DJI officially released the LED-BT-I(Bluetooth Indicator)
  • The WooKong-M now provides assistant software for iPhone4s, iPhone5, iPad3, iPad4, iPadmini, iPod5. You can adjust parameters at any time on your mobile device only through an LED indicator with a built-in Bluetooth module which makes it easy and convenient. It uses low power Bluetooth to minimize the power consumption of your mobile device,is easy to use and will automatically save your last connection records. The password mechanism ensures your safety link. Parameters can be automatically synchronized to the Cloud Server and can be restored immediately when you change your mobile device.
  • Built-in Bluetooth(4.0)
  • Interface: CAN-BUS/USB micro
  • Max communication distance:50m(line of sight)
  • Weight: 25g
  • Power Consumption: 0.3A@6V
The new firmware supports Bluetooth adjustment
What’s new?
  • Firmware
Add the Bluetooth assistant Function. Required LED-BT-I hardware support.
  • Software
New UI design, simple and easy to use.
Bluetooth LED firmware support upgrade online.
Support iOS mobile device assistant, download on the App Store.
  • Manual
New Quick Start Guide, matched with the assistant software V2.00.
Notices:
  • For safety reasons, do not use power battery during firmware upgrades.
  • Make sure you reconfigure all parameters after upgrading firmware.
Download on the APP Store
LED BLUETOOTH
