DJI Lightbridge
THE EVOLUTION OF SIGHT
DJI Lightbridge
Performance Parameters
Transmission Distance (outdoor and unobstructed)1.7 Km
EIRP100mW
Receiver Sensitivity(1%PER)-101dBm ±2dBm
Working Frequency2.4GHz ISM
Air System Antennas Gain2.0±0.7dBi@2450MHz
Ground System Antennas Gain5.0±0.7dBi@2450MHz
Hardware Functions Supported
Antenna ConnectorMMCX Male (air system), SMA Male (ground system)
Air System Operating Voltage3S~6S
Ground System Operating Voltage3S~6S
Air System Operating Amperage700mA ±20mA(@12V)
Ground System Operating Amperage600mA ±10mA(@12V)
Physical Parameters
Operating Temperature-10~50 °C
Dimension (no antennas)
  • Air system: 68mm(L)X48mm(W)X21mm(H)
  • Ground system: 125mm(L)X90mm(W)X20mm(H)
Gross Weight (no antennas)
  • Air system: 71g
  • Ground system: 295g
DJI Lightbridge Application Equipment
Video Input Format
AV
  • PAL25
  • NTSC30
HDMI
  • 720p50
  • 720p60
  • 1080i50
  • 1080i60
  • 1080p25
  • 1080p30
  • 1080p50
  • 1080p60
Recommended mobile device
  • Samsung Galaxy Note3 QCOM, N9005, N9006
  • Samsung Galaxy Note3 Exynos, N900
  • Samsung Galaxy S4
  • Samsung Galaxy Mega
  • Optimus G Pro
  • LG Electronics
  • LG Electronics G2
  • Sony Xperia Z (L36h)
  • Sony Xperia Z Ultra (XL36h)
  • Samsung Galaxy Tab Pro 10.1”
  • Samsung Galaxy Tab Pro 8.4”
  • Samsung Galaxy Note 10.1”
  • Google Nexus 7 32 Gb LTE
  • Google Nexus 7 16 Gb Wifi
  • LG 8.1” Tablet
System Requirement Of Mobile Device
  • Android system (version 4.1.2 or above)
Supported HD Display Device
  • Konka 32-inch LED32M1200AF
  • Konka 42-inch LED42M3820AF
  • Konka 42-inch LED42X9600UF
  • Skyworth 55E680E
  • TCL L40F3309B
  • TCL 4K*2K Smart 3D Cloud TV L5E5690A-3D
  • Konka LED46F5580F
  • LG 27EA33 Monitor
  • 12-inch ORTECA Portable Monitor
  • 7-inch FEELWORLD Portable Monitor
  • 27-inch SAMSUNG S27D360H Monitor
  • Ideal LED TV 3261
  • Zeiss Cinemizer
  • Vuzix Wrap 1200DXAR
  • Vuzix M2000AR
  • SONY HMZ-T3W-H
  • Samsung 28” TV 1080i 60Hz
  • LG 55LA6200 55” 1080i 60Hz
  • ikan VH8 8”
  • Samsung 46” TV (model 7080)
  • Samsung UE40D7080 HDTV
  • Scott TVX150 HDTV
  • Feelworld 10.1” FPV monitor (450cd/m2 version)
  • Feelworld 7” FPV DVR monitor
  • Lilliput 664/w 7” IPS field monitor
  • Lumenier 10.1” LCD monitor
  • Lilliput 7” monitor
  • Sony HMZ-T2 video goggles
  • Phottix Hector 7HD
How to install DJI Lightbridge on Phantom 2
2014-04-30
DJI Lightbridge installation demonstration(with DJI 5.8G remote control system)
2014-04-30
Connecting the DJI Lightbridge and Non-HD Gimbal AV Signal Output
2014-05-13
Connecting the DJI Lightbridge and Non-HD Gimbal HD Signal Output
2014-05-13
Release Notes
  • DJI Lightbridge Release Notes
    2015-05-11
  • DJI Lightbridge User Manual v1.04
    2015-03-12
  • DJI Lightbridge Quick Start Guide v1.06
    2015-03-12
Assistant Software & Driver
  • DJI Lightbridge Android App v 1.0.7 (Stop distributing and updating)
    2016-04-21
  • DJI Lightbridge Assistant Software v1.3 (Stop distributing and updating)
    2014-06-17
  • @Ground system decoder* v1.4.8
    2015-05-11
  • @Ground system main controller* v1.1.9
    2014-10-13
  • @Air system encoder* v1.1.10
    2014-12-30
  • @Air system main controller* v1.0.6
    2014-10-13
  • DJI Lightbridge Assistant Software v1.2
    2014-06-13
  • @Ground system decoder* v1.4.5
    2014-07-04
  • @Ground system main controller* v1.1.7
    2014-07-04
  • @Air system encoder* v1.1.5
    2014-07-04
  • @Air system main controller* v1.0.3
    2014-07-04
  • DJI WIN Driver Installer
    2013-01-18
  • * Important Notice:
    As DJI Innovations has no control over use, setup, final assembly, modification (including use of non-specified DJI parts i.e. motors, ESCs, propellers, etc.) or misuse, no liability shall be assumed nor accepted for any resulting damage or injury. By the act of use, setup or assembly, the user accepts all resulting liability.
    We will stop distributing and updating "DJI Lightbridge Android App v 1.0.7" & "DJI Lightbridge Assistant Software v1.3"on May 15, 2018, including adaptations to the new version of the operating system. After May 15, 2018, the software is still available for download. The server shutdown time will be announced separately. Looking ahead, DJI will continue to provide the best tools and services for users and developers.
  • * Go to DJI Wiki for release history!
Buy DJI Lightbridge
Wireless HD image transmission from above.
