Naza-BTU-iOSD-mini
BTU Module
  • The Naza-M now provides assistant software for iPhone4s, iPhone5, iPad3, iPad4, iPadmini, iPod5. You can do parameter adjustments at any time on your mobile devices, using only the BTU with a built-in Bluetooth module which makes it easier and convenient. It uses low power Bluetooth to minimize the power consumption of your mobile devices. It is easy to use and will automatically save your last connection records. The password mechanism ensures your safety link. Parameters can be automatically synchronized to the Cloud Server and can be restored immediately when you changed your mobile devices.
  • Built-in Bluetooth(4.0)
  • Working Temperature: -10℃~+50℃
  • Communication Distance: 50m
  • Weight: 17g
  • Power Consumption: 240mw(0.04A@6V)
iOSD mini
  • The Naza-M now supports iOSD Mini, offering you real-time display of flight parameters on your monitor. This ensures you have the live status of your aircraft immediately and enjoy a safe, reliable flight, while undoubtedly giving you a fantastic FPV flight experience.
  • Voltage: 6V
  • Working Temperature: -20℃~+60℃
  • Video Input/Output Mode: PAL/NTSC(automatically recognize)
  • Weight: 14g
  • Working Current (Typical Value): 180mA@6V
The new firmware supports Bluetooth adjustment.
What’s new?
  • Firmware
Parameter configuration by NM Assistant is supported. (BTU module is required. Download the App software from iOS App store or scan the QR code to get the download link.)
iOSD mini supported.
S-bus II receiver supported.
Optimize the warming up condition, to avoid a long wait period before aircraft can takeoff.
  • Software
Add tips for IMU Advanced calibration time out.
  • Manual
Add connection diagrams when used with other DJI products.
Notices:
  • Make sure to reconfigure all parameters in the assistant software after upgrading firmware, since V3.16 upgrade will reset all parameters.
  • For safety reason, do not use power battery during firmware upgrade.
Download on the APP Store
Naza-M BTU
Please click here for support and downloads of iOSD mini.
