Z318
Specs
Max Allowable Voltage13.05V
Battery2-3S LiPo
Max Allowable Current (Continuous)18A
Max Peak Current ( < 3 sec)25A
Support High Rotational Speed Motors280000rpm (1 pole pair)
Max Regular Signal Frequency500Hz
Max OneShot125 Signal Frequency600Hz
Weight(include wires)13g
Operating Temperature-10℃ to 40℃
Typical Dimensions
Length(Without Cables)42.34 mm
Width18.00 mm
Thickness7.10 mm
Motor Cable Length79.00 mm
Power Cable Length87.66 mm
Signal Cable Length119.66 mm
Z420
Specs
Max Allowable Voltage17.4V
Battery2-4S LiPo
Max Allowable Current(Continuous)20A
Max Peak Current( < 3 sec)30A
Weight(include wires)13.2g
Typical Dimensions
Length(Without Cables)42.36 mm
Width18.00 mm
Thickness8.80 mm
Z318 & Z420
Compatible Motor Modelsincluding but not limited to: 1804,1806,2204,2206,
2208,2212,2216,2312,2808,3506
PC Assistant Software
  • Timing settings
  • Active braking settings
  • Acceleration settings
  • Motor rotation direction settings
  • Startup tone settings
  • Throttle range settings
  • Firmware upgrade
Typical Applications
  • Racing drones
  • Camera drones
Documents & Manuals
  • Takyon Z318/Z420 Electronic Speed Controller User Manual
    2016-04-01
  • Takyon Updater User Guide
    2016-07-14
SOFTWARE
  • DJI Assistant 2
Buy Takyon Z318 Z420
Built to Race
