iPad Ground Station
Waypoint Flying At Your Fingertips
iPad Ground Station
The iPad Ground Station app is fully compatible with the DJI Phantom 2, Naza-M V2, WooKong-M and A2. It makes complex waypoint flying as simple as a few taps on a screen.
supported devices
Ground Station is supported all iPads running iOS 6 or above, with Bluetooth 4.0. This includes iPad 3, 4, Air and mini.
Data at a Glance
See flight routing, attitude and important stats, all readable in an instant.
Touchscreen Flight Control
Use the customizable joystick control mode to fly straight from your iPad, no radio control required.
Tap and Go Waypoint flight
Get in the air with a tap, just set a single waypoint then tap Go.
Route Planning
Set a flight path and edit it in the air in real time.
Route Templates
Four flight route templates for easy, accurate waypoint setting. The shape of each route can be customized.
Additional Features
  • Editable home point for Return to Home
  • One key takeoff and landing
  • Flight simulator
Accurate flight timing
Offline map support
Three map orientations
Voice control
Real time alarms
Route saving
English and Chinese UI
Cloud storage support
