Z415-M
General
Max Allowable Voltage17.4V
Battery2-4S LiPo
Max Allowable Current (Continuous)15A
Max Peak Current ( < 3 sec)20A
Support High Rotational Speed Motors280000rpm (1 pole pair)
Max Regular Signal Frequency500Hz
Max OneShot125 Signal Frequency650Hz
Weight(include wires)6.3g
Operating Temperature-10℃ to 40℃
TYPICAL DIMENSIONS
Length(Without Cables)24.00 mm
Width12.00 mm
Thickness4.65 mm
Motor Cable Length75.00 mm
Power Cable Length100.00 mm
Signal Cable Length132.00 mm
Z425-M
General
Battery2-4S LiPo
Max Allowable Current(Continuous)25A
Max Peak Current( < 3 sec)30A
Weight(include wires)7.5g
TYPICAL DIMENSIONS
Width12.00 mm
Thickness4.65 mm
Z415-M & Z425-M
General
Compatible Motor Modelsincluding but not limited to: 1804,1806, 2204, 2206, 2208, 2212, 2216, 2312, 2808, 3506
PC Assistant Software
  • Output PWM Frequency settings
  • 3D Mode settings
  • Motor rotation direction quick settings
  • Timing settings
  • Active braking settings
  • Acceleration settings
  • Motor rotation direction settings
  • Startup tone settings
  • Throttle range settings
  • Firmware upgrade
Typical ApplicationsRacing drones
Documents & Manuals
  • Takyon Z415-M/Z425-M Electronic Speed Controller User Manual
    2016-07-21
  • Takyon Z415-M/Z425-M Electronic Speed Controller Quick Start Guide
    2016-07-21
  • Takyon Updater User Guide
    2016-07-14
SOFTWARE
  • DJI Assistant 2
Buy TAKYON Z425-M AND Z415-M
Built to Race
