Tuned Propulsion System
E1200 Standard
E1200 Standard
With upgraded power for multirotors weighting 15.4-33 pounds (7-15 kg), the E1200 System provides efficiency, safety, and endurance under extreme conditions.
E1200 Pro
E1200 Pro
Designed for multirotor copters weighing 7-15 kg, the E1200 Pro can be adapted on platforms with 25mm-diameter arm tubes, such as the S900.
E800
E800
Smart ESCs that communicate the status of your motors in real time combine with more powerful motors (similar to those in the Inspire 1) to give you unprecedented control of your flight platform.
E310
E310
Built for multirotors with a diagonal base of 330-350mm. Built for multirotors weighing 1-2.5kg.
E305
E305
Finely customized and painstakingly engineered, the E305 Tuned Propulsion System is specifically designed for multirotor copters weighing 2.2-5.5 pounds (1-2.5 kg).
