The Master Wheels controller is an advanced professional wheel controller system that employs high-precision sensors, advanced control algorithms,and state-of-the-art product design to deliver precise and butter-smooth remote camera movement control.
Each wheel control module has its own set of dials to control speed, smoothness, and damping. Turn the damping knob to increase or decrease damping for that particular wheel module.
If the signal is weak due to strong interference, a wired connection is recommended.
If the signal is weak due to physical obstructions (e.g., wall, radio module, electrical cable), it is recommended to place the radio module on the opposite side of the obstacle.
Each wheel control module has its own three-stop toggle switch to control gimbal direction. Flip the switch to either end to set forward and backward direction, and to the middle for no movement at all.
Users can detach the three Master Wheels control modules and mount them at different places to accommodate the space where it is used. Users just need cables to connect a removed module to the base.
