Internet Explorer is no longer supported. It is recommended to use other browsers.
GNSS Frequency | Simultaneously receive: GPS: L1 C/A, L2, L5 BEIDOU: B1, B2, B3 GLONASS: F1, F2 Galileo: E1, E5A, E5B |
Positioning Accuracy | Single Point Horizontal:1.5 m(RMS) Vertical:3.0 m(RMS) RTK Horizontal:1 cm+ 1 ppm(RMS) Vertical:2 cm+ 1 ppm(RMS) 1 ppm: For every 1 km increase in distance, the accuracy will be 1 mm less. For example, the horizontal accuracy is 1.1 cm when the receiving end is 1 km away from the base station. |
Positioning Update Rate | 1 Hz, 2 Hz, 5 Hz, 10 Hz and 20 Hz |
Cold Start | <45 s |
Hot Start | <10 s |
Recapture Time | <1 s |
Initialization Reliability | >99.9% |
Differential Data Format | RTCM 2.X/3.X |
Features | Built-in high-precision 6-axis accelerometer D-RTK 2 movement monitoring Sloping measurements Electronic bubble level |
Dimensions(D-RTK 2 body with extension rod) | 168 mm×168 mm×1708 mm |
IP Rating | IP65 |
Data Link | OcuSync, Wi-Fi, LAN, 4G |
Operating Frequency | 2.400 GHz to 2.483 GHz (China, United States, Australia, Europe, Japan, Korea) 5.725 GHz to 5.850 GHz (China, United States, Australia) |
EIRP | OcuSync 2.4 GHz SRRC (Mainland China) / CE (Europe) / MIC (Japan) / KCC (Korea): < 20 dBm FCC (United States, Australia) / NCC (Taiwan, China): < 26 dBm 5.8 GHz FCC (United States, Australia) / SRRC (Mainland China) / NCC (Taiwan, China): < 26 dBm Wi-Fi 2.4 GHz SRRC (Mainland China) / CE (Europe) / MIC (Japan) / KCC (Korea): < 20 dBm FCC (United States, Australia) / NCC (Taiwan, China): < 22 dBm 5.8 GHz FCC (United States, Australia) / SRRC (Mainland China) / NCC (Taiwan, China): < 22 dBm |
Communication Distance | Operating Mode 1/3 SRRC/NCC/FCC/MIC/KCC/CE: 2 km (Unobstructed and free of interference, when the D-RTK 2 Mobile Station is used as a base station and the distance from the D-RTK 2 antenna to the bottom of the tripod is 1.8 m, when the difference in height between the remote controller and D-RTK 2 is less than 2 m, and when the remote controller is 1.2 m from ground level) Operating Mode 4 Between the aircraft and mobile station: NCC/FCC: 7 km; SRRC/MIC/KCC/CE: 5 km Between the remote controller and mobile station: 200 m (Unobstructed and free of interference at a flying altitude of about 120 m, when the distance from the D-RTK 2 antenna to the bottom of the tripod is 1.8 m, and when the remote controller is 1.2 m from ground level) Operating Mode 5 NCC/FCC: 12 km; SRRC/MIC/KCC/CE: 6 km (Unobstructed and free of interference, when the distance from the D-RTK 2 antenna to the bottom of the tripod is 1.8 m) |
Memory Capacity | 16 GB |
Power Consumption | 12 W |
Power Supply | 16.5 to 58.8VDC |
Battery | Type:Lithium-ion battery Capacity: 4920 mAh Energy: 37.3 WH |
Run Time | WB37 battery:>2 h MG-12000P battery:>50 h |
Operating Temperature | 4° to 131° F (-20° to 55° C) |
Modes |
Product Name & Compatible Products |
Number of Indicator Blinks |
Operation Mode 1 |
Rover Station (Agras T20 / Agras T16 / MG-1P RTK / Phantom 4 RTK/ P4 Multispectral) |
1 |
Operation Mode 2 |
Base Station* |
2 |
Operation Mode 3 |
Handheld Mapping Device (Agras T20 / T16 / MG-1P RTK/ Phantom 4 RTK) |
3 |
Operation Mode 4 |
Rover Station (Matrice 210 RTK V2) |
4 |
Operation Mode 5 |
Rover Station (Broadcast Mode, Matrice 300 RTK) |
5 |
OPTIMIZED ACCURACY. ULTIMATE RELIABILITY.
