Internet Explorer is no longer supported. It is recommended to use other browsers.
Features | Excellent Motor Compatibility Active Braking System Adjustable Motor PWM Frequency 3-6S LiPo Battery Maximum Working Currency up to 60A |
Two Throttle Signal Mode | Regular throttle signal: 30Hz to 500 Hz PWM signal OneShot125 signal:30-650 Hz |
High Rotational Speed Motors | 40000rpm(7 pole pairs) 280000rpm(1 pole pair) |
PC Assistant Software | Timing Settings Active braking settings Acceleration Settings Startup tone settings Motor rotation direction settings Motor rotation direction testing Throttle range settings Firmware upgrade Output PWM Frequency settings |
Complete Electromagnetic Compatibility Test | Radiated RF electromagnetic field immunity Radiated emission Electrostatic discharge immunity |
Input Voltage | Minimum:9.6 V Maximum:26.1 V |
Allowable Current (Continuous) | Maximum:50 A |
Peak Current (< 3 sec) | Maximum:60 A |
PWM Input Signal Level | Maximum:5.0 V Minimum:3.0 V |
Compatible OneShot125 Signal Frequency | Minimum:30 Hz Maximum:650 Hz |
Compatible Regular Signal Frequency | Minimum:30 Hz Maximum:500 Hz |
Operating Temperature | Minimum:-10 ℃ Maximum:50 ℃ |
Note | The data above is measured at a temperature of 25°C and a voltage of 22.2V |
Quiescent Current | Minimum Value:0.0221A Typical Value:0.0227 A Maximum Valu:0.0235 A |
Full Throttle Working Current* | Minimum Value:47.394 A Typical Value:50.137 A Maximum Valu:53.469 A |
Hovering ESC Temperature** | Typical Value:30.4 ℃ |
Note | Testing Environment: *Propeller:2255;Motor:3510 Motor(KV350) **Aircraft:diagonal wheelbase 600mm;Propeller:1345 Propeller;Motor:3510Motor(KV350);Battery:6S LiPo,4500mAh;Total Aircraft Weight:2010g |
Max Allowable Voltage | 26.1 V |
Max Allowable Current *(Continuous) | 60 A |
Max Peak Current (< 3 sec) | 70 A |
Max OneShot125 Signal Frequency | 500 Hz |
Default Output PWM Frequency | 16 kHz |
Weight (not including wires) | 50 g |
Battery | 3-6S LiPo |
Compatible Motor Models | Including but not limited to: 1306、1804、1806、2216、2312、3510、3515、3520、4010、4114、4216、5010、6215 |
Note | *meausred in ventilated environment and at a temperature of 25°C. |
Input Voltage | Minimum Value:9.6 V Typical Value:22.2 V Maximum Value:26.1 V |
PWM Input Signal Level | Minimum Value:3.0 V Maximum Value:5.0 V |
Compatible OneShot125 Signal Frequency | Minimum Value:30 Hz Maximum Value:650 Hz |
Compatible Regular Signal Frequency | Minimum Value:30 Hz Maximum Value:500 Hz |
Operating Temperature | Minimum Value:-10 ℃ Typical Value:25 ℃ Maximum Value:40 ℃ |
Note | Typical Working Conditions*:The following data is measured at a temperature of 25°C and a voltage of 22.2V |
