any resulting damage or injury.
    By the act of use, setup or assembly, the user accepts all resulting liability.
Buy ZENMUSE Z15-A7
Keep your camera level however you fly
