General
Weight224g
SizeController: 54mm x 39mm x 14.9mm
PMU: 39.5mm x 27.6mm x 9.8mm
IMU: 41.3mm x 30.5mm x 26.3mm
GPS-Compass Pro: 62mm (diameter) x 14.3mm
LED: 30mm x 30mm x 7.9mm
Built-in Functions
  • Built-in receiver
  • Multiple control modes
  • 2-axis gimbal supported
  • Low voltage protection
  • PC & Bluetooth Ground Station
  • External receiver supported
  • Intelligent orientation control
  • Sound alarm
  • 4 configurable outputs
Flight Performance
Maximum Wing ResistanceVertical: ± 0.5m
Horizontal: ± 1.5m
Max Yaw Angular Velocity150 deg/s
Max Tilt Angle35°
Ascent/Descent±6m/s
SDK
SDKMobile SDK is supported A2+LB2 used
Extending Function
PWM I/O PortsF1-F4 ports for output
iOSD Data StorageNeed iOSD MARK II
Ground Station2.4G/900MHz DATA LINK
Intelligent Flight ModesHome Lock, Course Lock, Point of Interest, Banked Turn
Remote Parameter AdjustmentA2 Assistant APP
PC AssistantDJI ASSISTANT, not support simulator
Hovering Performance
Hovering Accuracy
  • Vertical: ± 0.5m
  • Horizontal: ± 1.5m
Peripheral
Supported Multi-rotorQuadcopter: I4,X4;
Hexacopter: I6,X6,Y6,IY6
Octocopter: X8,I8,V8
Supported ESC400Hz frequency
Recommended Battery2S to 6S LiPo
Operating Temperature-5°C to +60°C
Assistant Software System RequirementWindows XP SP3 / 7 /8 (32 or 64 bit)
Recommended RadioS-BUS, D-BUS, PPM, DSM2 or normal receiver
Other DJI Products SupportedZ15, H3-2D, H3-3D, iOSD, 2.4G Data Link, S800 EVO, S900, S1000, S100+, etc.
Protection
Motor Fail ProtectionMinimum 6 axis
No Fly ZonesSupport
Low Battery Voltage WarningSupport
New A2 Firmware (V2.5) Introduction
2015-05-10
How to connect the A2 flight controller
2015-01-14
How to use A2 Assistant Software
2015-01-14
DJI - New "Banked Turn" Mode
2015-01-14
Release Notes
  • A2 Release Notes
    2016-01-06
  • DJI Assistant App
    2015-09-30
Assistant Software & Driver
  • A2 Assistant Software v1.9
    2016-01-05
  • @A2 Firmware* v2.7
    2015-09-28
  • iOSD Assistant Software v4.1
    2015-05-08
  • @iOSD MARK II Firmware* v3.02
    2014-11-07
  • DJI WIN Driver Installer
    2013-01-18
    2016-01-05
Manuals
  • A2 Quick Start Guide v1.22
    2015-05-08
  • A2 User Manual v1.24
    2016-01-05
  • You will need Adobe Reader to read PDF documents.
  • * Go to DJI Wiki for release history!
Buy A2
Impossibly Precise
